Question about Toshiba Computers & Internet
Hi, My Toshiba Satellite L555 10M notebook is having severe performance problem. The cpu temperature gets too high very quickly and finally it switches off.. I want to clean my cleaning system but dont know how. Can u provide some instructions how to do this? Is there any driver update for my fan, because it seems to me that it runs seldomly on 100%? regards Mat
    President:
  • 1,961 Answers
Hello sir!
there is no driver update for the fan.
the blower is faulty. the fan may need cleaning or replacement.
Posted on Mar 17, 2011
My computer shuts down while im playing a game
This laptop was not designed to be a games machine, so the stress on the CPU will be quite high, generating a lot of heat. If the fan is unable to dissipate the heat from the cpu, but more importantly from the graphics chip, the laptop will shut down to stop damage.
What I suggest is that you open up the laptop and clean the area around the heatsink and fan and inlet grille, even a mild build up of dust and fluff will cause the temperature of the laptop to rise 10 or more degrees. Eventually overheating will cause the graphics chip to unsolder.
This link is a good guide
http://www.paulstravelpictures.com/Toshiba-Satellite-A105-Laptop-Overheating-Dust-Removal-Guide/index.html
Jul 18, 2011 | Toshiba Satellite A105-S4384 Notebook
Seems my toshiba satellite lap-top is over heating, how do I get to the fan to clean it? Model number: psafgu-02k001 serial; x7253530q
If your fan is running OK, then it probably doesn't need cleaning.
I have a satellite A350 and it pumps out a LOT of heat but that doesn't mean it's overheating. It's more likely your CPU usage is very high, which makes it very hot.
Turn on the CPU Meter in the Windows sidebar and close all applications. Watch the CPU usage (the larger front meter) for about 20-30 seconds. If the AVERAGE level when running no other applications is over 40% or spiking up at 90 or 100% then you are probably running too much junk in the background, or you have a virus.
Oct 14, 2010 | Toshiba Satellite A215-S5837 Notebook
My Toshiba satellite pro M10 very slow.
check your system performance thru task manager. check for CPU usage. usually COU usage is 1% to 10%. if your CPU usage would peak from 10% to 100% there is a huge possibility that there is program running on your computer that eats up your memory. Or it could be spyware/malware
Mar 27, 2010 | Toshiba Satellite Pro M10-S405 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
I ahve a toshiba A100. It frequently freezers for
This can be due to malfunction of an application (virus/trojan horse), ensure cpu, memory utilization is not too high, check whether the cpu is overheated, try freeing up memory by unloading unwanted processes
Oct 08, 2009 | Toshiba Satellite A100-S8111TD Notebook
A problem with the cooling system is detected. Satellite A25-S207
The sensor that reports the cpu temperature could be faulty or could be fan loose from cpu or faulty motherboard .
Aug 02, 2009 | Toshiba Satellite A25-S207 Notebook
CPU upgrade for Satellite 5205-S505
You would only get a marginal performance increase. If your laptop has 256Mb of RAM, increasing the RAM up to 1Gb (this model laptop cannot support more than 1Gb RAM) would boost the performance of the laptop.
Jun 20, 2009 | Toshiba Satelite 5205-S505 Notebook
HP dv5 heating up
if hp dont have solution for that my advice is buy a laptop cooler or call HP to replace your computer, i was looking for the reviews and there are no negative reviews and hardware heating
Mar 20, 2009 | HP Pavilion dv5-1140us Notebook PC
Toshiba Satellite A100 LE4000 Turns Off Randomly
there must be still a problem with your current cooling system. try cleaning up your laptops fan. cpu gets heated up very easily even if you turned it off for a while. you can do this by unscrewing the parts, the inside must be pretty dusty or something. this also happened to me but from a different unit.
also, try checking for the latest bios driver for your laptop and to be sure, download it on toshiba site itself. because latest drivers for your bios also manages the control of your cpu fans.
if you could also get access to your systems cooling options in bios, try checking if your cpu's temperature are doing fine.
but i prefer you cleaning up the inside fans as well. hope this helps.
Feb 07, 2009 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
