Question about HP LaserJet 5550 Printer
Trying to print a document error 49.4CO2 comes up. What does this mean?
  • 51 Answers
Hi as you will see I have cut this from the manual its not very specific
I hope this is of some help
Ian
Description Recommended action
49.XXXX
PRINTER ERROR
To continue
turn off then on
None A critical firmware error has
occurred that caused the
processor on the formatter to
abort operation. This type of error
can be caused by invalid print
commands, corrupt data, or invalid
operations. In some cases,
electrical noise in the cable can
corrupt data during transmission
to the printer. Other causes
include poor quality parallel
cables, poor connections, or homegrown
applications. On rare
occasions, the formatter is at fault,
which is usually indicated by a
79 Service Error.
1. Press CANCEL JOB to clear the
print job from the printer
memory.
2. Turn the printer off and then
back on.
3. Try printing a job from a
different software application.
If the job prints, go back to
the first application and try
printing a different file. If the
message appears only with a
certain software application or
print job, contact the software
vendor for assistance.
4. If the message persists with
different software applications
and print jobs, disconnect all
cables to the printer that
connect it to the network or
PC.
5. Turn the printer off.
6. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
7. Remove all EIO devices from
the printer.
8. Turn the printer on.
9. If the error no longer exists,
install each DIMM and EIO
device one at a time, making
sure to turn the printer off and
back on as you install each
device.
10. Replace a DIMM or EIO
device if you determine that it
causes the error.
11. Remember to reconnect all
cables that connect the
printer to the network or
computer.
12. If the error persists, replace
the firmware DIMM.
13. Replace the formatter and
calibrate the printer. See
Calibrate now (HP Color
LaserJet 5500 models only).
Posted on Mar 17, 2011
Im trying to print important documents, when i print its says error printing, yet i was able to print the test page and align my carterigdes , what is going on?, thank you my kind sir
un install and re innstall the disk with the app, and drivers for your operating system. test page just comes from the printer, it's not seeing the document
Sep 01, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
Error code 024-747 is given when trying to print a specific Word 2010 document although any other Word 2010 document seems to print without any problems. Can you tell me what this error message means and...
In my case was like when i tried to print MS Word or Excel document (Xerox WC 5020 & WC 7120) i had to set "Original document size" in Paper Type option as same as "Output document size" in Printing preferences - it should help.
Jul 22, 2011 | Xerox DocuPrint C4350 Laser Printer
Please help! I keep getting an error code: 0 x 80004005 when trying to open a document. What does it mean? Thanks
It means that the operation (opening the document) failed for unspecified reasons. These errors are quite common, and can be caused from any number of things.
To assist you further, I require the following information:
What program you are trying to use to open the document?
What version of Windows you are running (Windows XP, Vista, or 7)? Does the error come up when you try to open other documents?
Mar 28, 2011 | Computers & Internet
What does the message "ecm" mean when trying to
Error correction mode error
Take a look at this article on the HP website: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01747846&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
You may find similar instructions for your fax on that site as well.
Jan 14, 2011 | HP 1040 Plain Paper Inkjet Fax
There is a little green light that is flashing when I try and print certain documents.. Is this the error warning? Also it is telling me to replace my photoconductor, would this be the reason it is not...
The flashing green light means that the machine is receiving the print data that you are sending when trying to print. Depending on how the dealer set up the machine, yes it will shut down and stop printing when the "replace photconductor" indicator comes on. You will either need to order a replacement unit or have a local service guy come out and reset the counters. If you order your own unit, it will come with installation instructions and they are designed to be end user replaceable.
Good Luck and Thank You for using Fixya
WheatlandServices
Nov 18, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
I'm printing on my HP LaserJet CP3505. Documents are being printed from Print Shop Deluxe. When my document prints it leaves out one graphic on the page and following the printed document a page prints...
this error means that the image doesnt meet the specifications of the program you're using. which is really strange....you can try to reinstall the program, but make sure you remove it completely first. reinstall the program and make sure you have updated the software (if you can) update your printer software and dirvers as well. if the issue continues, them you'll have to find another software to use for what you're trying to do, because thats more than likely where the problem lies.
Sep 24, 2009 | HP LaserJet CP3505n Printer
I have an HP Color LaserJet 3800 printer. I am trying to print a document and it keeps printing: PCL XL error Subsystem: GEDI Error: MemA L LocError Operator: ReadImage Position: 743
That means that the printer does not have sufficient memory tp [rint the document, if it is a text document (eg word) try to print pages in groups, if it is a different document try the following:
" I receive a 'PCL XL error' on my HP 4100mfp when making a 2 page copy as one page in duplex? Why?
The problem is related to a printer memory problem.
If following parameters are set in the HP 4100mfp you will receive and 'Insufficient Memory" error.
1) In 'COPYING' the 'IMAGE QUALITY' is set to 'BEST'
2) In 'ORIGINALS' the 'CONTENT' is set to 'PHOTO'
Following error message is printed:
PCL XL error
Subsystem: GEDI
Error: InsufficientMemory
Operator: EndSession
Position: 32
The solution is to set 'CONTENT' to 'MIXED' or 'TEXT' or set 'IMAGE QUALITY' to 'NORMAL' or you can add additional memory to the HP 4100mfp. "
from euroform.com - FAQ
Dec 22, 2008 | Office Equipment & Supplies
HP LaserJet 5550 Printer Logo
328 people viewed this question
Seeker5211
Seeker5211
