Question about Refrigerators
The temp on the freezer drops to 0 on it own. have tried resetting, unplugging etc but not use. please help
  • Refrigerators Master
  • 43,501 Answers
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Mar 18, 2011
Ok, upright freezer, frigidaire, read -12 after power outage but working ok..when I tried to reset temp to 0, light went off, freezer went off, front display reads 56..any ideas?
Thank you for your post, Cynthia!
Based off the information you have provided your Frigidaire freezer is not cooling properly and is now displaying the temperature of 56. It sounds like your freezer is not on, even though it has power the compressor is not turned on. I would suggest pressing either the down or up arrow three times within five seconds. That should power on your compressor and it should start cooling properly. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Feb 28, 2015 | Frigidaire Freezers
Fridge is freezing everything. Tried to unplug to reset, now front panel is blinking and won't do anything else. I have a rb215lash bottom freezer refriderator.
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Aug 25, 2011 | Samsung RB215LASH
Miele F7131 S The red alarm and the orange -32 degrees orange light on the front of my under counter freezer keep flashing. I have defrosted it. It appears cold but the lights will not stop flashing.
Freezer Temp. shoud be 0 to -5 Deg. if to warm it will set off the alarm. try unpluging or turn off power to freezer for 1 or 2 min. to see if it will reset.
May 17, 2010 | Freezers
My freeer stopped working after the temps dropped
freezers have a range of ambient temperature uses
most are plus 10c to 35c if using some units in garages etc. they just dont work...too cold for the poor things...
Feb 04, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
GE side-by-side PS123SGMD BS won't cool
Check the door seals to be sure they are in good working order. Close both doors on a dollar bill at several locations all around the door and pull on the dollar bill. You should have resistance as you pull it out in every area you check. If you have any gapped areas and it slides easily, adjust the door or replace the seals. Also, is the circulation fan in the freezer working correctly? Lastly, unplug the unit for 5 minutes to allow the control module to reset itsef. Then plug it in again and reset your temps, clock etc.
Jul 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Deforst mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work. Tom
Jun 18, 2009 | Freezers
Freezer not freezing
Hello jannette859,
huuum at your service
You said,
freezer was working fine had to unplug it due to evacuation, now it doesn't freeze, is there any reset buttons? i didn't turn the temp selector to the off position before unplugging
Try turning off the temp. switch off.
Then plug it in and turn the temp on!
this may reset it.
Repeat one more time and let me know ho it went!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Bless You huuum
Please give me the best rating at fixya .com before you sign off.
Thank You
Sep 15, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
No digital readout
Hello derek143
You Said,
I have a Whirlpool upright freezer AFG 371/H there is a digital display and lights and buttons, on/off temp alarm etc running across the top of the freezer. None of this works but the freezer is still freezing. i have no idea what the temp is.
I think you should try unplugging it for 5 minutes and then try restarting it and see if it reset.
Sep 11, 2008 | Freezers
GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Sep 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator will not cool
Do you mean the display won't go below 70 or that the actual temps won't go below 70? First try to unplug the refer for 20-30 seconds then plug it back in. Hopefully that will reset the levels to factory settings (usually around 0 for freezer and 36 for refer).
Dec 18, 2006 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
