Question about Vacuums
I keep trying to send a text, but it immediately comes up saying resend at a specific time like two minutes later...then after three attempts it will say failed - general - memory full. close some applications & try again. What do I do?
  • 3 Answers
Ala
Posted on Mar 17, 2011
I HAVE THE BISSELL 3031123, BOUGHT USED, NOTICED IT WOULDN'T PICK UP ANYTHING, THE BELT IS BROKEN, LOOKS MELTED, WHAT WOULD CAUSE THIS AND IS THERE ANYTHING I CAN DO TO FIX THIS?
Sounds like the brush is stuck. When that happens the belt continues to run, quickly burning up. Take the brush out and clean both ends(bearings) and check that something is keeping the brush from turning. It's a fifteen minute procedure, and to save time pick up a belt or three (usually come 2+ in a bag) and you'll be ready.
Apr 04, 2017 | Bissell Vacuums
I bought a cordless Dyson, three days ago. I have charged it three times. It states that this model has a twenty minute running time. This one runs less than 10 minutes. JU6-US-HEA1415A
If after a few more discharge, charge cycles unit still underperforms then return for exchange or money back. Newer batteries have to be "exercised" a tad before they perform up to specs. And if they say 20 minutes, then hold them to it!!!!!!!!!!!!!!
Nov 28, 2016 | Vacuums
I have a Hoover SteamVac F5914-900 SpinScrub... The last time I used the hand tool attachment, it worked fine. Just tried to use it again, and now I only drips of water will come out of the hand sprayer,...
The brushes can be turned off on most of them via a switch on the hood. There shouldn't be water coming out onto the floor unless you are pulling the trigger at that top. You probably broke this when attempting to use the tools.
http://www.vacuummedic.com/product.php?id=231
Sep 23, 2012 | Hoover SteamVac F5914-900 SpinScrub...
I found a salton tweety and sylvester waffle maker, but there are no instructions. The light just stays on all the time when plugged in. How do you know when the waffles are done?
Try letting it warm up for at least ten minutes. Then add waffle batter and leave closed for about five minutes and check the waffle. If it is way over done try three minutes other wise adjust your time in thirty second increments. You should have great waffles in three or less tries.
Good Luck,
Gil Shultz
Jul 19, 2011 | Vacuums
My hand held Dyson vacuum will not charge. Every time I attempt to us it I get 3 charge light on the side flash?
My same symptoms are - after starting charge, Red light is on, then second light turns On. Then for a long time nothing happens. And later I have all three LED flashing.
I replaced battery and nothing changed.
Imeasured Power Supply voltage and found it 24.2v instead 28v as it stated on the label.
I opened it up and found that the three-lid chip marked 431 is faulty.
431 is a voltage shunt, which sets and controls output voltage.
You can use AIC431CUS or TL432 (TL431 has different pinout).
I replaced mine and volatge back to 28.25v and charger is now working as it should.
You can also use any TO-92 431 chip - there is enough room for it.
May 19, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Hoover Model U8185-900 beater bar part keeps smoking and burning up We've replaced the part Hoover PCB Display Bridge U8172 three times and the vac beater bar works for about a minute then the part starts...
I'm not sure why this is happening. Perhaps if you would contact Hoover and explain the problem to them such that it appears that there is a safety issue with their product, they might be more cooperative. If that fails, I have had luck writing letters to the CEO's of companies. You can usually find the CEO name and address online. This is probably not exactly the info that you desire, but I thought I'd add my 2 cents.
Mar 07, 2010 | Hoover U8185-900 Upright Vacuum
Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
May 13, 2009 | iRobot 4150 Roomba Vacuum
Sweeper belt
Greetings from GoVacuum.com,
Have you replaced the belt with a new one yet? You may want to try replacing the belt, as with flat belts like the Fantom Thunder, they do stretch out 4 -5 inches after time. We in fact recommended replacing a flat belt every year, even if the belt doesn't break, because of the stretching. I think what may have happened, is that your belt is stretched to the point where it will not stay on the pulley as soon as there is any tension (putting the brushes on carpeting), which will cause the belt just to slip off.
You should be able to replace the belt (very inexpensive, we sell Fantom belt for $2) and this should take care of the problem. When you replace the belt, you should also take the roller brush apart and remove any hair, or thread that may be wrapped around the bearings. You should be able to remove the bearing cap by pulling them, or holding one end, and unscrewing the other.
I'd even be willing to send you a free Fantom Thunder belt, if you'd be so kind to vote Fixya for this answer :-) Just send me an email with your name, address, and the exact model number (located on the back of the machine, or the bottom of it) of your vacuum, and vote Fixya, I'll immediately ship you the belt for free!
Please let me know if you have any other questions I can help you with.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
1-866-468-2288
Oct 13, 2008 | Fantom Vacums XT450K Upright Vacuum
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
