Question about Dishwashers
Teka DW6 59 F1 Lights 4&5 keep flashing together. How do I reset the programmes?
  • Dishwashers Master
  • 3,247 Answers
I am slightly unclear if lights 4 & 5 are counted left to right or right to left when facing the dishwasher.
If you are counting right to left - then lights 4 & 5 flashing implies E3 fault - heater failing to heat.
am suspecting the heater unit is failing. Try to run dishwasher on a colder program like DELICATE and see if goes through.
If the flashing does not go away by turning power off and back on then the heater or the thermostat has failed and will need replacement.
Hope this helps fix the problem. Please post a comment if this is not helpful.
Posted on Mar 17, 2011
Teka ha 830 oven timer will not reset after power cut
I have a Teka HA830 oven I held the buttons down but it never resets. Would like to know if its possible to change the computer board, and where can i purchase it online?..
Jan 29, 2013 | Ovens
Why is there a beeping noise every 5 minutes or so while driving-
AS LONG AS YOUR CAR IS RUNNING FINE & HAS BEEN SERVICED RECENTLY YOU CAN ALTER THIS MESSAGE ON SCREEN TO STOP THE BEEPING, THE EASIEST WAY IS TO DISCONNECT BOTH THE + & - BATTERY LEADS & CONNECT THEM TOGETHER FOR AT LEAST 30 MINS, THIS WILL RESET THE JEEP'S MEMORY, CONNECT BACK THE LEADS & THEN WHEN YOU GET IN & START YOUR CAR THE DISPLAY BY THE GEARSHIFT WILL BE FLASHING - SET THE CLOCK BY KEEPING YOUR FINGER ON THE SET BUTTON FOR S FEW SECONDS UNTIL THE IST DIGIT BEGINS TO FLASH, THEN PRESS THE SET BUTTON UNTIL YOU REACH THE DESIRED HOUR, THEN PRESS THE SELECT BUTTON BELOW & THIS WILL MOVE YOU ON TO THE MINUTES, CONTINUE WITH THE ABOVE OPERATION UNTIL THE TIME & DATE HAVE BEEN SET, YOUR "SERVICE" SHOULD NOW BE RESET TO EITHER 7500 MILES OR 12500 MILES, I SERVICE MY 96 GRAND CHEROKEE MYSELF SO THIS IS MY "CHEAT" FOR THE SYSTEM & IT IS GUARANTEED TO WORK. BEST OF LUCK.
Sep 05, 2012 | 1995 Jeep Grand Cherokee
Genus 30 70 & 80 lights flashing
You posted this question in the Calculators area of FixYa. Please repost in the appropriate area so the proper experts can see it and provide an answer.
Jun 13, 2012 | Office Equipment & Supplies
Dishwasher lights flash half way through program
you will have to consult your owners manual
Jun 07, 2012 | Dishwashers
Need an english manual for teka dishwasher dw6 59 f1 please
By maggiegardne on Nov 20, 2010
need an english manual for teka dishwasher dw6 59 f1 please
Nov 20, 2010 | Dishwashers
How do I reset the oil service counter
1. Switch ignition OFF.
2. Press and hold button "A" - fig. 1 or fig. 2.
3. Turn ignition key to position "I".
4. After 5 seconds the words "OIL SERVICE" or "INSPECTION" are shown together with the message "reset" or "re".
5. Release button "A". Press and hold button "A". After a futher 5 seconds the message "reset" starts to flash.
6. Release button "A". Press and release button "A" again.
7. The new service interval is now displayed.
8. Press and release button "A". The message "END SIA" is now displayed.
8. Switch ignition OFF.
Fig.1
Fig.2
Aug 27, 2010 | 2004 BMW 3 Series
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
FDW 60 lights 4 and 5 flashin.Select programme,m/c then bleeps 4 times and then lights 4 and 5 flas together and nothing else happens!Any ideas please?
Control panel which is a bit sensitive might need re-booting. Mine did the same and had a mind of its own, doing what it wanted, lights flashing all over the place, not completing the wash etc etc.
Switch off the machine and unplug from the mains. Leave for 10 minutes.
Plug back in, switch the machine on to your required programme and if ,like me, you are lucky, your machine should work again. If it happens again in the future you know what to do. Failing that go to the Hotpoint website, find the customer service number and ask if there is anything else you can do yourself to solve the problem, before paying for a service call. They are really helpful
May 27, 2009 | Hotpoint 24 in. FDW60 Free-standing...
My hunter thermostate keeps flashing a 4 and wont turn on !
hunter thermostats are not the highest quality. on the back of the thermostat there should be a not well identified reset button. You can locate and push this to attempt to fix the problem. Or purchase a new (i would suggest Robertshaw or braeburn) thermostat and install.
Dec 14, 2008 | Hunter Fan Company 5/1/1 Programmable...
Dishwashers Logo
492 people viewed this question
Top Dishwashers Experts
Owen Barnes
