Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer (LTF600ES1) Error E20
Can someone please tell me what error E20 means and how to fix it? It comes up within 10 minutes of the wash cycle. I removed all the clothes from the machine and pressed start. It tries to drain water and will not go past this cycle. If I set the washer to spin only it will drain and spin in that setting, but not when washing. Thanks in advance for any help. Washer will start alarming like the cycle is done, but when I look at the display it reads, E20 and the door won't unlock. I have to unplug the machine and try to fool it into starting another load, then pause/canceling it. I noticed that the fabric softener is still in the compartment. How can I get it up and running again. If something is clogged, how can I get to it? They are stacked with the dryer on top, so it would be extremely difficult getting to it- do not have any help around to move both the machines. I want to get caught up on laundry. HELP!
  • stephgeiser Aug 02, 2008
    How do I get to the drain hose?
  • 876 Answers
Your washer is not draining properly. You need to check if the drain hose is kinked and also whether the household drain is running smoothly.
Posted on Aug 02, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 02, 2008
    You are going to need some extra muscle and a moving cart to pull the stack out from the wall and you will have to be very careful. You will need to use a strap to wrap around your machines (one on each) and then to the moving appliance very snugly.You are not going to be able to do it alone. Then once you have checked out the hose ( actually pull the hose out of the drain and check out both lint and drain for debris) you are going to have to be very careful to make sure all connetions on dryer and washer are secure again before you push it back into place. Before you do this which is the hard part I would check out all of my household drains, using a plunger and make sure they are running fast and clean. I hope this helps. Just Please do not try to do it alone. You could hurt yourself or damage your machines. And remeber when you are working with the drain to unplug your washer and dryer!
  • Gayle Ashbach
    Are you on a city water system or a septic system? There could be a general drainage problem if you are on a septic.
What do i do when my washer affinity frigidaire displays E20
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire ATF6000ES Front Load Washer
this is an error that indicates the tub is clogged or draining slowly
to fix this you have to go under the washer and pull the tub hose off and clean all obstructing stuff in the hose and thru the hole on the tub
Oct 18, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
What does the error message E20 on the frigidaire front load washer GLTF2940FS mean?
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
My frigadare front loader has code E20 on it and won't drain out all water from clothes or drum
Hi
Error code e20 means a clogged drain pump. This might have happened due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump. Hope this helps... Please post back for any further assistance.
Daniel
Nov 27, 2010 | Frigidaire ATF6000ES Front Load Washer
WHAT DOES E20 MEANS ON A FRONT LOAD
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then clean the debris from the pump. Make sure that you have a container to collect water nearby when you are removing hoses from the pump, as ther would be a lot of water. Please post back for any further assistance.
Daniel
Aug 02, 2010 | Frigidaire Affinity ATF7000ES Front Load...
What does e20 mean? The display shows an error of e20. Looks like the water is not pumping out during the regular wash.
Hi
Daniel
Jul 31, 2010 | Frigidaire ATF6000ES Front Load Washer
Error code e20 model # gltf2940ee0
Hi
Daniel
Jul 28, 2010 | Frigidaire ATF6000ES Front Load Washer
E20 error code
Check this answer:
http://www.fixya.com/support/t615626-error_code_e20
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 02, 2008 | Frigidaire ATF6000ES Front Load Washer
E20 Error
On the sheet, 2 beeps and error E20 says Water Doesn't Drain. Drain hose is kinked or household drain is clogged. Straighten hoses or unclog household drain.
Jun 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
356 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
