Question about ACCO Brands Rexel 3250 s3 Shredder
Paper jammed and can't get top lid open Rexel RLS32
Rexel 100X. Why does it work for 2 seconds in reverse only, then jams?
From your description, experience tells me there is something jamming the mechanism. If plastic or clay coated material has been shredded, there will be residue between the grinding wheels that will require use of a utility knife and a pick to remove bit by bit. You will have to apply power periodically to rotate the mechanism and give access to new areas to be cleaned.
Dec 26, 2015 | Shredder Office Equipment & Supplies
I tried to staple too many papers together using my Rexel Staple Wizard, now it won't work - any ideas?
open and check the clip from where the pins come out for staple. may be one or two pins are stuck in it.
Dec 15, 2011 | Tools & Hardware - Others
I have a very deep paper jam. The paper can barely be seen when looking down into the paper feed. Paper cannot be seen from the front where paper comes out. The paper is apparently folded very tightly...
Hi Rosemary, thanks for contacting me to help you fix your printer problem.
Well, have you tried removing the Paper Trays? There should be two trays and both of them are removable. Once they are removed, you'll be able to see through inside the paper passage in order to remove the jammed papers.
Remove the lid from the top of your printer. This lid protects the scanning bay. With the lid in the fully "open" position, lift upwards on it to separate the lid from the base of the printer.Now, remove the printer paper trays. These trays will pull directly off of the body of the printer. There are two paper trays -- one on the top of the unit and one on the front of the unit, beneath the control panel. Once they are removed, you will be able to see inside the passage where the papers are usually jammed. If your fingers can't reach the jammed papers, use a pair of tweezers to remove them. If you still have problems, let me know.
Good Luck.
Thanks for using FixYa.
Regards,Nonontech.
Oct 03, 2011 | Lexmark X5495 Printer
Paper gets jammed everytime it copies, it would not go through. There's no paper stuck either. Canon MF6530
I am assuming its jamming in the ADF when you are attempting to make a copy, if so open the top lid of the scanner and check both hinges and make sure they are not broken or cracked. The slightest crack in a hinge will offset the paper path and cause jams. If the hinges look good check for a clear plastic mylar strip under the lid, it will be on the left side. If that plastic strip is missing that will also cause jams.
Apr 11, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Laser Jet 4250N Is The jam code B.20.00 paper jam in tray 2..... a service call or can i try to fix it myself?
You should be able to clear this jam yourself
Open the top cover and remove the toner cartridge.
Look inside for jammed paper, and remove it.
Reinstall the toner cartridge and close the lid.
Try that....
Dec 01, 2009 | HP Office Equipment & Supplies
Paper jammed between blades
it must be a switch that percive papers. just in front of the where you giving paper.
May 29, 2009 | Office Equipment & Supplies
Paper jam message brother MFC-440CN
Generally theres still a small piece stuck somewhere. Remove the back where the paper feeds through and check there. Then open the top so you can see the ink head and check around there. That should do it. The printer sometimes wont remove the jam until you open that top lid.
Also try switching it on and off again just to be sure.
If it's still there, the only other way is ripping it apart to find that pesky bit of paper still stuck.
Mar 24, 2009 | Brother MultiFunction Center MFC-440CN...
I have had a paper jam
open the top lid and pull out the paper from the top
Feb 10, 2009 | Brother DCP 130C All-In-One InkJet Printer
Old Rexel 1250 - falsely detecting safety cover is open
You'll have to unplug the machine, then remove the screws front (inside door or cabinet) and rear to remove the top cover. Insure that the safety cover arm which contacts the microswitch is not broken or the microswitch is out of adjustment.
Oct 24, 2008 | Office Equipment & Supplies
Rexel rdx1750 shredder jam
This is the available numbers for ACCO Rexel 0845 658 6600 or 01296 732466/732468 in the UK or you may contact by email mailto:informationeurope@acco.com and this is the web address http://www.acco.co.uk/
Mar 01, 2008 | Office Equipment & Supplies
ACCO Brands Rexel 3250 s3 Shredder Logo
287 people viewed this question
Top ACCO Brands Office Equipment & Supplies Experts
jasbo
jasbo
Are you an ACCO Brands Office Equipment and Supply Expert? Answer questions, earn points and help others
