Question about Skull Candy Agent Headphones
HI THERE MY SON HAS BOUGHT A PAIR OF SKULLCANDY HEADPHONES AND THE PHONO CONNECTION THAT YOU WOULD PUT INTO AN IPOD FOR INSTANCE HAS SNAPPED OFF, IS THERE A SPECIFIC PHONO CONNECTION I NEED TO BUY AND CAN IT JUST BE SOLDERED? ANY HELP ON WIRING THIS WOULD BE MOST APPRECIATED, I HAVE BOUGHT A STANDARD PHONO CONNECTION, IT HAS 2 PINS AND AN OUTER LONGER PIN WHICH I ASSUME WOULD BE USED AS A CABLE GRIP, I HAVE NOTICED THERE IS A BLUE AND A RED STRAND IN EACH INDIVIDUAL WIRE SO WOULD POLARITY BE AN ISSUE HERE? I HAVE CONNECTED THESE EITHER WAY AND NO SOUND. PLEASE HELP :-) THE HEADPHONES I'VE GOT ARE VERY SIMILAR TO THE LOWRIDER S5LWCY-074
Apelord89
SOURCE: how do you fold lowrider headphones?
It's easy,
Step1: rotate the earpeices so that either the cushions face up or down
Step2: fold one side inwards by bending the rotating elboe inwards, this elboe is located one inch above the top of the cushion
Step3: now do the same for the other side
Step4: as you fold/rotate the second earpeice, do so in a way that this earpeice lies underneath or ontop of the first folded earpeice
Note: as you do step 4, you will notice that the middle of the top band starts to bend to accomodate the motion of this folding process
Add. Note: the mic may be sticking out at an odd angle by now, rotate it towards the rest of the mass that is now your folded headphones...... now they are ready for your pocket
Posted on Feb 13, 2009
SOURCE: Jack plug broken off
Buy a $4.00 1/8" jack replacement from Radio Shack - part # 274-0869, which has small screw connectors that don't need soldering.
Strip about 1" of the braided insulation at the old jack end, which will expose 4 very small wires: Blue, Green, Red, Copper.
Attach the Green & Copper wires to the tallest pin on the replacement jack.
Attach the Red to the shortest pin, and the Blue to the medium pin.
Remember to slide the jack cover onto the headphone cord before attaching any wires!
This works great, I just did it.
Posted on Jul 25, 2009
  • 15 Answers
SOURCE: How do I set up my Skullcandy Lowrider head set
if you go on there site you have got to change some settings on x box live. here is the link. http://www.skullcandy.com/manuals-and-drivers.html it is the x box settings for lowriders.
Posted on Aug 10, 2009
SOURCE: Lowrider 360 Skullcandy Headphones don't seem to work on my xbox.
Yeah, I had this same issue, the solution is to go too Settings/System Settings/Console Settings/Audio/Digital Output and select Dolby Digital with WMA Pro.
Also change your Prefrences/Voice to Play through both and crank the volume to 10.
Posted on Sep 26, 2009
  • 5 Answers
SOURCE: My skullcandy lowrider left headphone won't work on my iPod touch
Try messing with the plug a little. Otherwise the wires somewhere might be messed up. That happened to a pair of my earphones, some of the wires at the plug broke so I wasn't getting sound out of the left side.
Posted on Oct 29, 2009
My Skullcandy Hesh headphones have messed up sound with my ipod
I would say that if they work fine with other devices then your input jack on your ipod is bad. First I would plug other headphones into your Ipod and see if the problem persists. If not the case then I would plug in your headphones into a known working device and wiggle the wire at the connection point to see if you can duplicate the problem. If this does happen then you need to replace the connector (1/8th inch stereo male plug) on your headphones.
Oct 22, 2012 | Skullcandy Hesh Overear Headphone...
Headphone Repair
The cable that is used in the headphones is actually very low quality and very weak so easily broken, You may be able to remove the wiring from another pair of headphones and use it.
Unfortunately Skullcandy are not a high end brand so no spare parts are really available as they are made in china as you can see on the following link.
Link:
Mar 02, 2012 | Skull Candy Lowrider Headphones
How do I connect my ipod/iphone to my technics hi fi/stereo? What cables do I need? Susan
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except one labeled "PHONO"). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT one labeled "Phono".
Jul 14, 2011 | Audio Players & Recorders
Apple ipod do not play music in head phone
Your Headphones may be broken. Apple headphones usually wear down over time and eventually break. I would recommend purchasing skullcandy headphones or even Beats headphones depending on your style and budget. http://www.skullcandy.com/ http://www.beatsbydre.com/
Jan 12, 2011 | Apple iPod shuffle MP3 Player
I cant connect the headphones to my PC or my iPod
wireless is not all its cracked up to be. youd be better off with a pair of skullcandies
May 11, 2010 | Sennheiser HDR 130 Consumer Headphones
I have the exact same problem
happened to me first time i bought them, but the ear was extended more so the break happened higher up on the extendor thing. I just taped it, and stuck it into the hole to stabalize it. About 3/4 of the life of my first skullcandys were spend broken. Then, somebody stole my backpack, took nothing out of it, and threw my skullcandys in the trash.
I sent in for a new pair, they've not broken for a much longer time but today, they have broken again. Because the break is much lower, the earpeice isnt held to my head and just dangles. Duct tape wont fix it so i'm gonna try hot glue. If that fails, i might sauter it.
Jul 15, 2009 | Skull Candy Hesh Stereo DJ Headphones -...
Cracked green piece that holds earpiece on skullcandy headpones
This you can warranty. they will give you 1/2 off on a new pair but at least you can get that.
Dec 19, 2008 | Skull Candy (NNTN5751) Headset
My son dropped his skullcandy headphones and cracked the green piece that holds the ear piece... anyway to replace that?
I dont think that they have replacement parts but they will give you 50% off you next pair if you warranty them. http://www.skullcandy.com/warranty-information.html
Only One Ear Works!?!?!?
get on there site and warranty them. they will replace them for you. www.skullcandy.com/warranty
Jul 08, 2008 | Skull Candy Ink'd Stereo Ear Bud...
Skull Candy Agent Headphones Logo
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Joe Lamb
Joe Lamb
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
