Question about Philips Televison & Video
Hi, I have a Philips 24PW6006/05 flat widescreen tv that when you first switch it on from standby, it switches back to standby after a couple of seconds, then attempts to switch on again and then switches back to standby. After several attempts at switching the TV on, with the same response, it will eventually switch on properly. Any chance someone might know where I need to look to isolate the problem - seems like a warming up issue to do with the switching relay? Regards, Eugene.
  • 7 more comments
  • eugene913 Apr 07, 2011
    Hi, I have a pdf of the circuit diagram for the main board of this TV. If you could suggest which Capacitors to check, it would be easier for me to check them?
    Regards,
    Eugene.
    Thank you.
  • eugene913 Apr 08, 2011
    C2561 is actually a 100mF cap on the board, but I can only get hold of 47mF capacitors at this voltage. Would this cause a problem if I use a 47mF cap?
    And C2566 is not present on the actual board.
    None of the capacitors look leaky, but I am going to replace them. I was just asking whether capacitor C2561 (shown as 47mF on circuit diagram but actually 100mF on circuit board) can be replaced with 47 mF(as on circuit diagram)? The capacitor C2566 is not connected on my circuit board(doesn't exist).
    Regards, Eugene.
  • eugene913 Apr 19, 2011
    Have now replaced all the capacitors you suggested, but problem still remains. Any other ideas?
    I have replaced caps no 1, 2, 3, 4 and 6, plus the largest cap on the board C2503 (220mf 400V).
    Thank you.
  • eugene913 May 11, 2011
    Hi jdvillanueva, I'm sorry I haven't got back to you before now but I couldn't get one of the caps till now. Replaced both and still the same. Any other suggestions please?
  • Philips Master
  • 2,098 Answers
Hi Eugene,
This symptom was caused by leaky/dried filter electrolytic capacitor in the output of power supply section. This capacitor will produced an out-of-regulation in the supply. It needs a warm-up to make itself stable but the symptom will get worst which will not power up or disable the power supply. Leaky capacitor has a dome/bulged at the top and easy to recognize but dried capacitor has no physical indication of fault. You must have a capacitor checker to determine its condition and pinpoint where the faulty one. If capacitor checker is not available, you may replaced all the electrolytic capacitor in the output stage of that board. The affected working voltage are 10v,16v,25v,35v if you see the capacitor with this working voltage replaced them all and your unit will back to normal again. This will not cost you much, because it is cheaper than other parts($4 at the most). Here is the sample of leaky capacitor.
Hi, I have a Philips 24PW6006/05 flat widescreen - jdvillanueva_12.jpg
Here's the link for parts replacement.
LINK1 LINK2
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 07, 2011
  • 6 more comments
  • Jdvillanueva
    Jdvillanueva Apr 07, 2011
    sure, you may upload the pdf file in this link then give me the link also.
  • Jdvillanueva
    ok bro I'll check it...
  • Jdvillanueva
    check this capacitor first...
    1. C2521 (22mf) - small electrolytic capacitor near the primary winding of chopper transformer.
    2. C2561 (47mf) - like my sample picture. Secondary side of chopper transformer.
    3. C2450 (47mf) - duplicate of C2561 near the flyback transformer.
    4. C2564 (2200mf) - secondary side of chopper transformer
    5. C2566 (47mf) - secondary side of chopper transformer
    6. C2568 (0.47mf) - secondary side of chopper transformer
    Concentrate first on the first three capacitor. You may pull-out with the same mf rating and compare the reading if you don't have a spare good capacitor. Check first if there an stored voltages before you touch the capacitor most especially with those high working voltage like the 160v capacitor which is C2561 and C2450.
  • Jdvillanueva
    Jdvillanueva Apr 08, 2011
    Sorry I can't understand what you are trying to explain...
    If you are going to replaced this cap, make sure it's same rating, 100mf must be 100mf replacement also....
  • Jdvillanueva
    No don't replaced the 100mf with 47mf, it will have an effect on the sudden change of bright picture to dim picture. Don't follow the schematic, most of the time it has an error in some rating versus the actual.... replaced all I've mentioned cap, also check the main filter cap(largest cap).
  • Jdvillanueva
    Jdvillanueva Apr 19, 2011
    do you replaced all 5 caps?
  • Jdvillanueva
    I'll check the schematic tomorrow, i have a problem in my internet connection this time... its already late in the evening here...
  • Jdvillanueva
    Jdvillanueva Apr 20, 2011
    it seems that we haven't got the faulty capacitor in our first attempt, be patient bro, lets try a second time...
    replaced this cap...
    2567, 2580, 2581,
    2846(100uf) - near the rectangular IC
    2340 - at the crt neck board...
    Let me know what will happen...
    Goodluck bro...
Why is the standby light blinking steadfast on a philips TV but screen does not switch on?
When you can't get it to play, after you did switch it off and on with the switch on the TV, I'm afraid the set is defect.
With some electronic skills, you could try to solder the points on the HT transformer, when they look not o.k.
Feb 16, 2015 | Philips Televison & Video
Where can we get an on/off switch for philips flat scren tv model 32PF3320
The power button for the "Philips widescreen flat TV 32PF3320" if located, if you are facing the screen, on the Left-Hand Side Edge of the television.
Feb 28, 2011 | Philips Televison & Video
When i switch my tv on it turn's itself to standby, i can switch it back on again but it just keep's switching itself to stanby after a couple of minutes.
You need a live input source to the port that the TV is set to, or turn on the tv and switch input to a live input source, anything else and the tv shifts to standby.
Oct 13, 2010 | Televison & Video
Permantly on standby mode
maybe your tv have problem with power supplies and need check expert in electronic, because the problem is programing and replace component electronic, any solution by you tv problem is reconfigurations of the electronic program..... this is the job of a expert electronic
Mar 07, 2010 | Philips Televison & Video
Philips TV 29pt3425 after a while switches off to standby mode but no red standby light is on. It can be switch on using remote by switches off again in a 2 seconds
Ur power supply board,have burn capacitors,check for puff up caps,know how to solder?If not,no puff up caps,change the whole power supply board it somethings burning not notice, able to see in the power supply board.
Oct 26, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
My philips 42 inch plasma model # 42PF9966/37 wont turn on. Red standby light is not on
Hi. Try, in back yours tv on left side of the power corde connector have on hole, inside of this hole have one main switch, using one insulated stick and sheck if this switch is off ( may be not ) but try. If you heva esperience take out the back cover and check the fuse on power board. Good lock
Jan 03, 2009 | Philips 42FD9932 42 in. Plasma Television
Televison & Video Logo
244 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
