Question about GPS
My tomtom xi xxl showes that it is charging, but after charging for 4 hours it showes the battery is still flat i have tryed to charge it several times ,please can you help. it only 4 months old
    Top Expert:
  • 74,136 Answers
Hello
Your GPS may be new, but it battery has some trouble with it. Some batterys will get damaged before its gurantee period, and it is normal to all all batterys. If you are still in guarantee period, contact the service center for replacement of an other battery. In rare cases, the charger unit iside the GPS also get damaged, as it won't give enough voltage and current to the battery to get full charged. keep it charge for at least 20 hours, and check whether the battery get heated. there may be a slight heat, but not have too much. If overheats, the charger circuit inside the GPS is OK and the battery is bad. If not heat at all, the charger section inside the GPS should be checked. Anyway, you can check the battery only by the above mentioned method. Never attempt to open the device, as the internal circuits are entairly digital and can be get damged by improper service, without previous experience, and knoledge in digital electronics. If the battery is found bad, either replace it by yourself with a better one, which can be bought from electronic spare part shops nearby you, of get it replaced by its authorised service center. OK.
Posted on Mar 17, 2011
  • The Knight
    The Knight Mar 17, 2011
    According to TomTom manual, you can access the service center by the following way. I quote:
    You can use Help me! to find and make contact with a service center.
    If your phone is connected to your TomTom, your TomTom automatically
    dials the phone number.
    To use Help me! to locate a service center, contact the center by phone and
    navigate from your current location to the center, do the following:
    1. Tap the screen to bring up the main menu.
    2. Tap Help me!
    3. Tap Phone for help.
    4. Select the type of service you require, for example, Nearest hospital.
    5. To dial, select a center from the list, the nearest is shown at the top of the
    list.
    Once the call is answered your TomTom shows your position on the map
    along with a description of the location. This helps you explain where you
    are while making a call.
    6. To navigate your way to the center on foot, tap Walk there.
    Your TomTom starts guiding you to your destination
  • The Knight
    The Knight Mar 18, 2011
    About its battery
    This product uses a Lithium-Polymer battery. Do not use it in a humid, wet
    and/or corrosive environment. Do not put, store or leave your product in or
    near a heat source, in a high temperature location, in strong direct sunlight, in
    a microwave oven or in a pressurized container, and do not expose it to
    temperatures over 60 C (140 F). Failure to follow these guidelines may cause
    the Lithium-Polymer battery to leak acid, become hot, explode or ignite and
    cause injury and/or damage. Do not pierce, open or disassemble the battery.
    If the battery leaks and you come into contact with the leaked fluids, rinse
    thoroughly with water and seek medical attention immediately. For safety
    reasons, and to prolong the lifetime of the battery, charging will not occur at
    low (below 0 C/32 F) or high (over 45 C/113 F) temperatures
Tomtom XLL will not hold a charge
I suggest you go to your nearest car electrical expert to check your car if there is problem with your car electrical connections..
Dec 19, 2013 | Tomtom XXL 550 Car GPS Receiver
It shows a green light at the on and of button but does not go on
Hello
In rare cases, your TomTom ONE/XL/XXL navigation device may not start correctly
or may stop responding to your taps.
First, check that the battery is properly charged. To charge the battery, connect
your device to the car charger. It can take up to 2 hours to fully charge the
battery
If this does not solve the problem, you can reset the device. To do this, press
and hold the On/Off button for 15 seconds and release the button when your
device begins to restart.
OK.
Oct 17, 2011 | Tomtom One XL GPS Receiver
After pressing the on/off button nothing is happening,Ionly have the screen Tom Tom nothing else!
First, check that the battery is properly charged. To charge the battery, connect your device to the car charger. It can take up to 2 hours to fully charge the battery.
If this does not solve the problem, you can reset the device. To do this, press and hold the On/Off button for 15 seconds and release the button when your device begins to restart.
Hope this helps.
Feb 28, 2011 | Tomtom XXL 540TM Portable GPS
My new Tom Tom will not start past the first screen that shows the name Tom Tom.....how do I get it to operate properly. If I depress the start button for about 14 seconds it goes to a green screen or...
It is likely that your battery is low or nearly-dead, particularly if you haven't used your GPS for a while and it has not been plugged in (to be kept charged). That's why it doesn't start (even if it is plugged in when you're trying to start it up again now). Don't try to repeat the startup (too often) as it will mess up your sw / data (when your battery is low or half dead) You'll want to plug it in (e.g. using your USB or wall adapter) for up to 24 hours or so, to charge the battery. Then start it up and keep it plugged in until your battery is fully charged.
Feb 13, 2011 | Tomtom XXL 540S GPS Receiver
Tomtom xxl 550tm, when I press address it shuts down.battery is charged?
Try pushing the reset button( you need something like a straightened paper clip)
Dec 30, 2010 | Tomtom One XL GPS Receiver
How do i know my xxl 540s battery charge full?
To know if your tomtom is fully charged. Unplug the tomtom from the power source and you will see the battery meter, if it is full or not, because while it is charging, it is the power source that is working so the battery signal will not come up. Unplug it and you will see the battery meter.
Hope this was able to solve the problem.
Dec 21, 2010 | Tomtom XXL 540S GPS Receiver
Tomtom XXL 540 S Just bought. Can this be charged up in my home? I tried USB to Apple but not sure that this works to charge up?
Yes, use the mini A to Standard USB cable to connect it to a USB port on computer. Leave it to charge for a few hours. This is how to do it on Windows based computer, as to Apple I know not about them. My hunch is that it should not make a difference, but I would not stake my neck on that.
Jan 03, 2010 | Tomtom GPS
IT is a xxl 530 s tomtom. Do you keep the unit
While in drive view, tap the screen on the blue status bar, on the GPS signal strength. A new screen appears showing the battery charge level at the top right corner.
Dec 29, 2009 | Tomtom ONE XL GPS
I have a one xl with no manual or instructions please supply asap. My display goes out after 2minutes andprogressively shortens with continous usage. is the battery low or what please assistregards Ray.
you can download a copy of your manual HERE
from the tomtom website.
your right! your unit is probably powering off from a low battery...tomtom recommends charging it via the usb cable from your computer for atleast 4 hours..
after you charge it up enough that it will start, tap the screen where it shows satellites linked, then in the upper ight corner you can see the battery and if its charging and what percentage af the battery is charged..
its a common problem on these Xl not to charge, but it just might be low on battery.
bill
Oct 14, 2009 | Tomtom One XL GPS Receiver
I charged my tomtom one 125 for 4 hours, but it didn't start at all. I just bought it today. Do I have to charge for longer hours?
hello there subedi! there might be some technical problem in your gadget. try contacting the company from wherein you purchased your tomtom. but there are some gadgets that is required to be charged up to 6 hours. for more inquiry, please keep me in touch.thanks!
Apr 10, 2009 | Tomtom ONE 125 GPS Receiver
GPS Logo
37 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
