Question about Mitsubishi Televison & Video
I have a Mitsubishi 65 inch CRT big screen. When I turn it on, it shuts itself back off again. I have tried unplugging it and plugging back in to no avail. Any suggestions.
  • 813 Answers
Reset to the factroy setting & try to on your tv if problem come u need to go with a professnol tv repaire
Posted on Aug 02, 2008
  • 790 Answers
Hi
this is the power oscillation problem! this unit have abnormal parts!
Thanks!
  • carlos fernandez Jr.
    carlos fernandez Jr. Aug 02, 2008
    please give the brand and model!
    Thanks!
  • 1,183 Answers
The power supply is cause of the problem. Donot switch on the TV again and again as it could furthur damage the motherboard. If you are not comfortable repairing or opening electrical components its time to take to TV repair mechanic
Thanks
proton
    Guru:
  • 1,894 Answers
This may be due to some heating problem in your power board
and hence please have a check for bad components.
63 inch flat screen
Kay, the problem is not A DIY and certainly not cheap to fix. If under warranty of any kind claim it. If you recently had a storm and also have home insurance claim repair under FUSION You need to have repair person use the words Fusion on the bill to get paid/
The popping was capacitors on the y and x sustain boards and even the power board. Sustain boards are about $200 each and power board about $170 all up close to $900 for the repair. But get some quotes and try and find Mitsubishi specialist repair people as they will work faster and have the right parts in stock.
Please rate my help++++Thanks for using FIXYA
Jun 01, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I HAVE A MITSUBISHI 65 INCH MODEL WS-65411 AND HAS A CODE 23
This error code shows that you have a Horizontal failure occurring. It could be a intermittent solder connection on one or more of the yoke connectors. That is the most common issue with shut down due to Loss of Horizontal Deflection. If you are handy with a soldering Iron and confident in general TV knowledge, you can repair this. If not , do not attempted it. Call a Professional. If confident, unplug the set from power, remove the speaker Grills from the front. Then remove the Center Piece of the front panel. You should have access to the front plate. Remove the 6 screws holding in on and place it aside. If you look at the neck of the left CRT', you will see a 4 pin Plug Connector that goes from the High Voltage Board up to the Yoke . You will need to use a flash light and check the solder connection under that yoke plug. Most of the time it will look like it has been arching. Resolder each of the pins. then move to the center CRT and do the same. After that, repeat it again on the CRT to the right. Make sure that each of the pins you solder are not shorted or have Solder Splashes between the pins. Plug in the set and turn on. Hopefully you will not have the problem again. Reinstall the Front Panel Access plate, Center Piece and Speaker Grills.
Hope it does the job,
Sky Assoc
Feb 22, 2010 | Mitsubishi WS-65411 65" Rear Projection...
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Feb 17, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
Aug 03, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
I bought A 65" Mits and had it two days approx. 2hrs. of run time
check the lamp. it sounds like it failed. you will probably see the broken glass inside the lamp housing
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Yes my nickname is cztop i have a mitsubishi big screen tv & need guns ajusted
try unplugging tv for 30 minutes remove all speaker away from tv and anything magnetic after 30 mins turn back on try that
Aug 23, 2008 | Mitsubishi WS-65809 65" Rear Projection...
TV shuts itself off
Mine does the same thing , too. I turn it on and off repeatedly , but nothing happens.I unplug it to see if it resets and nothing still .
Aug 02, 2008 | Mitsubishi WS-65908 TV
Mitsubishi 65 inch Diamond rear projection
Sounds like your control unit has going down. its the big silver box in the rear to the left of the set.
Oct 28, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Televison & Video Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
