Question about Norscot Group 150 CAT D6K XL Tracofn14332 Tractor
I have a Cat D6k XL and after a little bit of running, a code shows up that says Hydraulic System Electronic Control Module Add, Input Voltage Below Normal. Code 2225-4, OCC: 127. After the code pops up the D6k locks up all hydraulics. Then you have to shut it down for about 5 min before the hydraulics reset and you can move them again.
Every time I start my 06 equinox the 10 amp backup fuse blows. When I try to restart the car its no crank no start. When I replace fuse it starts fine again. Why is 10amp backup fuse blowing?
A short circuit in the wiring . Do you you know how to test automotive electrical circuits ?
10 amp backup fuse ?????? back up lights ? Video's on youtube showing how to find an fix a short . Park neutral safety switch
The transaxle control module (TCM) primarily controls shift points and lockup engagement.
The transaxle is controlled by an electronic shift system. The TCM processes input signals. From the information received, the TCM controls the transaxle hydraulic system.
The electronic shift system consists of the following components:
• TCM
• Shift Solenoid (SS1 and SS2)
• Pressure Control Solenoid (PSC)
• Lockup Solenoid
• Input Shaft Speed (ISS) Sensor
• Output Shaft Speed (OSS) Sensor
• Transmission Fluid Temperature (TFT) Sensor
• Park/Neutral Position (PNP) Switch
Have the vehicle checked for DTC'S - diagnostic trouble codes
When the TCM detects an invalid combination of TR switch signals, then DTC P0705 sets. DTC P0705 is a type A DTC.
BACKUP Fuse
10A
PNP Switch
The transmission range (TR) switch is part of the park/neutral position and back-up lamp switch assembly and is mounted on the transmission manual shaft. The TR switch is a multi-signal switch. The transmission control module (TCM) supplies voltage to the TR switch. Each gear selector lever position grounds one or more of the signal circuits in a unique pattern. In order to determine the gear range selected by the driver, the TCM compares the voltage combination on the signal circuits to a TR switch combination table stored in memory. Refer to Transmission Range Switch Logic .
Sep 02, 2017 | Cars & Trucks
Fuel control module 2008 escalade and the fuel pump quit working.if I run a hot wire to it it will run but as soon as I remove the hot wire it quits
Ran a hot wire to what fuel pump or the control module ? Which of these is yours ?
Figure 9: Fuel Controls - Fuel Pump Controls (LY6)
Figure 10: Fuel Pump Flow Control Module (Except LY6) Does yours have fuel pump flow control module under the vehicle Fuel Pump Flow Control Module (except LY6)
Mounted to the left side of the frame assembly below the driver seat ?
Fuel Pump Flow Control Module (FPCM) - LMF
The fuel pump flow control module (FPCM) is a serviceable GMLAN module. The FPCM receives the desired fuel pressure message from the engine control module (ECM) and controls the fuel pump located within the fuel tank to achieve the desired fuel pressure. The FPCM sends a 25 KHZ PWM signal to the fuel pump, and pump speed is changed by varying the duty cycle of this signal. Maximum current supplied to the fuel pump is 15 amps. A liquid fuel pressure sensor provides fuel pressure feedback to the FPCM.
Electronic Returnless Fuel System (ERFS) - LMF
The electronic returnless fuel system is a microprocessor controlled fuel delivery system which transports fuel from the tank to the fuel rails. It functions as an electronic replacement for a traditional, mechanical fuel pressure regulator. A pressure vent valve within the fuel tank provides an added measure of fuel pump flow control module (FPCM). Desired fuel pressure is commanded by the engine control module (ECM), and transmitted to the FPCM via a GMLAN serial data message. A liquid fuel pressure sensor provides the feedback the FPCM requires for Closed Loop fuel pressure control.
If your vehicle has this system check it for DTC'S - diagnostic trouble codes . Will take guess work out of it .
DTC P0191: Fuel Rail Pressure (FRP) Sensor Performance
DTC P0192: Fuel Rail Pressure (FRP) Sensor Circuit Low Voltage
DTC P0193: Fuel Rail Pressure (FRP) Sensor Circuit High Voltage
DTC P0230: Fuel Pump Relay Control Circuit
DTC P0231: Fuel Pump Control Circuit Low Voltage
DTC P0232: Fuel Pump Control Circuit High Voltage
DTC P023F: Fuel Pump Control Circuit
The engine control module (ECM) supplies voltage to the fuel pump flow control module (FPCM) when the ECM detects that the ignition is on. The voltage from the ECM to the FPCM remains active for 2 seconds, unless the engine is in crank or run. While this voltage is being received, the FPCM supplies a varying voltage to the fuel tank pump module in order to maintain the desired fuel rail pressure.
DTC P025A: Fuel Pump Control Module Enable Circuit .
