Question about Minolta magicolor 2350 Laser Printer
Hello My boyfriend has a Konica Minolta Magicolor 2350 printer. I just replaced opc drum for him. When he switched it on after this he says there was a bang and then the message Service call 08. He switched it off and then on again. There was another bang and the message: Service Call 14 XFER ROLLER. Any advice you can give would be very much appreciated. Regards Amanda
  • 111 Answers
Hi Amanda,
Wow your so sweet to your Boyfriend, anyway try to check on this manual im very sure that something is misalligned on the drum.
http://www.inkcloners.com/Service-Manuals/MagicColor-2300-manual.pdf
Hope this gives you guys an idea..
Cheer up and dont forget your THumbs Up...
Thanks!
Posted on Mar 17, 2011
  • amanda994 Mar 18, 2011
    You were right - it wasn't clicked in properly. The manual will be very useful.
    Thanks!
  • 3 Answers
Srevive Call X14 transfer roller has nothign to do with the transfer BELT. It is to do with the foam roller in the drop down unit which contains the m ultipurpose paper feed.
the problem was diving me nits as it turned up on 3 printers I look after!
The solution is not too difficult. Firt a quick note of the problem
(or you can skip this and go direct to solution). The foam roller is part of the paper feed and is controlled by a platic clutch. This is actiovated by a solenoid - an elevtromagnet switch with a handled. The hooked end stops and starts the clutch depending on the arm beign in the rest or pull down position. QMS in theirt wisom put a small piece of foam rubber to dampem the arm. problem is the foam is such poor qaulity it rots leaving the double sided sticky tape on the arm and the rest position. When the arm is activated it then gets stuck on the rest position instead of jumping back when the solenoid is switched off. Result instead of workign the clutch to control the roller correctly, the roller goes into the wrong position and up comes the error message.
SOLUTION: Clean the glue on the solenoid arm and replace the rotted tiny piece of foam rubber.
WHERE IS IT? There are in ibfact 2 solenoids both of which are located under the black plastic cover on the right hand side of the drop down paper feed mechanism.
how to do it Open the drop down paper mechanisim us the push up switch on top left hand side. Look for the black cover on the right hand side. There is one screw that holds it in. Remove this and carefull prise out the plastic cover.
You will see the 2 solenopids. Unscrew in turn. Note how they are fitted in. One goes the opposite way to the other. Note the absence of black foam between arm and rest pad! Clean the gook of glue of both sides. I have tried it without replacing the foam but ity might be best to put a thin pad in there. A durable piece of foam or even thin leather would do the trick. Do this on both solenoids. Use super glue or good wuality other glue. Screw both solenopids back in. The lower one is a little tricky and must be located correctly.. Check that when the arm is in teh activated positing (i.e. pulled away from teh white clutch) that it clears the hunp bits. Turn the gears to check this. replace the black pastic cover. This is a little trick, be careful. Start by locating the far end that fits round the wire loom. The back end has a lug that fits behind the medal bit (I\'ll try to post some pictures soon) It needs a bit of bending to get it in tyhere. Also make sure the 3 plastic lugs fit in correctly behind the metal bit.
Make sure it is all fitting in snugly and straight then rplace fixing screw.
GENTLY push the whole mechanism back and ensure there is there is nothing catching. Its easy for the black plastic cover to not be seated correctly and if you force the paper mechjanism back in it will jam so gently check it in place. If it doewsn;t seem right pull back out and re-seat the plastic cover. the back lug can often be put in teh V shaped metal bit by mistake. it MUST go behind the metal bit NOT in the V shape bit of metal. (you will see hat I mean when you do this job!) Once setated correctly and paper mechanism push and locked correctlky in place it shoudl solve this pesky X14 problem.
I\'ll try to post pictures soon but any questions feel free to post
Posted on Jul 07, 2014
Konica minolta magicolor 2350dl drum replacement
Was the new one new? Check the medal connectors located on the image unit anything medal and clean with alcohol and all connectors on the assy. the image unit goes in reseat properly Third party do not work use OEM
Apr 11, 2012 | Minolta magicolor 2350 Laser Printer
Do you know the service password for a konica minolta magicolor 2350
hi........
Konica minolta magicolor 2350 service password is not available.......
pls contact to the customer care..........
thank you.............
Jul 23, 2011 | Minolta magicolor 2350 Laser Printer
Konica minolta 2530 dl Replaced black cartridge now says others not installed and "cannot rotate cartridges"
Clean toner chip reader, remove OPC drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it.
Jul 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
I've replaced all neccesary ink colors and now my 2530DL Konica Minolta wants me to replace my Drum Cartridge... I don't know what that is or how to do it!
Open the Front Cover and remove the OPC drum cartridge by pulling up from the green lever. I'm sure you'll find all these instructions on the box the new drum is comming.
May 14, 2009 | Konica Minolta Magicolor 2530 DL Laser...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Konica minolta opc drum magicolor 2350 printing problems I have replaced the opc drum on magicolor 2350 and also the black (k) ink cartridge and now can only really print in yellow, sometimes the other...
When you print stop the printer half way through then check the image on the opc drum and transfer belt to see if it's complete or not, also you may want to check the aidc sensor (sometimes the cable comes loose). I can e mail you the 2300 series service manual (4.17mb) if you reply with your e mail address
Jun 15, 2008 | Minolta Office Equipment & Supplies
Magicolour 2350
Try updating the drivers for the printer from the manufacturers web site. I doubt the issue is related to the printer itself, otherwise it would fail to print magenta all the time.
Jul 25, 2007 | Minolta magicolor 2350 Laser Printer
Minolta magicolor 2350 Laser Printer Logo
362 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
