Question about E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply
Power Supply Emachine T5026. The fan runs nonstop, no power to the keyboard, the monitor just flashes the monitor menu a few times and goes dark. I replaced the power supply and nothing has changed. The computer is on, the fan is running , but the keyboard is dead and monitor is dark except for the monitor menu which flashes several times and goes dark.
  • 753 Answers
Check all power cables plugged into M/board if these are correct
remove all hard ware
hard drives / cd player and anything else
except for video and memory and test to see if it boots. If it does, one of the removed hardware is faulty if it does not then you have M/board failure
Posted on Aug 08, 2008
Have a T5026. There was a problem with the power supply. Had to hold the power button while booting up, lights would flash and machine makes a strange noise. I have replaced the power supply which fixed...
Make sure that you have the monitor plugged into your video card if you have one (usually a horizontal port), and not your motherboard(usually a vertical port).
If it's not a plug issue, then if you press F8 repeatedly while the computer is starting, Windows will give you a boot menu, select the option "Enable VGA Mode" and windows will revert the resolution to a more common one, and will allow you to reset the resolution to one that your video processor can handle.
Mar 03, 2011 | E-Machines Emachine T5026 power supply **...
Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply: my cpu fan is running but at a low speed. When i t...
In my opinion you have a faulty power supply, replacing only the fan may not solve your problem. Try replacing the power supply.
May 16, 2010 | E-Machines Emachine T5026 power supply **...
I have an emachine t5026 that won't turn on. It
There can be two problems with your PC. either the power supply is faulty which is highly probable, and the other is that your Motherboard maybe faulty or both things are faulty. Try replacing the Power supply first. It should solve your problem.
May 15, 2010 | E-Machines Emachine T5026 power supply **...
Emachine wont start
I just had the same problem. Try replacing the battery on the motherboard, that seems to have fixed mine. The number on the battery is CR 2032.
May 11, 2010 | E-Machines Emachine T5026 power supply **...
When I turn on my machine, I get 3 beeps and my monitor tell me no signal, the model is a T5026 emachine, please email me any suggestions
First use the following steps:
Turn off the system and disconnect power cables
Press and hold the power button for 10-15 seconds.
Reconnect power cables and try to turn it on.
If it remains same, the next step will be to:
Open the case and re-seat memory modules
If you have more than one modules installed, try to test the system with a single module at a time.
Mar 12, 2010 | E-Machines Emachine T5026 power supply **...
I have a T3626 emachine that I replaced the drive.
check all your ground screws on the motherboard. If that doesn't work try booting it up with out the hard drive. if that doesn't work, pop out the BIOS battery and unplug your computer, let it sit for about a min. and put the battery back in and restart.
Sep 18, 2009 | E-Machines Emachine T5026 power supply **...
Emachine shuts off when Windows starts to load
what os are you running? if xp try booting to repair console and run "fixboot" and or "fixmbr".
Jul 15, 2009 | E-Machines Emachine T5026 power supply **...
EMachine T5026 no boot
This just happened to my t5026. I had to replace the power supply to fix.
Mar 08, 2009 | E-Machines Emachine T5026 power supply **...
E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply Logo
145 people viewed this question
Top E-Machines Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