Ford Electronic Returnless Fuel System Diagnosis Part 1 this for ford but the GM system works the same . You'll need a wiring diagram so you know what wires are what . Free wiring diagrams http://www.bbbind.com/free_tsb.html
Oct 31, 2016 | Cars & Trucks
How do I fix this problem?
the p 0420 is the HO2S bank 1 or cat converter below efficiency threshold
replace the HO2S first as it is the cheapest then replace the cat converter bank 1
have the accredited auto electrician bench test the alternator and regulator for over voltage
Nov 13, 2015 | 2001 Chrysler PT Cruiser
Hi i am still getting problems with this 2008 chavy tahoe, affter changeing the fuel pump, it drive a little and cutting off ,two codes comeing up p025A and P0452 .and the nigative wire getting hot.
Your problem is the fuel pump control module , do you know what this is !
Circuit/System Description
DTC P0452: Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage
What negative wire gets hot ?
What
your pro
Sep 22, 2015 | Cars & Trucks
All brake lights and traction light Or on the dash and my brake lights will not work 2006 Cadillac CTS
The traction control system is part of ABS control module an if the light is on there is A DTC - diagnostic trouble code stored in the EBCM - electronic brake control module ! The brake pedal position sensor is an input to the EBCM , when you press the brake pedal the EBCM then energizes the BAS relay in the left rear fuse box turning on the brake lamps !
There could be a DTC like
DTC B3903
The electronic brake control module (EBCM) supplies voltage to the BAS relay coil side voltage supply circuit when the stop lamps are active. The coil side control circuit of the BASS relay is permanently grounded at G402.
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC B3903 Stop Lamp Relay Circuit
Or
DTC C0278
The brake pedal position sensor (BPP) is a potentiometer. The electronic brake control module (EBCM) supplies a 5-volt reference circuit and low reference circuit to the BPP sensor. The BPP sensor signal circuit is a direct input to the EBCM. The EBCM determines the BPP based on the voltage from the BPP sensor. The EBCM converts the BPP sensor feed back voltage to a digital signal and puts it on the class 2 communication bus.
DTC C0282 Brake Pedal Position Sensor Circuit Range/Performance
DTC C0283 Brake Pedal Position Sensor Circuit Low
DTC C0284 Brake Pedal Position Sensor Circuit High
DTC C0880 Device Voltage Reference Output 2 Circuit
You may want to take this to the dealer !
Jul 14, 2015 | Cadillac Cars & Trucks
2007 Yukon Denali XL autoride suspension light comes on intermittently
Would need to know what DTC'S - diagnostic trouble codes are stored in the module for the autoride suspension . Hooking up a professional type scan tool ,looking at input data to the module etc... Looking at a wiring diagram an testing electrical circuit's using a DMM - digital multi-meter . Reading how the system works ,what all involved in making the system work . This is how a professional Tech would go about diagnosing this .
The automatic level control (ALC) system maintains a desired rear suspension position under all types of towing, hauling and loading conditions. The following components are involved in the operation of the ALC system:
• Air line tubing--Pressurized air from the ALC compressor is pumped to each of the rear shocks via air line tubing.
• Air drier--Pressurized air from the compressor is run through a drier containing a moisture absorbing chemical preventing water accumulation in the rear shocks.
• Compressor--Supplies pressurized air to the rear shocks
• Compressor motor relay--The relay supplies battery positive voltage to the ALC compressor motor.
• Pressure sensor--The electronic suspension control module (ESCM) module provides a 5-volt reference and low reference to the ALC pressure sensor. The module receives the signal voltage that is relative to the air pressure applied to the rear shocks.
• ESCM--Controls the ALC system and electronic suspension control (ESC) system and detects failures in both. The module monitors inputs from the position sensors, and pressure sensor to determine when to raise and lower the vehicle to trim height as the vehicle is loaded or unloaded. The module limits pump activation to 255 seconds to prevent thermal damage.
• Exhaust valve--An electric solenoid activated by the ESCM to vent air pressure from the rear shocks.
• Left and right rear suspension position sensors--The module provides a 5-volt reference and low reference to all 4 of the body-to-wheel suspension position sensors. The sensors send the ESCM a signal voltage that is relative to the rear suspension ride height
• Left and right rear shock absorbers with internal air chambers and dampers--Dampens the rear suspension and maintains trim height depending on the air pressure applied.
Nov 04, 2017 | 2007 GMC Yukon XL Denali
Engine diagnostic code p0333 from 2007 toyota tundra
P0333 - Knock Sensor 2 Circuit High Input Bank 2. The knock sensor is attached to the cylinder block. It senses engine knocking using a piezoelectric element. A knocking vibration from the cylinder block is sensed as vibrational pressure. This pressure is converted into a voltage signal and sent to the Powertrain Control Module or Electronic Control Module.
The code is triggered by an excessively high voltage from the sensor is sent to Powertrain Control Module or Electronic Control Module.
Possible Causes:
- Knock sensor circuit short to GND.
- Knock sensor circuit short to PWR.
- Knock sensor circuit open.
- Damaged knock sensor.
- Powertrain Control Module
Possible Solutions:
- Repair or resecure harness or connector
- Replaced knock sensor
Jan 16, 2011 | 2007 Toyota Tundra
96 cherokee xj trouble codes list?
