Simpson Genesis 505 will not complete a cycle without manual assistance to increment into the next phase of the cycle. It will happily fill to the correct level and wash and then semi drain but will not refill to continue th next phase. In the next cycle, it will drain and drain and drain until it is again increment to the next phase. Finally on sppin cycle it must be incremented to spin and then it will continue to spin without stopping and must be stopped manually
  • 1073 Answers
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Posted on Apr 20, 2008
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
jumptrout51
  • 3361 Answers
SOURCE: will fill and drain wont agitate or spin
Replace the lid switch.
Posted on Mar 11, 2009
SOURCE: GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Posted on Mar 27, 2009
  • 1294 Answers
SOURCE: My washing machine is not draining
You can try this: It's for the Kenmore/Whirlpool models..
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels, a good big plastic bag or a wet vac to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Posted on Apr 03, 2009
Why can't I pass my emissions test?
If you had O2 sensor problems, the car would throw up an engine malfunction code.
You could try disconnecting the battery overnight to reset the ECU and emissions data. Run the car for a week of mixed driving and then retest. The test station should give you full info on what caused the fail. I would go somewhere else.
This is a emissions test cycle;
The cycle simulates an urban route of 12.07 km (7.5 mi) with frequent stops. The maximum speed is 91.2 km/h (56.7 mi/h) and the average speed is 31.5 km/h (19.6 mi/h).
The cycle has two phases: a "cold start" phase of 505 seconds over a projected distance of 5.78 km at 41.2 km/h average speed, and a "transient phase" of 864 seconds, for a total duration of 1369 seconds.
The dirty secrets of vehicle emissions testing
Oct 03, 2016 | Hyundai 2011 Genesis Coupe 3.8 R-Spec
Hi, I am Hoping for a Service/Repair Manual for a Simpson Espirit 450 Top Loader. I think it has Shorted out and needs rewiring or a fuse replaced(If they have Fuses)
I went google and typed in-- workshop manual for simpson espirit 450 top loader washing machine -- and got several pages one of which is www. manuals. club
I suspect that you may have to pay for the manual but on their page there is a listing for user manual, installation manual, service manual, parts list and schematics
try and see if you get what you want
there may be a loose connection to the program board or a faulty program board but I doubt that you will need a rewire or anything drastic like that
Dec 07, 2015 | Simpson Washing Machines
Brake band for Simpson Genesis 505 heavy duty washing machine
www.searspartsdirect.com or www.applianceparts.com. If the brake is internal with the gearbox, chances are the only way to replace the brake is with a new/rebuilt gearcase.
May 10, 2012 | Simpson Washing Machines
My Simpson eziset 650 won't complete a cycle it
The machine has detected that it's taking too long to fill, check the hose filters in the inlet solenoids (remove the hoses and you will see them) make sure your taps are turned up, If all seems ok then you have work inlet solenoid(s) and will need to replace 1 or both of them depending on if it does it on both hot and cold cycles.
Mar 05, 2012 | Samsung Washing Machines
A manual, for a simpson genesis 505 washing machine, heavy duty
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 30, 2011 | Electrolux Washing Machines
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
My simpson top loader will not complete cycle.
More likely than not it is your control regulator gone out. This is where your rotary knob is.
Dec 07, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
