Question about Zanussi Refrigerators
No power to fridge, power point working and have checked fuse
  • 77 Answers
Sir plz check the transform is working or not
Posted on Mar 17, 2011
MY HISENSE FRIDGE IS NOT WORKING, THE LIGHT IS NOT ON, AND AM NOT HEARING ANY SOUND FROM IT
Could be a lot of things but if the light is not working (and I'm assuming it is OK) then I would be checking the power supply.
There is nothing else that makes this work except the door switch. Check the power point and if Ok then check for internal fuses. If the light is found OK then check the defrost timer. It may be jammed. Cheers
Feb 10, 2017 | Cell Phones
3 way fridge not working on 12 volt have checked with volt meter 12 volt not present at dc terminal fuse seems to be ok.
You need to trace down the 12 volt source wire right up to the point it gets power from the battery.
Aug 15, 2016 | RVs
The fan on my Miele fridge freezer is not working, how do I rectify this issue
Check first input power supply of fan if its OK then problems can possible in the fan motor . you can check pre fuse by a tester with continuity method
Jul 21, 2016 | Miele Refrigerators
Ice maker and dispenser is not getting water
Make sure "Stop Bar" is all the way down. Check water filter (if applicable. If water filter needs replaced, it can stop water from entering the system). Unplug the fridge or shut power off at fuse box for 20 minutes. After restoring power, If ice maker does not start after a few minutes, Check water inline. (if fridge has been moved, it could have pinched the inline). Check the point of where the inline starts (if possible, disconnect and flush inline. The inline has been known to get clogged at their point of origin coming off of a main water line)
May 15, 2016 | Frigidaire Refrigerators
It will not turn on.
First thing, disconnect AC and DC power. You can leave the LP attached but go ahead and close the valve for now.
Plug in AC only and let it boot up. If the fridge does not automatically, press the power button to turn it on. The refrigerator should start working. Let it run for a while to make sure it does get cold. Once you confirm it does work you can either unplug the fridge or just open the breaker in the fuse panel.
Before you reconnect the DC wires, you need to check the power coming in. Most camper units will have wiring that will have color on one side and white on the other. The color wire will be your 12VDC, white is neutral return. Once verified, pull out the fuse for the power to the fridge to isolate the DC voltage. Check with the manual for the fridge, the positive input should be marked or identified in some manner. Open the valve to let LP back into the lines and wait a few minutes. Plug the fuse back in. If the fridge does not turn on automatically, press the power button to turn it on.
With the DC power on and no AC detected, the display should display CHECK. Let the fridge run for a bit to make sure it cools. Once you know it is working, the breaker for the AC can be closed to turn on the AC power to the fridge. Press the MODE button until AUTO displays displays.
Let it get cold and resume normal operations.
May 10, 2016 | Atwood 6 Cubic Ft RV Refrigerator Black...
Fisher paykel fridge E442b Blows fuse on circuit board Changed power point no change
probably a fault in the compressor
have an fridge mechanic call and check out the capacitor for the compressor and what else that could be blowing the fuse
Nov 18, 2015 | Fisher Washing Machines
My 1993 model dometix RM 2611 fridge won't turn on no light's and doesn't make a sound.. wit could it be
Hi, This sounds like either a power supply issue or the ''fridge is completely knackered. Check that the power supply to the 'fridge is working. Check for an internal fuse in the 'fridge, if there's one there, is it working?
Jul 16, 2015 | Refrigerators
Fisher & paykel fridge e521t no power to fridge,not any power coming to fridge
Did you try an other electrical outlet? Can you test the outlet has any voltage?
does the fridge have an on / off switch? I don't think so, so if nothing works also check the cable and the plug going in the outlet.
Mar 17, 2015 | Fisher & Paykel Paykel E521TLX2 Fisher...
Blowing the fuse
Get someone ( electrician ) preferably to check all connections , something is going straight to earth.
Apr 18, 2010 | Maytag MSD2758G Side by Side Refrigerator
Refrigerators Logo
47 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
tony denham
Level 1 Expert
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