The error codes are given below
1192 Inlet air temperature sensor voltage is wrong
1193 Inlet air temperature sensor voltage is wrong
1194 Oxygen sensor heater performance is faulty
1195 Oxygen sensor is slow
1196 The oxygen sensor switched too slowly (bank 2).
1197 The oxygen sensor switched too slowly (bank 1).
1198 Radiator coolant temperature sensor voltage is wrong.
1199 Radiator coolant temperature sensor voltage is wrong.
1281 The engine is staying cold too long - check your thermostat.
1282 The fuel pump relay circuit seems to be having a problem.
1288 The intake manifold short runner tuning valve circuit seems to be having a problem.
1289 There's a problem in the manifold tuning valve solenoid control circuit.
1290 Compressed natural gas system pressure is too high
1291 The heated air intake sensor does not seem to be working.
1292 Natural gas pressure sensor issue
1293 Natural gas pressure sensor issue
1294 Can't get to target engine speed, check for vacuum leaks and idle speed motor issues.
1295 The throttle position sensor doesn't seem to be getting enough electricity.
1296 The MAP sensor doesn't seem to be getting enough electricity.
1297 The MAP sensor doesn't change its reading when the engine is running!
1298 During wide-open throttle, the engine runs lean.
1299 MAP Sensor and Throttle Position Sensor signals don't match, check for a vacuum leak.
1388 Auto shutdown relay circuit problems?
1389 No Z1 or Z2 voltage seen by the computer when the auto shutdown relay is used.
1390 Cam and crank signals don't match - did the timing belt skip a tooth?
1391 Sometimes, I can't see the crank or cam sensor signal.
1398 I can see the Crank Sensor's signal when I prepare for Misfire Diagnostics. Try replacing it.
1399 Problem in the Wait to Start Lamp circuit - (diesels only?)
1403 EGR position sensor not getting (enough) voltage.
1476 Too little secondary air injection during aspirator test.
1477 Too much secondary air injection during aspirator test.
1478 Battery temperature sensor voltage wrong.
1479 Transmission fan relay circuit problems?
1480 PCV solenoid circuit problems?
1481 Transmission RPM pulse generator signal for misfire detection seems wrong.
1482 Catalyst temperature sensor circuit shorted low.
1483 Catalyst temperature sensor circuit shorted high.
1484 The catalyst seems to be overheating!
1485 Air injection solenoid circuit problems.
1486 Pinched or blocked hose in the evaporative hose system.
1487 Control circuit of the #2 high-speed radiator fan control relay is having problems.
1488 Auxiliary 5-volt sensor feed is too low.
1489 High speed radiator fan control circuit problem.
1490 Low speed radiator fan control circuit problem.
1491 Radiator fan control circuit problem (may be solid state relays as well as other circuits).
1492 Ambient or battery temperature sensor voltage wrong
1493 Ambient or battery temperature sensor voltage wrong
1494 Leak Detection Pump (LDP) pressure switch problem - electrical or the pump itself.
1495 Leak Detection Pump (LDP) pressure switch problem - the solenoid circuit.
1496 Sensor feed is below an acceptable limit. (under 4v for 4 seconds - should be 5v).
1498 High speed radiator fan control circuit problem. (#3 control relay)
1594 Voltage too high in charging system.
1595 Speed control vacuum or vent solenoid control circuits shorted or lost.
1596 Speed control switch always high
1597 Speed control switch always low
1598 A/C pressure sensor voltage high
1599 A/C pressure sensor voltage low
1681 No messages received from the cluster control module (dashboard computer).
1682 Charging system doesn't seem to be working well. Check alternator, etc.
1683 Speed control servo power control circuit problem.
1684 The battery has been disconnected within the last 50 starts.
1685 Invalid key received from the Smart Key Immobilizer Module.
1686 No messages received from the Smart Key Immobilizer Module.
1687 No messages received from the Mechanical Instrument Cluster module.
1 693 The companion engine control module has shown a fault.
1694 No messages received from the powertrain control module-Aisin transmission.
1695 No messages received from the body control module.
1696 Unsuccessful attempt to write to an EEPROM location!
1697 Unsuccessful attempt to update Service Reminder Indicator (SRI or EMR) mileage!
1698 No messages received from the electronic transmission control module or the Aisin transmission controller.
1719 Transmission 2-3 gear lockout solenoid control circuit problem.
1740 Either the tcc solenoid or overdrive solenoid systems doesn't seem to be making much sense.
1756 Transmission control pressure not equal to target. (Mid pressure problem)
1757 Transmission control pressure not equal to target. (Zero pressure problem)
1762 The Governor Pressure Sensor input was too high or too low for 3 consecutive park/neutral calibrations.
1763 The Governor Pressure Sensor input is too high
1764 The Governor Pressure Sensor input is too low.
1765 Open or short in the Transmission Relay control circuit.
1899 The Park/Neutral switch seems to be stuck!
Jul 18, 2010 | Directed Electronics Dei '96 To '98 Jeep...
Norscot Group 150 CAT D6K XL Tracofn14332 Tractor Logo
128 people viewed this question
Top Norscot Group Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Norscot Group Toy Expert? Answer questions, earn points and help others
