Question about Konka Televison & Video
I have konka kp-2562atxi television There is problem.Sparking near from EHT and horizental line on tv.can u give me solution for that.
    Top Expert:
  • Konka Master
  • 75,599 Answers
Hello
Sparking of EHT transformer is an irreparable fault. The only remedy is to replace the EHT transformer with same type and number. never switch ON your Tv in this condition anymore. It will damage other components nearby the EHT transofrmer. Replace it without any delay. Now, all the sections are working, and if you continue to research with, the condition will go worse and costly. OK.
Posted on Mar 17, 2011
My Samsung 20" Color TV has some EHT spark at PCB side. Spark jumps from EHT bottom to nearby Resistor / capacitor. Can i stop this by covering some insulation, will it be ok and no damage to TV. OR shall...
it is sparking as the case has come cracked. I have manager to fix some with some superglue finding the crack takes a few times to fill the gap. failing that a glue gun around it will put a rubber seal around it and make it safe. .
Oct 03, 2013 | Televison & Video
Stand by lights blinking and no picture.
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ............... so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact sony service centre.........
Apr 19, 2011 | Sony KP-46S25 TV
I have a Sony KP-43T90 that has the flashing light 4 times bug What do i do?
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective - so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 (US$ 12) - iam service engineer (computers, laptops, printers,etc) - bangalore - domlur - 09986222774 - sathyavijayasarathibabu@ymail.com - if you are in bangalore then you can call me for service - i think you are living somewhere in america /australia..... - problem is simple but i don't have any idea about EHT COMPONENT 's price & service charge in your place....... so my suggestion contact near by TV service engineer or approach sony service centre ....this problem cannot be solved by user unless user is a technical person, having idea about components (resisitors,transistors, diodes, ...etc), having tools like multimeter ,soldering iron , soldering lead ,flux, desoldering coil, etc....
Apr 15, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Im in Sri Lanka. I have a 29" JVC InteriArt Musee TV. It's Very Good Television. But is in sometime FLIYBACK wire High voltage Spark. is Very Dangerous Sounds and looking Spark. I think replace TV...
With an EHT meter, check the EHT voltage is no higher than 26kV. Check where the spark is coming from, thoroughly clean the area with Isopropyl. If on the EHT plug, on the tube, use DC4 silicon grease on the affected area.
If on the transformer, use a liberal amount of DC4 to stop the sparking.
Mar 05, 2018 | Televison & Video
My SONY tv KV-XF21M80 produces a continuous sparking sound
The tech is very likely correct. The EHT or flyback transformer can develop hairline cracks that allow leakage of high voltage that exists in this circuit. There are other related components that can also cause this, but the transformer is the most likely. This area in the set also builds up allot of dust also due to the high voltages and this aggravates the issue. I do not recommend operating the set very long this way as it may begin arcing inside and cause more components to fail. Replacing the part would depend on how much you want to invest in the unit. Get an estimate and go from there. Good luck.
Nov 25, 2009 | Sony Televison & Video
My SONY KV-XF21M80 produce a hissing (sparking) sound
That model number is not correct. What is an EHT? Must mean HVT High voltage transformer. If this set is 26 inch or smaller replace it. If larger yes replace the transformer.
Nov 23, 2009 | Televison & Video
The color is fading in our KV-32FV26 Sony Wega The TV is approx 3 years old.
my sont tv model no. KV-XF21M83 (21 in's) indicator lamp flashes red a number of times between 3 secounds interval
the color of the tv has gone faded. The channels name on the top right or left side is not seen properly
The EHT is sparking near the picture tube.
Nessarry guidence may please be comnicated in this regard please. send me feed back to my email adress
sikandher@hotmail.com
Mar 13, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KP-57WS500
Sounds like a conergence circuit failure, probably a couple of AMPs and a few discreet components. Probably 250-300 repair
Apr 20, 2007 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
90 people viewed this question
Top Konka Televison & Video Experts
Arnel
Arnel
matt martin
matt martin
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
