Question about Intel S5000PSL (0735858182874) Server
Cannot ping my interl sp5000psl server from the network however i can ping the other server from It.
  • 596 Answers
I would verify your NIC is working. Check the control panel>network for any errors. Also, I would verify the configuration from the DOS prompt. Check with ipconfig /a and see results. if you get an error message about not able to retrieve info, you need to replace the NIC or add one on your board.
Good Luck.
Posted on Dec 28, 2011
How to Make a Ping Utility on Windows NT Systems?
Helps in determining TCP/IP networks IP address as well as determine issues with the network and assists in resolving them. See the ping definition for a full description.
Pings the localhost. which helps determine if the computer can send information out and receive the information back from itself.
Note: The above command does not send information over network, but can indicate if the card can respond .
Ping supports the ability to ping an Internet address. In the above example, we pinged "computerhope.com" and as can be seen, received four responses back. If we couldn't reach the server or the server was blocking our request we would have lost all four packets .
Allows you to ping another computer where <69.72.169.241> can be the IP address of the computer you want to ping. If you do not get a reply or get lost packets you have a problem with your network, which can be a cable issues, network card issues, drivers. router. switch. or other network problem.
Oct 20, 2016 | Computers & Internet
Tip
How to Troubleshooting Network
Here you will learn network troubleshooting tips, fix tcp/ip errors, tcp/ip settings, internet connectivity errors, how to fix pc errors, lan connectivity issues, traceroute and ping commands. Whether your operating system is Windows or Linux network problems are likely to arise. Many times the network problems arisee due to improperly configured TCP/IP settings. Following is the basic checklist to identify and troubleshoot the basic networking errors.
1. First of all you should learn what stopped working server or client computer also see if the outage affecting the other computers or only one.
2. If you server stopped working you should inform the users of the server and you should start working on fixing the error.
3. If a single client computer stopped working or disconnected from the network, ask the user of that computer that what recent changes cause the server to stop working such as newly installed software or games, service packs, internet software, new hardware or any other thing.
4. Check the physical network connectivity. The most network problems arise due to the physical layers failure.
5. Check all the network cable connections. You can start at the NIC and check if the green light is blinking then check the hub and see if the computer is getting the link across the cable.
6. Get a cable tester to check the connectivity of the cables.
7. Finally start pinging the network both Windows and Linux have the PING command. You can use ping command in this way start > Run > cmd > type "ping" then IP address of the other computer
on Mar 25, 2010 | Computers & Internet
Why Addresses in the IP Address Pool on a Switch Are Exhausted When the Switch Functions as a DHCP Server and It Has a Few Clients?
If the IP address pool has much more resources than needs of clients, the following two reasons may cause address exhaustion:
1. An attacker keeps changing the CHADDR field and sending DHCP Discover packets to exhaust addresses. If so, contact Huawei engineers to deploy DHCP snooping to protect the IP address pool.
2. The DHCP server ping function is enabled on the DHCP server. This function tries to ping the allocated addresses before responding to DHCP Offer packets. If a client responds to any ping packet, the DHCP server considers that there are address conflicts and addresses are exhausted. To solve this problem, two methods are available:
1. Capture packets on the ports connected to the DHCP server. If a client responds to ping packets, prohibit the client.
2. Disable the DHCP server ping function using the undo dhcp server ping packet command.
3. Such as S5700, S6700
Aug 01, 2016 | Computers & Internet
How to ping server name
find command screen on windows computer. XP it is under accessories. On windows 8 you have to use the search facility to find CMD.
On black command screen enter command
PING "server name" where "server name" is the server you want to find such as Microsoft.com.
Jul 02, 2014 | Intellinet Active Networking 802.11b/g...
We have an HP Proliant G4 Server, the onboard NIC Card is does not power up when it is connected to the Network, i have checked the device manager and the BIOS setting if it is working fine which was so, i...
Have you checked firewall settings. It's possible that the Server's OS has a firewall blocking pings and\or the server is running antivirus software that has a firewall setup again blocking pings.
Feb 03, 2011 | Computers & Internet
Printer can not ping
is this is a print server/network printer? first off, the basics --- is the computer you are using to ping the printer on the same LAN IP as the printer (e.g. 192.168.1.x for both)? is this a wireless print server/network printer? if yes, physically connect it first to a router or switch and check if you can ping it. if you can, does it have a web interface, make sure you can access it and its wireless settings matches those of your wireless router.
Post back whatever you can come up with so I can give you more specifics
Jul 13, 2009 | Zebra (11X-7CX-XXXXX) (11X7CXXXXXX) Print...
Can't send e-mail
Check your network connection. Can you visit web pages? If not, check your network cable, modem, etc.
If your connection is good, try pinging your outgoing mail server.
If the ping fails, phone whoever maintains the server, and ask them when it will be back online.
If the ping is successful, try closing, then opening your mail client. Doublecheck the settings for outgoing server, port, encryption options, username and password.
Sep 17, 2008 | Gateway Computers & Internet
No longer pinging...
check the cables, it's possible that a wire used for the comm. from the server to the switch/router is not making proper contact or is broke...
Jun 24, 2008 | NetGear 24-Port (fsm726s&mr814) Networking...
Networking problem
yup..i have a symantec antivirus..i also turn off the firewall of my computer.
May 23, 2008 | Computers & Internet
Documents not printing
Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
Intel S5000PSL (0735858182874) Server Logo
208 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
