Question about Dishwashers
I have got a dishwasher bought from Carrefour in Spain, an Ice Cool C1154S. It is about 2 and a half years old. It has started making a noise when half way through its programme and then the 2 red lights flash. It empties and fills OK. Hubby has taken it out and checked for blockages but nothing there. Any suggestions? Sally
zeusfaber
  • 247 Answers
SOURCE: No water filling up in the dishwasher when programme set
My instinct would be to replace the water inlet valve without even trying to prove whether that is the real problem. The valve is the plastic unit on the back wall of the cabinet that your cold water hose screws onto. I think your dishwasher takes a Universal 90 degree Single inlet cold water solenoid valve, which you can find unbranded on the net for under £10. Provided you remember to turn the power and water off before you start, there are no hidden surprises in the replacement procedure: Remove the inlet hose, undo the screws attaching the valve to the cabinet, unplug the two wires, unclamp and remove the hose inside the dishwasher, then reverse the process to reassemble. After assembly, check that the hose to valve coupling is watertight. Granted, the problem might conceivably lie elsewhere, but the valve is so much more likely a culprit, so cheap to buy and so easy to fit that you might as well change it on spec. A.
Posted on Mar 20, 2007
  • 883 Answers
SOURCE: Zanussi Aquapulse DE6544 not emptying
find the power source (usually at the circuit breaker panel)-then turn the breaker for the dishwasher off and return to on after 10 minutes and try restarting.
Posted on May 27, 2007
SOURCE: Whirlpool ADG 6340 Dishwasher
fault 7 is a fill fault . If you take the left side panel off you will see a white plastic tank . The sensor in the tank has failed
Posted on Jun 23, 2008
  • 235 Answers
SOURCE: dishwasher wan't fill with water
The water valve may look fine but the solenoid may not be opening to allow water in. You said that everything else works fine except no water supply to the dishwasher. This sounds like a bad soleniod valve. Check for continuity on the valve with an ohms meter after you start it. Be careful.
Posted on Jul 05, 2009
pride applia
  • 232 Answers
SOURCE: Red light flashes when it gets to rinse cycle
complain to miele be a pain they have given discounts on a new one before. try running apple cyder vinager through it pore some in let it run a little then open the door and let it soak for a day or so and then try it again it may just be dirty good luck
Posted on Dec 08, 2009
Manual for Carrefour home CSC507-11
Steam Cleaner CSC507-11 purchased from Carrefour in Spain but need an English translation can you help
Feb 19, 2013 | Vacuums
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
LOOKING FOR AN ENGLISH MANUAL FOR A CARREFOUR SLOWCOOKER MODEL HSC 290-10
I need an English manual for Carrefour Home slow cooker HSC290-10
Dec 26, 2010 | Crock Pots & Slow Cookers
I have an MDB760 dishwahser making a lot of noise
The pump is not turned on when the what is sloshed around. It is the wash motor which turns the arms around. It is likely something is stuck under the washer arms or the washer motor bearing is faulty.
If the dishwasher is only about 2 years old, I would suggest you call Maytag for warranty service. Depending on the part they will have different warranty time period. Normally 2 years should be a general policy .
May 08, 2010 | Maytag 24 in. MDB7601AWS Stainless Steel...
Dishwasher will not go into wash cycle.
On the LG LDF6810 dishwasher, the best you can do is remove the bottom spray arm and then the 10 phillips screws that hold the filter down.
Pull the filter out and clean it as best you can.
Inspect the sump area beneath where the filter was. Be careful of broken glass and remove all debris. Use a flashlight and look into every little spot down there. Reassemble the dishwasher and operate your DW.
If you still have problems, I recommend a service call. Check your manual to confirm but most LG dishwashers have a 1 year parts & labor plus a 2 year parts only. Have your proof of purchase ready.
Apr 02, 2009 | LG LDF6810ST Stainless Steel Built-in...
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Dishwashers Logo
93 people viewed this question
Top Dishwashers Experts
