Question about Gateway GT5012 PC Desktop
The PC shuts down randomly. when it's restarted it displays message that a thermal event (overheating) has occurred. what could be cause? power supply?
  • 1,381 Answers
Hello antmanv1
It's nearly certainly a psu issue . Replace it by a more powerfull one .
A defective fan ( CPU or general ) could also cause malfunction . Check this first .
Download Speccy to have control on temperatures and all functionning devices : http://download.cnet.com/Speccy/3000-2094_4-75181811.html
Best regards .
fanaudi .
Posted on Mar 17, 2011
ITS A PROBLEM OF PROCESSOR FAN REPLACE IT
Posted on Mar 19, 2011
  • 604 Answers
Most likely with a message like this, its not power supply, but rather the CPU take the cover off and look at the processor fan and make sure it is turning. if it is not, you need to replace this fan. the overheating could have damaged your processor and if this is the case it can't be repaired but must be replaced.
    Brigadier General:
  • 8,909 Answers
A build up of fluff in the fan cooling the uProcessor. Poor compound quality between the heatsink and uProcessor or just general lack of ventilation. Any or all of which can be the cause/contributary factor.
Hope that helps.
NEW HP Spectre 13T-3000, 13.3" Touch will not run with the battery and shuts down randomly
you can use the unit without the battery. Remove the battery, plug in the charger/power supply and turn on the unit and wait for the result. if the problem persist?..... maybe the fault is in CPU fan. check the fan...overheating the processor. Cleaning the heat sync and reapplying silicon compound on CPU's can cure the problem.
Sep 02, 2014 | Computers & Internet
Acer aspire 4736g shut down unexpectedly
try using a cooler pad for your laptop for heating issue,
try changing the RAM also sometimes the faulty RAM also does this
Jan 17, 2013 | Computers & Internet
Pc suddenly powers off
that can be meaning if the processor is Not Supported with your motherboard,or the New Processor is not in good condition (can be Over Heat or damage).
Processor over heat or damage can be because the HEAT SINK (white or grey pasta at the top of processor) is not enaugh to cooling the processor or,the fan Proseccor is Dirty.
Jan 18, 2012 | Computers & Internet
My pc turns off automatically when iam working on it. its a desktop intel mother board with i3 2nd gen processor 2100 4gb dynet ram 500gb hdd, tell me what is the relative problem
first possibility - Your system is pulling too much power from your power supply while running that game. Your graphics card is probably pulling too much power and your PS isn't a high enough wattage.
second possibility - Your processor is overheating due to the increase load on it. This can happen if your cooling is insufficient or if your heat sync is a poor stock quality. Are all your fans running? If your card was overheating you would only get graphic failures but the PC would still be running.
Start by downloading a temperature monitoring program for your computer and run it while you run the game. see how hot your processor gets. Find online the normal range of your processor is and compare it with you are recording. If you aren't hitting any high temps then refer to the first possibility.
Sep 03, 2011 | Computers & Internet
Shut down problem
the fan/heatsink asembly is most likely clogged .. causing the thermal controller to kick in a thermal overheating warning and shutting down the laptop
Jun 13, 2010 | Toshiba Satellite A100-S8111TD Notebook
Shuts down randomly, nothing in the event log...
try to use windows xp or try to check hardware
May 30, 2010 | E-Machines eMachines Desktop PC
The computer will just randomly do a windows shutdown and then restart. Cleaned, changed the power supply and still does it.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the computer back on and figures out a way to foil the protection, the unit is probably doomed. Once a unit shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated unit is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning. Check the CPU fan if it is spinning and also the CPU itself put thermal paste. So that the heat from CPU will absorbed by the heat sink.
Jan 19, 2010 | Dell Dimension 2400 PC Desktop
My laptop keeps shutting down at random times. I
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Good luck
Oct 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Random shut down
Yes.... over heating can and will cause a system shutdown..
Download and install speedfan ( http://www.almico.com/sfdownload.php ) It will most likely tell you how hot things are really getting......
Depending on what cpu you have, you may have a thermal paste problem, you may need to remove the heatsink and re-apply heatsink thermal paste to the bottom of the heatsink and reseat ontop of the cpu. This will void any warranty if you PC still has any left.
Jan 07, 2009 | EliteGroup GeForce 6100SM-M Motherboard
Gateway e-4100 thermal event
There can also be thermal sensors in your power supply, on your motherboard, and video card. Does your problem happen during gaming/heavy computing, after x amount of time, or totally randomly?
If your case conforms to the later ATX spec or some derivative thereof, don't block the hole in the side of the case.
Just some stuff I've run into, maybe you already know this!
Nov 25, 2008 | Gateway Sb-4100-A PC Desktop
Gateway GT5012 PC Desktop Logo
116 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
