Half paper at the back i thing stuck in roller tell me solution
  • 77 Answers
Ur printer is required service
Posted on Mar 17, 2011
Anyone having trouble with canon printer pixma mp 210 not feeding paper. i have tried every thing that the maintenance tools have. reinstalled the software. there is in the center obstructing the path....
did the paper feed sideways if so there is something stuck in the feeder, here what you do fold the bond paper into half then feed it manualy open the cover of the printer so you can see the paper pass through push through until it will pass underneath the small roller then pull it out slowly be sure the paper pass all the small roller, dont forget to unplug the unit from the outlet before executing this step
Aug 03, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
I have a HL-2070N printer and it would not print, the Paper light is red and blinking. Also, sometimes when it prints the pages get stuck half way out. Any solutions? Thank you.
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cause if the paper stops in the same position all the time.
The error light is simply telling you that there is a paper jam. Open both the back panel (you should be seeing the orange roller clearly) and the front panel. Grab the handle and take out the toner and drum and check there are papers stucked. Chances are there will be.
Thank you for using Fixya!
Dec 04, 2010 | Brother Office Equipment & Supplies
System keeps telling me i have a paper jam
Does the paper exit the paper tray?
If not, the half-moon shaped feed rollers may be slippery. Turn the copier on its back side to see the rollers.
Usually they are facing upwards and the rubber side is unreachable. Turn the copier back to its original position.
1. Press the copy button. When the copier starts feeding paper take the power cord off-QUICKLY. If you are quick enough the rollers remain at down position and you can clean them with some kind of rubber cleaning liquid or solvent. Perhaps alcohol, but it tends to dry out the rubber surface.
Jul 04, 2010 | Xerox WorkCentre 4150 Black and White...
Half inch of paper goes in and paper gets stuck
Sounds to me like the pickup roller is shot. These are somewhat easily removable and cheap to replace. However, you can usually eek some additional life out of a pickup roller by cleaning it with rubbing alcohol or even water (no soap, though). Let it dry and replace it and see how you do. The service manual found HERE should help you get through the take apart... and it's really not that hard to do it yourself.
The part number for a replacement roller (if that seems to be the issue) is: RG5-1940-000CN. There are many vendors online who can sell you this part for a few dollars.
Feb 07, 2010 | HP LaserJet 5L Printer
The paper twists and causes a jam on every print
sounds like something jamed in the rollers like a pin etc
Jan 05, 2010 | Epson Stylus R265 InkJet Photo Printer
Paper getting stuck
the reason the paper is going in sideways is because one feed roller has more pressure than the other
try cleaning the rollers with alcohol and cotton cloth
If that does not work remove the paper tray t
take your fingers and see if the feed rollers turn freely or turn in only one direction( some rollers are half moon and only turn a half turn)
Just try to make sure that the roller that is not working is in the same position and turns the same as the one that does feed properly
Jan 04, 2009 | Office Equipment & Supplies
Paper Jam
If it truly stops halfway then it must be obstructed by seomthing. If it only gets a short way past the pick up roller then it may be something else. A little trick for removing obstructions is to fold your paper in half or even a quarter so it is much thicker and stronger and try to feed that through. This can push through any obstructions (assuming they aren't too big). If it still gets stuck see if you can manually turn the main gear found to the side of the carriage and try to push the paper through that way (hence pushing through your obstruction). If your paper feeds through fine doing this then you may have another issue.
Good Luck.
Please rate my advice, good or bad.
Feb 03, 2008 | Lexmark All-In-One Printer
Recurring error
This answer was almost exactly correct:
>hey guys, for the "printer mispick" problem, try to remove the >toner and look IF there's any paper jam inside,because this >solved my problem,..
>=open toner door
>=remove the toner
>=look carefully IF there's any paper stuck between roller
>=CAUTION - carefully and gently remove the paper if so, as it >will be a nightmare if half tear off and the half end will be more >difficult to remove,...
The only thing I did differently, that worked like a charm, was to =open the door on the other side of the machine, and
=swing down the two green levers (one on each side); this released the roller tension and removal of the paper was easy.
=Once the paper has been gently removed, put back up the two green levers, and
=close everything up, re-installing the toner cartridge as you do.
Nov 16, 2007 | HP LaserJet 3330 All-In-One Printer
Brother 4100e paper jam
Can be tricky people usally damage the fuser rollers removing this jam with pliers/tweezers, it has concertined and stuck after fuser rollers and before exit rollers it will be stuck on the switch best bet is to dismantle properly and remove fuser then dismantle fuser and remove jam, another thing to be concerned about is why did it, three seneraros, Damp paper going threw fuser dries and crincles(use fresh paper from sealed packet), fuser is worn(have fuser replaced), just a bad bit of paper (just have fuser jam removed. Fusrr runs on 240v, covers break easy
Oct 15, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
13 people viewed this question
jasbo
jasbo
