Question about Canon PIXMA iP3500 Printer
Only prints other colors except black. Have change the toner but problem still exist.
  • 51 Answers
Hi if you have put a new black ink in your machine and it still will not print black you will need to do a print head clean. you will find this on you pc in printer properties.
The problem is the ink can dry up and set in the print head so no new ink can get passed.
in the cleaning fails then you will need a new print head this is a part that you can if and if you go to Amazon and look for PIXMA iP3500 print head you will find it at about £45 ish
Yours Ian
Posted on Mar 17, 2011
Change BLACK AND WHITE DEFAUT TO COLOR
You can change the font color in the document you want to print.
(This will not help if the printer refuses to print blue while the black toner is empty.)
May 12, 2014 | Dell Office Equipment & Supplies
We have a CLP-300 Series A laser printer which we really like. The problem we are having has recently surfaced after we changed the BLACK toner cartridge. There are skips and light area in the printing...
I think you should contact the manufacturer or vendor who sold you the cartridge. The standard warranty is 90 days. I believe that it will prove to be a bad toner/ drum (which are the same thing for this printer.)
Besides that you can do a "half-test". Stop the print job half way by opening a cover during the print process, before it is transfer to the paper and fused. Look at the drum or transfer belt and see whether the defect exists early in the print process.
There may also be a contact problem with the black toner. Check for bent metal on the toner, or chassis that should mate and conduct charge to the toner.
Whit
Item, Inc.
Dec 13, 2010 | Samsung CLP 300 Laser Printer
Printing only black in TallyGenicom 8108N
You can change the colour setting in the printer driver to Black Only, this means you will only print Black and White using only the black toner.
To make this change on Windows XP;
Open the Printers and Faxes Folder.
Right Click on the printer driver for the 8008.
Select Printing Preferences.
Click on the Color/Print Quality Tab.
In the Color Mode section select the B&W radio button.
Click on the APPLY button
This should change the pritner driver to print only black and white.
Mar 23, 2010 | TallyGenicom 8008 Laser Printer
I need to get new color toner. It indicates
go into your printer menu to your replace supplies section and turn on your override I did this and was able to print out about another 250 sheets
Oct 06, 2009 | HP Color LaserJet 2600n Printer
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
POOR PRINT QUALITY WHEN PRINTING IN BLACK ONLY
may be your new toner can be faulty.you can try this processor first you remove the toner & refix it after shaking.if your problem is not solved then check with new toner again.
Sep 02, 2009 | Samsung CLP 300 Laser Printer
Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Sep 30, 2008 | HP Color LaserJet 2600n Printer
Xerox 7700 intermittant banding on a diagonal black only
You most likely have a bad black developer housing.
You can try removing the waste bottle and using that bla\ck stick inside the cover to clean the laser ****.
But it sounds like the developer housing has failed.
Sep 07, 2008 | Xerox Phaser 7700 Laser Printer
Not printing black
it´s pretty strange but if u replaced both toner and drum, the printer doesn´t give any error u may have the high voltage board damaged, and u can't do much, u must contact a local dealer
Jun 30, 2008 | OKI C5100n Laser Printer
Canon PIXMA iP3500 Printer Logo
184 people viewed this question
old marine
old marine
