Question about Stoves 720EF Electric Double Oven
How to fit oven door seal - Stoves 720EF Electric Double Oven
  • 250 Answers
The handbook tells you how to do it. If you want a copy, supply an email address and I will send you a pdf copy.
Posted on Jun 04, 2011
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: how do i fit new
If the seals have what appears to be hooks at the corners, then unhook the old seals and re hook the new seals into the holes in the front of oven .
If no hooks, then the front of the oven needs to be unfastened.to replace the seals.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
SOURCE: can i purchase a replacement seal for around the
That seal you should be able to order from any appliance spares supplier the Zannussi part number is. 3577252020. cost in euros. € 10.20 + vat.If it is the one I think it is then it is not easy to fit.The screws around the whole front panel have to be slackened off and the front prised forward dont take off fully pull old one off the new one has to be pushed in behind lip then fix all screws.may be easier with door off.
Hope I helped.
Posted on May 07, 2010
Testimonial: "Many thanks for your advice regarding the replacement door seal on my Zanussi oven. It does sound a little complicated to do the replacement, it may proove better to ask if the seal can be fitted by an expert repair man / woman, rather than me/ husband. I shall ask my local appliance shop for a cost price. I thought it may have been a quick D.I.Y. job thaks very much for your assistance "
B1432 door gasket wanted with rounded corners
I believe this is the oven door seal. You can purchase this online from Ransomespares.co.uk product code RS46105 cost £29.25. Easy to fit, each rounded corner has little metal hooks which fit into the pre-drilled hole on the oven itself, simply unhook the old one and replace with the new, simple.
Jun 20, 2011 | Neff B1432 Single circotherm plus Electric...
We have a Hotpoint double oven spec# BD52K and after having the element refitted have notice that the bottom oven door no longer fits flush causing the oven not to seal correctly. is there any way that...
Assuming that the door was not removed for the new element to be fitted, then it sounds to ne as thiugh the oven door hinges are weak.
The only solution is to replace both door hinges,
If the door was removed, then it could possibly be not fitted back correctly.
Jan 28, 2011 | Hotpoint Ovens
Can i purchase a replacement seal for around the
Hope I helped.
Apr 25, 2010 | Zanussi ZBF260 Electric Single Oven
Can I get replacement door for my top oven, and new door seals for Creda Cachet Solarplus Model 48182, serial 60.1.00082
we should be able to help if you contact the office
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Ovens
How to fix iner seal on the oven door
I have a Zanussi ZDF290X which requires a new top oven seal. I have pulled the remainns of the old one out, but without dismantling the oven it seems impossible to fit the new seal. Any easy way of fixing this, please?
Jan 13, 2010 | Zanussi Ovens
How do i fit new door seals for an neff u1421 double oven i have the seals
Thanks.
Jan 14, 2009 | Neff U1421 Double circotherm Electric Oven
Do i ned instructions to fit new door seals i have the parts
See if you can lift the corner of the seal and see if there is a hook of some kind, if there is then all you do is unhook each corner, and remove seal, if no hooks, then it may be one of these tjhat is held in place by the the oven liner, and this is more of a tricky job to do.
Thanks.
Jan 08, 2009 | Neff U1421 Double circotherm Electric Oven
Oven tempture
The solution I am proposing here only applys to electric ovens and not micro wave ovens.
The usual reason for fluctuating oven temperatures is a faulty or out of calibration thermostat.
Some thermostats can be recalibrated, but in my experience, it is better to replace it.
Another reason for fluctuating temperatures is a badly fitting oven door, or a worn or faulty door seal, the door should be a good firm fit agaist the seal.
Thanks.
Jan 04, 2009 | Ovens
New World G90M
Normally they are held on with metal clips at each corner, just pull the seal back and unhook the clips to remove the seal..
Re fit by hooking the clips into the holes in the front of the oven, you will probably have to stretch the seal to get it to fit with it being new.
Plz rate this solution.
Thanks.
Dec 19, 2008 | New World G90m Gas Double Oven
Stoves 720EF Electric Double Oven Logo
87 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
