In most of the Amplifiers we have only Bass and Treble control (Bass works on 100 HZ and Treble works on 10KHz - approximately). In some Amplifiers we have Mid range control also. What is the frequency range it will control. Now a days Equalizer equipments (5 band, 7 band ...) were becoming less important. Is this statements were true.
  • 484 Answers
The frequency of mid range control is about 1KHz. The bass and treble are usually enough to set the tone of sounds and music, and if the customer has high quality speakers connected to the amplifier it is almost unnecessary to modify any tone. In my opinion you are right that x-band equalizer became less important now.
Thank you.
gylacz
Posted on Mar 17, 2011
Testimonial: "Good answer - what I hear more nowadays"
  • 1 more comment
  • Gyula Lacz Mar 17, 2011
    I was glad your fast testimonial, thanks!
  • Jai Durai Mar 18, 2011
    "if the customer has high quality speakers connected to the amplifier it is almost unnecessary to modify any tone"
    Does the above statement indicates the quality of the speakers or Cross work. I am having 2 way speaker One 8 inch Woofer (Philips) Product and another 2 inch tweeter (brand not known). There is no cross work implemented in the Speaker box. Is that is very mandatory.
  • Gyula Lacz Mar 19, 2011
    You wrote "There is no cross work implemented in the Speaker box"
    I'm not sure whether I understand well you mean, but if there is a speaker box with woofer and tweeter it is mandatory to be equipped a cross filter inside. The main reason is the high energy bass frequencies will destroy the tweeter which has usually less power and doesn't stand high amplitude mechanical movements.
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
Yamaha AX-596 bass & treble control panell not working
Make sure there is no tone bypass button if it has one.
Apr 26, 2014 | Yamaha AX-596 Amplifier
What are the frequencies that the bass and treble controls on a Yamaha AX-396 amplifier control? I recorded alot of music direct from the amp to my pc with the bass and treble controls at max and need to...
The bass and treble controls (as well as volume) have no effect on the recorded output if you're using the traditional jacks a tape deck would use. Only PRE-OUTS get massaged by sound controls.
Even if you DID affect the recorded signals, WHY are you using such exaggerated settings? Or was it by mistake?
In theory, passing the modified output back through the same controls (set to Minimum this time) would undo most of the unwanted effect. Assuming their precise and mirror image for gain and loss.
Aug 23, 2011 | Yamaha AX-396 Amplifier
Thanks for the answer - If we have 3 controls as Bass, Mid and Treble. If we keep those in 12 O Clock position, will the output level be equal. In using the Bass and Treble control only (if we have...
If all are in 12 o'clock position they are "flat" (nothing has been added or subtracted foam input signal) If you only have bass & treble, yes adjusting will affect "mids" but Mids change can go both ways dependent on increase or decrease of Bass and /or treble. By increasing bass you will pull some mids up also. By increasing treble you'll subtract some mids.
Mar 17, 2011 | Audio Players & Recorders
I just got one what is it an how does it work an how do i hook it up?
2 channel power amp
you will need additional equipment for this beast to work right.
1. you need a pre-amp, all audio connections go into the preamp which control sorces, volm, bass and treble.
2. out from the preamp into the power amp and out to your speakers
3. you can freak it if you have an 1/8" stereo to RCA stereo plug in this caee you can play your ipod, phone or mp3 player thru this amp using your input device (ipod, phone or mp3 player ) like a preamp to control volm, bass and treble.
Feb 21, 2011 | Sharp SX9860 2-Channel Amplifier
Bass and treble controls
You should check the Direct button is pressed or not.
In Direct mode, it by passes the treble and bass circuitry so you will not hear any difference even if you turn it.
Jul 24, 2010 | Cambridge Audio Azur 550A Amplifier
ONKYO Tuner/ amplifier R-100 Need PDF Manual
The tone controls are only on the remote, Part number RC-174S. I can create a PDF of the manual if you still need it, just post here.
Oct 25, 2009 | Audio Players & Recorders
No manual for my amp.
  • Class-D Monoblock Amplifier
  • Bass Boost Level and Frequency Remote Included
  • Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
  • Variable Input Sensitivity: 200mV - 5V
  • Phase Shift: 0° / 180°
  • Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
  • High- and Low-Level Inputs
  • 1 Ohm Stable
  • RMS Power Output:
    • 500 watts x 1 chan. @ 4 ohms
    • 900 watts x 1 chan. @ 2 ohm
  • Preamp Outputs: 1 Pair
  • Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
  • Dimensions: 15" L x 11-5/16" W x 2-3/8" H
Oct 05, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Bass/Treble balance on Bose Lifestyle 5
You need to go into your menu and set the "MOVIE EQ" to your liking. That is where your bass/treble balance is on a Lifestyle system.
Mar 01, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
Spares
Bass Treble,bal controls can be clened with contact cleaner.
Drive belts audio heads may be available at the sansui web site or mcm electronics.com.
GOOD LUCK
BIGRED
Apr 01, 2008 | Audio Players & Recorders
337 people viewed this question
 Grubhead
Grubhead
