Question about Health & Beauty
HI. MyGO,Chair has a problem with the right wheel.It moves slower then the left wheel, also it makes a galloping sound.I think the gear is loose,how do i tighten it. Thank you.
  • 278 Answers
Sounds like you have a bad differential in your transaxle. This item is covered under the Pride limited warranty for 3 years. This is not an adjustable item. It is required that you remove the brake motor transaxle assembly, replace the transaxle, then re-install the brake/motor/transaxle.
Labor from a certified dealer is about 1.5 hours. Contact the dealer you purchase it from for service. Hope this helps.
Posted on Mar 20, 2011
My Jazzy Select HD stopped working. It turns on, but wont move. I have chasing lights going from left to right. I tried unlocking, that did not work. Any other ideas?
make sure that the free wheel levers are in drive position. Also the charger is unplugged. restart and see if that took care of it. Also check the wires coming out of the joystick that they have not been damaged somehow.
Oct 10, 2016 | Pride Jazzy Select Hd JSELECTHD
Pride ultra making noises during ride
If you turn to the right and the speed of the clicking sound goes faster then your left wheel has the problem. The shaft key is a little loose and is shifting while running. If you turn to the right and the speed of the clicking sound goes slower then the right wheel has the problem. Sometimes a stick will become lodged underneath making contact with the wheel or rim making a clicking noise. These noises can drive me nuts. Scooter Doctor App
Jun 01, 2016 | Pride Health & Beauty
Right wheel turns slower than left one causing chair to turn right only?
hi Robert, normally this is because of the motor on the left hand side either needs new brushes or the brake is not freeing 100% , at worse it is a joystick fault ... check the joystick connections.. and the connections to the left hand side motor
Regards
Rob
Oct 28, 2015 | Pride Jazzy 614 Hd JAZZY 614HD
What is making creaking squeeking noises in power chair?
hi, that noise can be caused by the seat mount moving slightly within the seat holder, because it 's a tight fitting when it does move slightly , you get the noise...only needs mm amounts of movement, Careful spraying WD40 in the gaps will solve this but take CARE making no electronics or electrics are near...disconnecting one battery will be ideal..
a visual inspection of all of the bolts and nuts should prove peace of mind...
WARNING: You need to tip over the power-chair to carry out the instructions set out below so extreme care is required.
This noise can also be caused by the motor gearbox ,, carefully place your hand on the gearbox as someone powers the chair , can you feel a grinding sensation ? , bear in mind you will get some feeling there of a dragging.
Regards
Rob
www.gewizrepairs.co.uk
Oct 10, 2014 | Pride Mobility Jazzy 614 - Jazzy Blue,...
My 2000 passat just started making a loud noise when i accelerate and it seems like its moving slower in acceleration and reving higher
my good friend I believe the solution I give might be not good for you as to what you state It sounds that you are loosing your automatic gear box. Have you ever changed the oil & filter of your Gear box? If not that was the reason.
Aug 15, 2012 | Volkswagen Passat Cars & Trucks
2001 ford windstar the right axle spin slower then the left one. What can be the problem i both two new axle and it stil spin slower then the right but it move better do i need to rebuild the trans
I don't think you can assess the condition of the transaxle by spinning the wheels.
The differential in the transaxle converts power from the transmission to the wheels by a set of gears. It would almost impossible for one side to turn at a different speed than the other.
You may have more drag on the brakes on one wheel, or the fluid in the transaxle could cause one side to go slower with the van off the ground.
Jul 05, 2012 | 2001 Ford Windstar
The right wheel seems not to be working smoothly. When I try to drive straight it veers to the right slightly, like the left wheel has more more. It is also hard for the chair to turn left because the...
Hi Jack
Sounds Like all you need is for a technition to program you chair. They can do an adjustment to compensate the different strengths of each motor and make the chair run straight Also to improve the turning speed adjustments. Programer is a P&G PP1
Good Luck
mimobility
Apr 26, 2011 | Pride Jazzy 1103 Ultra Standard Power...
My laft wheel hancs up. mostly when turning left and feels like the brake is sticking. It will hang up bad enpugh that the chair will not move and the safety lights are blinking when I try to move. After I...
Sounds like you need to replace the left electric brake. The brake is on the opposite end of the motor-gear assembly from the motor. Remove the screws holding the brake on to the gear assembly, unplug it and replace with new brake.
Dec 19, 2009 | Invacare Pronto M51 Power Wheelchair
How to push the jazzy wheel chair when power fails''
There are two levers located on the base of the chair on the left and right sides. Depending on the model, they will be located on top of the base on the front section of the chair base, or on the rear or on the lower sides. Most rotate 90 degrees to disengage the gears so you can manually push the chair. Others are moved up and down, or in and out. Return them to the locked position when done.
Jul 01, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Health & Beauty Logo
102 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
