Question about Gaggia Syncrony Compact Digital Espresso Machine
Hi, My Gaggia Synchro displays a Ventilate message, and now none of the buttons work. I.e. I cannot open steam, or enter any menu or click on the coffee button. I had this problem many years a go, and the solution was to open it and do something, but I can't remember what. Any ideas? Thanks, Danny.
  • dannynis Mar 19, 2011
    None of the above solved the problem. I still get the same Ventilate message and nothing can be done with the machine. Only the Escape button works, and send the machine to power saving mode.
    Any additional options?
    Thanks,
    Danny.
  • 10,515 Answers
That usually happens when the steam wand or pump is clogged.
The steam wand must be removed and unclogged.
To start unplug power cord and see if problem persists.
A basic work can be done inserting a paperclip or a long pin inside the steam wand, be careful not to damage the machine doing this.
As an alternative solution you can try while pushing the hot water button, then turning the machine off and removing the water tank
Then fill the plastic pump with water and inserts it into the water intake valve.
After that turn the machine on, open the steam wand and at the same time introduce water into the intake using the plastic pump until the machine is unclogged.
The whole procedure is wuite complicate and must be repeated several times.
More simply , if all the above does not work, you can try pressing the hot water button and opening the steam valve. Leaving the nozzle open until Ventilate message goes away. If the machine is not badly clogged this will solve the problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 17, 2011
Ventilate problem on gaggia titanium coffee
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 27, 2010 | Gaggia Titanium Espresso Machine
Gaggia Syncrony "ventilate"
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 04, 2010 | Gaggia Syncrony Espresso Machine
My gaggia titanium keeps coming up with ventilate in the display have cleaned the whole machine out made no difference
Apr 19, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Ventilate message
Press the hot water button and allow water to flow from the steam arm until ventilate disappears and warming up appears on the display.
Ventilate after descale is normal.
Feb 22, 2010 | Gaggia Titanium Espresso Machine
How to decalcify?
1. place water and descaler solution into tank
2. remove milk frother from arm
3. place a jug under steam arm
4.hold down the button 2nd from the right next to the menu button for a few seconds.
5.descaling machine open steam knob will appear on the display
6. after descale has finished "fill water tank" will appear.
7. refill tank with clean water no descaler
8.press the button 2nd from the right as in step 4
9. rinsing machine will appear.
10. when finished"close knob"will be displayed
11. refill water tank
12. ventilate will appear on the display
13.press the hot water button and allow to run
14.ventilate will disappear,warming should be displayed.
15. job done !!!
Jan 27, 2010 | Gaggia Titanium Espresso Machine
Our machine when turned on and menu is pressed it will show energy saving press again ventilate shows. no action
Hi
When the ventilate message is showing, push the water button is you have one then open the knob on the right with a cup under the steam wand. You should get ewater from the wand. If you don't get water from the wand check for a plug in the steam tip. If you don't have a plug in the steam tip, you may have a plugged flow meter.
Dec 18, 2009 | Gaggia Titanium Espresso Machine
Can't get rid of ventilate message on titanium plus machine
Try this, after opening hot water valve, push the knob in when it asks for ventilate. If that works then contact your nearest gaggia distrubutor and ask for a new stainless steel steam valve assembly.
Jul 04, 2009 | Gaggia Titanium Espresso Machine
Ventilate button does not seem to work
If you open the steam knob, can you get out any water?
Apr 22, 2008 | Gaggia Titanium Espresso Machine
Trying to ventilate and hot water not flushing through on button 26
Before you press water button to vent you need to restore to factory settings.
First press menu (far right button) then toggle to restore factory settings (using far left button), press menu button then far right again until yes comes up, then press menu button. Press esc button (3rd from left), machine should now be back to normal. Then press water button (3rd from right) and turn steam knob to vent until free water is coming through.
This is the only way I could get mine to work!
Dec 30, 2007 | Gaggia Titanium Espresso Machine
Ventilate
I fixed my ventilate problem! After 2 days of utter frustration and pushing many buttons, I read another guest comment about resetting to factory settings. Push the up button under the small coffee icon. It should say factory setting with the asterick next to it. Push OK. Then push "yes" for factory settings. Then my machine started working again! Hallelujah! It erased my personal coffee cup setting, but who cares.
Big thanks to the person who posted their solution on Dec. 2007.
Jun 11, 2007 | Gaggia Titanium Espresso Machine
Gaggia Syncrony Compact Digital Espresso Machine Logo
127 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
