Question about Westinghouse Refrigerators
Hey My westinghouse mastermind bj425 is leaking from the front left side of fridge. It is level, all seals are ok, need to know what the low down is. Mik
    Genius:
  • 1,157 Answers
Hi miccy73,
Seems like you're experiencing water on floor outside the refrigerator. Leaking issue sometimes caused by the drain pan. There are some ways on how to correct this issue, either you clean the pan or just reposition the tray. Here are some steps that you can apply to solve this problem.
Before conducting any repair, please remember your safety. Unplug the machine or shut off the power at the breaker panel to avoid any electric shock.
1. Remove the drain pan and clean it with a warm soapy water or water and baking soda.
--> the drain pan is located at the bottom of the refrigerator behind the front grill.
--> Please remove the grill which snaps into place. Hold the drain pan while pulling slightly upward and forward.
2. If you noticed that the pan is too closed to the compressor please reposition the tray.
3. You may also try to check water invelt valve. It is located behind the refrigerator. Look for a water supply line coming into the valve and turn it off at the source. Now disconnect the supply line. It has screws so you need to remove them.
4. The water inlet valve is connected by two wires. Before disconnecting the wires please label the wire placement on the water inlet valve.
5. The wires are connected to the terminal with slip on connectors. Firmly pull the connectors off of the terminals ( don't pull on the wire ). You can use a pair of needle-nose pliers to remove the connectors. Please check if the connectors and terminals has corrosion. If corroded they should be replaced.
--> if you still have a leaking issue after following the above procedures please try to check drain (second option). Please follow these instructions.
Your refrigerator has a drain that leads to the exterior drain pan, it is located beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. Here are some steps you can use to unclog the drain.
1. First look for the drain. The drain is located either on the floor of the refrigerator, in the wall behind a drain funnel or beneath the vegetable crisper.
2. Now clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe.
3. If solution wont flow through, you need to slide a length of 1/4 inch or smaller flexible tubing into the drain tube to push the clog through the drain pan.
4. Remove the tubing after clearing the clog.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 17, 2011
M y Westinghouse mastermind fridge/freezer just runs and runs , it is cold but hardly ever cuts out
Hay Paul ,
1) Are the door gaskets torn ?
2) Is the fridge empty , in order for the unit to cycle it must replace warm air with cold air .
GOOD LUCK
APPLIANCES R'EN
Dec 11, 2013 | Washing Machines
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
The freezer door opens if the refrigerator door is closed hard
this is quite normal on a lot of fridges ! if it isnt closing again by its self you need to re-level the fridge and have it very slightly backwards . alternatively the fridge is not level side to side !. open the main door a third to halfway open and let it go, it should close under its own weight, if not adjust up on the hinged side leg or down on the opposite side , if the front legs are not not adjustable pull it out and adjust the back legs , a quick fix, is to chock up the front leg and all will be ok ,regards terry ps, clean the seals and the fridge where the seals make contact the seals probably do not need replacing unless the fridge is very very old. a lot of people replace seals when its not needed. regs terry
May 17, 2011 | Frigidaire Refrigerators
We have this model westinghouse fridge which currently opens to the right but are moving house and the fridge needs to open to the left. I can see holes on the left side with white plugs in them so it...
Yes depending on age. once changed doors never seal properly. because cabinet warps and seals flatten on one side. suggest to sell and buy another. you will never be happy if converted.
Aug 30, 2010 | Refrigerators
How do i adjust the level on a westinghouse frost free 422 fridge the right side is higher than the left and won't fit in the space properly
ans / you can adjust the front both l & R / but the back / if floor is not level you will have to use shims . to raise . then adjust front . most important is the door's must have a good balance to each other . or the seal may not be proper ..
Jan 16, 2010 | Refrigerators
Fridge leaking oil on the bottom right side
OK, usually if you see an oily substance that you are sure is not from the fridge contents it's oil from the sealed system. When a leak in the sealed system happens the refrigerant gas leaks out and the lubricating oil also leaks out. I'm afraid you may be in this situation. As the refrigerant leaks out the cooling efficientcy drops off quickly and eventually there is no cooling at all. You would have to use a refrigerant leak detector "sniffer" to locate the leak and then have a certified company repair the unit. Sadly, the cost to do a compressor replacement and leak repair is 2/3's or more the cost of a new fridge...
Jan 15, 2007 | Frigidaire GLRS237ZA Side by Side...
Refrigerators Logo
160 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
