Question about Nikon D40x Digital Camera
How to put back the lens? - Nikon D40x Digital Camera
    Champion:
  • 226 Answers
Hi bleamarissa, i send you a illustration.
Regards
Posted on Mar 19, 2011
Hi, Hope u can help. Dropped the camera. Now when I go to turn it on it says, Lens error,
you possible bent the lens or the connectors of the lens.
do you have a camera with removable lens, just remove the lens
put another lens on, try take photo's, check the color and layout, view the photo, than try putting the old lens back on, see if if works,if you have the same results, than the lens maybe damaged
see if the lens is under any type of warranty, c/c, bank card.
contact dealer or manufacture or camera or lens repair shop to see if it is worth trying to fix or buy a new one.
www.BandH.com/service
18009479980
www.beachcamera.com/service
180057beach
www.adorama.com/service
18002232500
pick up any photo magazine look in the back for camera and lens repairs, or lens company talk to a service technic.
Sep 18, 2015 | Nikon COOLPIX Cameras
I mistakenly dropped my digital camera a few inches when the lens was out.When i tried putting it off to know if the lens would go back in,it didnt move so i forcefully pushed it back inside.Now, when i...
You've likely jammed the zoom motor in the lens. You're correct in thinking that the camera can't work without the lens out. With it being physical damage repairs wouldn't be covered under warranty so you either need to pay to have it repaired (if that's even possible, it varies camera to camera) or buy a new camera unfortunately.
May 11, 2011 | Cameras
Err message appears on the display of my D80.
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Nov 08, 2009 | Nikon D80 Digital Camera with 18-135mm...
The screen reads "lens error, restart camera. I can not get the lens to retract. I can not get the power to stay on. The cannon screen shows up momentairly - but fades to black and the message appears.
remove the battery, let it sit for at least 2 hours, then put it back. put the batteries back, then gentle push the lens sideways to free its stuck part. if the error still occurs and the lens is not retracting, consult the warranty for the device as the lens assembly gears may be at fault.
regards,
voodoo
Aug 12, 2009 | Canon PowerShot SD1000 Digital Camera
Lens cap stuck
I was messing around with this today, ended up where it seemed in was working.
Power up, let lens out, then take out batteries. Pry off silver band patiently using fingernails. Then pry off overlying black plastic piece. There are four units underneath, pay attention to how these are put on, mine popped off, but it wasn't too hard to figure out how to put back together. There are pins and holes and kind of fits like a jigsaw. Once off clean with alcohol where you can.
Put batteries back in and open and close a few times. This will help understand movement where pins of lens cover pieces go. When putting these back on make sure camera is in off position.
The lens cover pieces need to be put on so that the pin portion has some resistance. Move one so that it drops in then push up to get other in place. Let them come together and hold these in place.
The two smaller pieces will close the cover. Put the hole of the closer piece over the pin. Then move slightly so you can retract spring with a small instrument and subsequently engages pin on closer. Place top black piece back on, then silver.
This worked for me, hope it does you also! Good luck.
Dec 03, 2008 | Canon PowerShot A510 Digital Camera
Lens error 12 appears on screen, lens wont retract and camera turns itself off. How do I fix this
It is very easy to fix. Just Be Very Careful when doing the following Repair.
You will need the Following a Size 0 Screw Driver, and a Small Eye Glass Flat Head Screw driver.
1. remove the 4 Screws holding the side panels. (Make sure you do not mix these screws with the ones on step 2) as these screws are shorter.
2. Remove the 6 Screws on the bottom of the camera
3. Now carefully pull apart from the bottom up. You will see 2 more screws on the left side but do not remove them.
4. Seperate the Front faceplate carefully around the Lens assembly.
5. while keeping the Camera with the lens Facing Strate Up, remove the Two Screws on the right side of the Lens, but keep caution not to move the camera while the screws are out of place.
6. remove the Cover to the Lens Gears.
7. Now this is very important!!!!, Take the Small Eyeglass Flat head Screw Driver and Pry the Gear To the Left, not the one by the motor. you do not have to take the gear off, however just enough to allow you to Move the Lens Assembly manualy.
8. Turn the Lower half of the Lens assembly carefully until the Lens is compleatly In and lens protector flaps Shut.
9. Put the Gear back on.
10. put the Gear Cover back on and Screw the Two screws back in. Make sure they are Firmly tightened
11. Put the Front Face Plate back on by putting on the top first, then closeing the bottom.
12. make sure the side pannel with the Wrist Strap is in Correctly before screwing it in.
13. Place the Side Pannels back on and Screw them in.
14. Screw the 6 Bottom Screws back in.
Now put the Battery Back in and test it out. This should fix the error you were having. i just perfomed this on my camera 15 min before i Wrote these instructions it worked! Step 15 get back to taking great shots!
jakthebomb
Nov 24, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Putting it back together
In 1965 I did the same thing with a Nikon single focal length lens my F Photomic. This lens was far more simple then a modern AF zoom lens. I had to bite the bullet and pay a camera repair man to fix the lens. He told me that had I not tried to fix the lens myself, the repair would have cost 1/4. The only answer to your question is to take it to a camera repair man and get a quote. I would check the quote against the price of your lens on E-bay and use that to determine if you want to fix your lens or replace it.
By the way, it is very rare for dirt between elements to be so problematic that it results in a degradation of picture quality.
Aug 05, 2008 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
My nikon says lens error
my camera says lens error. the lens is also stuck in the position as if it where taking pictures. it will not retract.
Jun 16, 2008 | Nikon COOLPIX L5 Digital Camera
Frame around lens fell off
Do you mean the focussing ring fell off?
It can be reglued with Superglue, but be very careful not to use the glue from the tube or you could get it everywhere. First focus the lens on infinity. This is the furthest back or most withdrawn position of the lens. The infinity marking on the ring will be beside the diamond or dot indicator. Put a little bit of Superglue onto the end of a matchstick, and then use the matchstick to put traces of the Superglue on the lens barrel, exactly where the ring will sit. carefully place the ring on its correct position on the lens barrel.
May 27, 2008 | Casio Exilim EX-S500 Digital Camera
Dropped camera lightly, lens wont retract
my acm dropped and i messed up the lsenes it wont go in please help me how can i fix it my self?
Nov 03, 2007 | Canon PowerShot A540 Digital Camera
Nikon D40x Digital Camera Logo
14 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
