Question about HP Photosmart C6100 All-In-One Printer
Message saying scanner could not be initialized
    Sergeant:
    Champion:
  • 210 Answers
Can,t get scanner off all channels locked mode
Please try this!!
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works.. Happy Scanning
Nov 20, 2012 | Radio Shack Pro-96 Scanner
After installing the scanner I get a message that says "failure in initialization of scanner. Scanner is ofline or scanner power is off." I have checked all of the cables and the scanner is...
first most computers are plug and play, if yours is not then you need to load the software that came with the scanner, only then will the computer see the scanner
Mar 31, 2011 | Fujitsu fi-5120C
I get a error initializing scanner?
Background of issue- When 4345/M4345 boots up, amber light comes on under start button and the message "Initializing Scanner" is displayed. The unit will print but will not preform any scan functions.
Steps taken to try to resolve issue:
1. Updated firmware
2. Restored factory defaults
3. Took off cover in back of printer covering scanner controller board and reseated all cables
4. Took apart scan unit and cleaned (2)mirrors in scan head
5. Took off back cover of unit, reseated cables coming from scanner controller board
6. Ran Scanner Test, in menu (which everything functions properly)
Usually I would say scanner or controller board has failed but I had 3 M4345 come down with this issue in one week. The only resolve i've found for this issue is repetitively turning on and off the unit until it comes up without "scanner initializing" message. Once it comes up it functions 100% until the unit is turned off and issue will come back.
I'm at a loss here with so many units having same issue, open to any advice. I once took the formatter out of bad unit and put it in good one and it caused the issue in the good one but i'm double verifying this tonight. Thanks for any help.
Nov 17, 2010 | HP LaserJet 4345mfp Printer
I have A radio shack PRO-2096 and have not been able to use it in over A year. it reads all channels locked out. I can't unlock it.can someone please help me?
Please try this!!
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Jun 23, 2010 | Radio Shack Pro-2096 Base Scanner
IT WON'T BUDGE. IT READS ALL CHANNELS LOCKED OUT. PLEASE HELP
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Hope this works happy scanning!!
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
A message appears saying "scanner could not be initialized (scanner not found)"
Try shut down pc,then unplug the scannner usb.
Restart the pc and plug the scaner in and see if it finds it then.
Nov 12, 2009 | HP ScanJet 2300C Flatbed Scanner
HP color laser jet 2840. During initial power up/calibration, scanner bulb starts to click (and flash on one end), screen goes blank. Many people report similar problems. Some say it's a problem with the...
If the equipment shows the message "Scanner bulb warming up" and not initializes, look resolve:
Well have to clean the scanner assembly. Contains about 4-5 mirrors. It is very difficult to disassemble, careful to clean.
From here you can get service manual. There are 6 parts. put them all in a folder and a unzipp the first.
http://eserviceinfo.com/downloadsm/34029/HP_2820,2830,2840.html
Oct 09, 2009 | HP Office Equipment & Supplies
Scanner will not initialize
When I try to scan a picture a message comes up that says "A problem prevented the document from being scanned." What do I do?
Sep 16, 2009 | HP Scanjet 5500c Flatbed Scanner
HP Scanjet 4400c not recognized by Windows XP Home Edition
Try downloading the drivers from the HP website at: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=61902&lang=en
May 01, 2007 | HP Scanjet 4400c Flatbed Scanner
HP Photosmart C6100 All-In-One Printer Logo
Seeker5211
Seeker5211
