Question about Watches
My watch just stops several times a day. I bought it 2 weeks ago.
  • 3 Answers
Most likely a factory deficiency, I would suggest taking it back to the store and getting it returned.
Posted on Mar 17, 2011
Just bought a Longine watch L4.309.5.57 automatic, can i use it during sports e.g. Aerobics class and cycling?
I had a similar problem. I had no trouble with ordinary mechanical watches but when lcd electronic watches hit the market I tried a change and bought one which was replaced several times while all my friends had no bother at all.
These days I rarely wear a watch because mostly I no longer care what time it is and my phone has the time on it.
Longines watches are a reasonable quality but an automatic watch is really only suitable for normal everyday activity and such things as aerobics is likely to severely shorten the life of the mechanism. The original "activity" watch was the Swiss incabloc movement but the people who could afford to buy such a watch would not dream of wearing it while performing vigorous physical activity.
I imagine the only watch that would have a chance of standing up to sustained punishment would be a quality digital watch.
A fob or pocket watch would be a sensible alternative. There have been a wide variety of sports fob watches produced, many of them combining timepieces with stopwatch and timer functions.
I hope this helps.
Apr 12, 2016 | Watches
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
How do I set a Danbury pocket watch with date display
If it is this pocket watch, then the crown (the bit you turn to wind the watch) has 3 positions. Position 1 is when the crown is pushed in all the way. Position 3 is when the crown is pulled out as far as it will go. In between position 1 and position 3 is a place where the crown will stop, this is position 2.
To set the day of the week, pull the crown out to position 3 to set the time. When you set the time, the bottom dial with also turn to set the hour on the 24 hour clock, if you turn the crown enough to cycle through a whole day the day of the week dial will also turn. Keep turning the crown until the time is set on the proper day of the week.
To set the date, pull the crown out to position 2, and turn it clockwise until the hand on the date dial points to the correct date.
Hope this helps!
Sep 01, 2012 | Watches
My watch stops working, the mechanism works on motion or kinetics. However, even with a bit of a shake it works for a bit then loses time and stops altogether
It may require rather more than a bit of a shake! Some makers say that you have to swing it gently form side to side for 200-300 times to fully wind up the watch.
I bought one some years ago that didn't work well and I had it cleaned, after which it worked perfectly for years.
If giving your watch the shaking I described above it still does not work, try having it cleaned.
Automatic watches thrive on being used but should run for 2-3 days before stopping.
Mar 08, 2011 | Jacques Lemans Classic Automatic...
Tag Heuer 2000 Automatic not moving
Sounds like your watch is in need of service. All watches need to be maintained and regular service is required. A watch is a tiny machine. So if you think about it a car needs regular maintenance to keep it running and so will any machine.
In a watch the oils dry out after about 3-5 years and they stop lubricating. Just like in a car when the oils stop lubricating the engine will stop, a watch will stop.
The reasons for this are 1) no lubrication means high friction on the moving parts. 2) the dried oils become gummy like glue and hold the gear train in place which keep the gears from moving.
The only answer is to have your watch serviced to get rid of the old lubrication, clean and replace any worn parts, then reassemble and lubricate, and finally adjust the timing.
This is something only a watchmaker should do as the parts in your watch are very small and very fragile. Improper handling can permanently damage the parts.
Hope this helps,
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
May 24, 2010 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
Is my watch authentic ? I purchased a Hamilton H77646833 Khaki X-wind Mens Watch several weeks ago and have had issues since day one. 1. The date and day function didn't work. But now it does. 2. The watch...
RECOMENDATION:
Seek professional help.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 21, 2010 | Watches
6 monts old quartz model vz03-dd 2 weeks ago hands stoped, after adj. runs fine now all stops , no hands movement, no display.
Replace the battery. Does not matter watch is just 6 months old - battery was fitted long before you bought it.
Jan 24, 2010 | Watches
Blue angel watch resets to 4:00pm all the time after being set.
I think it is time your watch received a Citizen tune up. Start here ... http://www.citizenwatch.com/
Thanks for posting your question to FixYa.com
Please vote
thanks
a
Nov 19, 2008 | Citizen Blue Angels Skyhawk Watch
Citizen wrist watch stops working
A lamp may be to hot while the light may not be sufficient. Put it in a window sil for a week or so.  Look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
May 25, 2008 | Citizen 8700 BL8000-54L Wrist Watch
Watches Logo
32 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
