Question about Abit A17 Guru Motherboard
My cmos battery is not working and iit show cmos failure
    Sergeant:
    Champion:
  • 210 Answers
So change it... big deal...
Posted on Mar 17, 2011
LONG BEEP AND CPU FAN NOT WORKING
The continous beep usually means a memory failure (RAM) or video memory if a plugin card is used.
Check to be sure the unit sees all of the memory, a weak power source( without AC adapter) could cause a partial failure of one memory card.
Another fault would be that the battery is very low on charge and won't accept any charge.
BAD Battery.
make sure that your RAM modules and Cmos battery sockets are clean and dust free and the ram modules are securely seated in some motherboards cmos batteries are soldered in
hope it helps
May 30, 2012 | Computers & Internet
Tip
CMOS battery failure
This is a very easy and money saving tip for all,whenever your PC on starting shows CMOS battery failure it means nothing so complicate has stopped working just a button cell has lost its charged and needs to be replaced because if don't do so there will be lots of problem such as if you open a mail lets say Google it wont open because CMOS battery stores Time details and if it has stopped working time will be wrong and Google mail wont work so the solution is to just open your PC and you will see a small button like cell which you can remove easily and can be changed.
Hope this tip will help you in your problem.
on Jun 21, 2010 | Computers & Internet
Locate CMOS battery Lenovo Y570
It should be on your motherboard. You have to carefully disassemble you lap top .. Removing all Usb,Battery, and external connections.
U need a small screw driver to take it apart.
Leave your computer on for a day. If your need specifics let me know!
May 07, 2012 | Lenovo IdeaPad Y510 Notebook
Cmos battery error failure
The CMOS (BIOS) battery keeps the computer'a comfiguration and the Date & Time settings in the CMOS (BIOS) chip in its memory. When the CMOS (BIOS) battery is flat these configuration information is lost.
Replace the CMOS battery with a new one, in most cases this battery is a lithium 3 volt battery type CR2032 and it is coin size battery 18mm in dia.(check it to make sure the type of battery is installed on your motherboard).
When you replace this battery then go into the BIOS and set the Date & Time etc.
Jan 26, 2012 | Intel DG31PR Motherboard
My girlfriends Hp Pavilion A305W powers on then automatically powers off after it show a brief error message but also says F1 for startup. Should i press F1 and continue diagnosis?
Most probably your system is not getting your BIOS settings from your mainboard due to CMOS battery failure.
Check your CMOS 3.0v battery & replace it. Then reconfigure your BIOS settings from the CMOS setup.
Hope it helps
May 28, 2011 | HP Pavilion a305w (DM181AR) PC Desktop
When i restart my computer it shows cmos time is not set and cmos battery failure then after this mes i changed the battery and set the cmos time correct. it works properly till one day and another day it...
I had the same problem one week ago. Check if your SMPS power connection is OK. If it's OK, then you may have to change your motherboard... I mean may be your motherboard is corrupted. Open your cabinet, unplug all the components and clean the whole cabinet properly and re-assemble all the components. Restart your computer but still if the problem sticks be sure to check your computer with a well-knowledged hardware mechanic because there may be other causes.
Dec 22, 2010 | Computers & Internet
My msi u100 mini laptop won't reboot
Hello..
When you encounter this kind of problem you need to check directly to the HDD. This is an HDD problem which the cable are not good. Try to change the SATA or IDE cable. Or you may reset the CMOS jumper you can see the CMOS jumper near the CMOS battery. Good luck!
Jan 09, 2010 | MSI Wind U100-030US Laptop
My PC is not booting!!
first try to boot with new ram or try your ram in other cpu to confirm that its due to ram problem or something else......then try to replace your cmos battery or chk it with multimeter whether its working or not then try to change SMPS with new one............
Sep 28, 2009 | Computers & Internet
Cmos battery failure even after changing the battery
may be the replaced battery is not working too. please try another battery or first make sure, the battery you placed is working ok.
May 24, 2009 | Intel Motherboard
I have a Dell dimension 9150 which is 2 1/2 years old. Does it have a battery that I need to be concerned about replacing. I remember that used to be a problem with computers but don't know if that is...
Every PC motherboard has a battery. That battery serves two purposes: to feed the configuration memory (also called CMOS) and to feed the real time clock of the computer (the one that show the date and the time).
An indication it is time to change the motherboard battery is receiving one of the following error messages when you turn on your computer: CMOS CHECKSUM FAILURE, CMOS BATTERY STATE LOW, CMOS SYSTEM OPTIONS NOT SET and CMOS TIME AND DATE NOT SET. Another indicator of a low battery is a clock that, after being set, runs well while the computer is on, but shows the wrong time when the computer is turned on the following day (it is late).
Apr 21, 2009 | Dell (2336V) Motherboard
Abit A17 Guru Motherboard Logo
24 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
