Question about Lincoln Electric Stt Sense Lead Kit 75 Ft K94075
When using two Lincoln Electric STT 11 simultaneously the information transmitted through the + - Sensing leads becomes corrupted resulting in a faulty output. The STT's are being used in conjunction with stand alone welding bugs with a sprung negative sensing lead device trailing the bug. With 1 bug working there is no problem with 2 major problems. ****
3 Suggested Answers
luis_david
  • 407 Answers
SOURCE: I have a Lincoln Pro
Hi:
There is nothing wrong with your machine. The Pro-core100 is a 20% duty cycle machine; meaning: that will work for 2 straight minutes of welding and then needs 8 minutes to cool down.
Just allow the machine to cool down, turn it off and start again after the 8 minute cooling process.
If this was useful to you please vote. Thanks.
Posted on Mar 30, 2011
luis_david
  • 407 Answers
SOURCE: Where can I get a gas diffuser for a Lincoln
Gas diffusers are sold at any welding store, look up praxair site for your nearest location. The part number you are looking for is: TWE-35-50 about 6.00 bucks or less.
Posted on Jun 14, 2011
I have a Lincoln 305g with digital readout and the amperage readout is fluctuating wildly but is not effecting amperage to the stinger,is it possibly just the digital readout that needs replacing?
Most likely the coil that is sensing output at the lead terminals. Check it with a hand held Amprobe (digital) to see if out put is stable at the leads.
May 15, 2017 | Lincoln Cars & Trucks
Reset bios
The 104 error may be caused by windows system files damage. The corrupted windows system files entries can be a real threat to the well being of your computer.
There can be many events which may have resulted in the system files errors. An incomplete installation, an incomplete uninstall, improper deletion of applications or hardware. It can also be caused if your computer is recovered from a virus or adware/spyware attack or by an improper shutdown of the computer. All the above actives may result in the deletion or corruption of the entries in the windows registry. This corrupted registry will lead to the missing and wrongly linked information and files needed for the proper working of the application.
Aug 15, 2013 | HP EliteBook 6930p Notebook PC
Lg #721 repair manual
test this component and replace it any faulty. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Jul 20, 2013 | Microwave Ovens
How to fix can't load res_dll
important issues regarding Dll Error Repair: Computer errors occur when your operating system becomes filled with junk and important files get removed or corrupted. These types of problems are the consequence of not properly maintaining your system. If left unchecked these problems can result in critical system errors, freezes, and even a complete system crash.
Recommended: Use the Free Scan to diagnose Dll Error Repair issues as well as other problems plaguing your system. Once registered, this tool can repair the issues that may be causing your system to malfunction while simultaneously boosting computer speed, optimizing memory, improving protection, and much more.
May 26, 2012 | Dell Computers & Internet
How i can use wire feer x-tyrem with a cp-302 welder
Hi:
An easy one: Connect your Suitcase X-treme 8 or 12 VS (volts sensing) as follows:
Weld Cable (+) To Feeder lead cable.
Work Cable ( - ) To Workpiece Weld cable and work cable connections to power source (DCEN/DCEP) are dependant on wire type.
Since feeder is not polarity sensitive, there is no need for an electrode polarity switch.
Voltage Sensing Clamp Connect voltage sensing clamp to
workpiece.
Gas Hose to regulator.
Gas Cylinder to regulator.
Use of shielding gas is dependant on wire type.
You are all set up to weld.
If this was useful. Please vote.
Feb 22, 2011 | Miller Electric Mfg Co 903376 Deltaweld...
How do i get rid of er2 message on realistic htx404
This is taken from an in-store Rad Shark memo concerning the HTX-202.
ER1 indicates an internal RAM error. It appears when the memory backup battery is dead, when something has caused the memory contents to become corrupt, or as a result of physical or static electric shock. To clear this error, turn off the unit. Then turn it back on while holding down the "function" and "D" buttons. This clears the memory. If the error returns after you clear the memory, service is required.
ER2 indicates a PLL unlock. The radio gives this error if the PLL alignment is off or if the transmitted signal interferes with the internal PLL frequency. This error has been reported most frequently when using the supplied "rubber ducky" antenna with either a high-power battery pack or with an external DC source.
According to the memo, the fix for this is to use an external antenna when using external DC power.
Feb 25, 2010 | Radio Shack Radio Communications
Dryer will not start cycle
Hi-- none of the solutions I've read here are working. Same problem, dryer not starting, it says "Sensing..." and then "Wet" and does nothing. It worked fine on the last load, except I noticed it read 11 minutes for a very, very long time (I think it got stuck). New load? "Sensing..." etc.
Feb 18, 2010 | Whirlpool GEW9250 Electric Dryer
WordPerfect 11 files are corrupted
Borrow one. Copy it and use it instead of yours. The serial number is the important bit.
Jan 21, 2009 | Corel WordPerfect Office 11 Upgrade...
Lincoln Electric Stt Sense Lead Kit 75 Ft  K94075 Logo
Top Lincoln Electric Welding Tools Experts
oleolson
Level 1 Expert
Daryl Gleaton
Troy
Troy
Level 1 Expert
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
