Question about Western Digital External USB 2.0 80 GB Hard Drive
My 360 GB WD drive isno more detected by PC. last time i used when i it, it was working. no dropping, no damage. light is on as usual but drive is not dteected by pc.
    President:
  • 1,768 Answers
1.you may need to remove the hard drive from the original case and purchase a new case with good electronics.
2. check the USB cord to see if there is any damage.
3. use another USB cable to see if the hard disk is recognized by the Operating System ( my computer or "compute" in Windows 7.
Posted on Mar 17, 2011
My WD my passport not working
maybe the cable plug of the WD my passport is broken
Apr 18, 2013 | Western Digital My Passport Essential...
750GB My Passport Essential SE was working fine. Today I took it out of its case and plugged it in to my PC. Light came on for a bit, then started flashing. It did not appear on my Desktop as usual. Not...
If the drive is not spinning up, then you may have a damaged pcb, Have you tried this drive on another system. If your drive uses the mini USB connector. I have found that the solder joint is not soldered properly, I had the same issue, then upon soldering the connection USB connector at the pcb of the enclosure( not the drive) this fixed the problem. Let me know what you find, Dennis Sigala Computer Design Technologies, LLC
Jan 10, 2011 | Western Digital Passport WDXML800UE...
WD My Book Studio Ed. (Mac) - 2TB - stopped working for no reason
plug your drive in to your computer, right click
on my computer and bring up disk manager,
open disk manager and see if your wd drive
shows up. then reinitialize the drive and this
will hopefully solve your problem.
Aug 21, 2009 | Western Digital My Book Home Edition 500...
I have a 120GB Western Digital Passport external hard drive and it will not open up on my pc. the WD passport will turn ''on'' and light up and the pc will detect that a usb is plugged in but it will not...
Sounds like your passport is not working anymore. The fact that it wont work on another computer is a solid sign that something has failed in the device itself. Its possible that both of your comptuers have USB 1.1 but I would think this is unlikely.
I would plug it in to one of the comptuers, then go into your administrator tools then open your computer management tool(start>control panel> administrator tools> computer management). This will allow you to see if windows is detecting the drive at all. Sometimes if the file directory is corrupt, or the hard drive is even partially damaged, then it will not show up under "my computer" but it might show up under your computer management tool. If you see it on there, then there is probably something wrong with the hard drive that is not allowing the computer to recognize the device, or at least install it properly. If you dont have any crucial data, you can just simply reformat the drive and it might start to work after that. If you do, then you might have to take the thing apart and transfer the data by using the hard drive like it was just another drive on the computer.
If your computer does not detect the drive at all, not even on comptuer management, then I suspect the drive, or at least the adapter part of it is not working, in which case, you will need to remove the drive from the casing and use it as if it was another internal drive, you might be able to reformat it, then put it back in its casing, and hope that it works after that, but I have never taken a WD passport apart before, so I would recommend doing a google search to see if anyone else has done this before.
FYI, when I bought my WD passport, I bought a replacement plan with staples beucase I knew that with all the traveling I did, I would eventually break it. I have dropped it about 3-4 times only after about 4 months, the thing still works without any problems, but that just goes to show how well WD builds their drives, however, I am sure that if I wasn't so lucky, that I would be calling them up right now asking for a new one.
Jul 03, 2009 | Western Digital WD Passport 250GB Portable...
I have a WD external hard drive USB 2.0 750 GB. It was working just fine for many months, and suddenly, my laptop won't "read" it -- it's not listed/detected in "my computer." I thought there was something...
If the device is recognized and not listed as a driver in the Explorer, then the disk is not recognized as having been partitioned and formatted. You can use the Disk Manager to see if there is anything listed on the disk.
Start - > right-click My Computer -> Properties
In the management console, go to disk management and check your disks. The external disk should be there and then you can see the partitions and drives assigned to it.
If there is nothing on it, your MBR could be damaged, which needs to be restored.
Alternatively you could partition and format it, but then you'd loose the data on it, so that is a last resort.
I think a program called Acronis Disk Director Suite can restore MBR's. Have a look at this external hard disk troubleshooting article.
Jun 13, 2009 | Western Digital Elements powered by WD 320...
WD 250 GB external hard drive is not being detected by system
Hi !
First check if your WD is running (spinning), no matter if the blue light is on. Can you hear it close with your ear, or feel vibrations on your hand when it starts.
If it runs, then check/replace the USB cable you are using with another.
Check the Power supply if it gives necessary power.
If you are familliar with disassembling/assembling, then open and remove the HDD from the box and try to connect the disc directly to your PC (using another HDD Data/Power cables).
If it runs, and you can acces it, then something is wrong with the Box.
If it doesn't, then the HDD is broken or damaged.
Please note that if your device is under warranty, DO NOT open the box ! Contact your seller for service/replacement instructions.
Regards.
Mar 25, 2009 | Western Digital WD Passport 250GB Portable...
WD 500GB external hard drive won't load on new macbook
Dear Sir,kindly note this problem usually caused by a firmware damage,so you need find a dr company to use tool to repair the firmware,you can contact with me :honglake@gmail.com
Mar 19, 2009 | Western Digital 500GB My Book Pro-External...
Not Detected on PC
Since you say that it is detected in Device Manager and is shown as working properly, it would appear that the problem is that it is not getting a drive letter. Have you added anything recently that might take up a drive letter like a flash drive? If so, try removing both and then plugging the WD back in. If this is not the case or does not help, do this:
Assuming you are using XP.
Right click on My Computer and select Manage
The computer Management window will open, click on Disk Management
Do you see the WD in the window on the right?
Does it show a drive letter?
If not, you can assign it one by right clicking on it and selecting Change Drive Letter and Paths ...
If the WD does not show up in Disk Management, possible problems are:
1) USB cable is damaged, try another one.
2) USB circuits in the WD case not working properly, hard drive can be removed and put into another case.
3) WD USB case is good, hard drive is good but there is a loose connection inside. Open case and reseat everything.
4) WD USB case is good but the hard drive inside has gone bad (worst case scenario)
Sep 27, 2008 | Western Digital Passport WDXML800UE...
Imation Swivel Flash Drive Cant detect
is it several times that youve used your flash driver at your office? and which side of the usb port did you plug it? coz when it is your first time to use your flash drive at your office and your plugging it at the front side of the PC. well there might be something wrong with connection and may cause damage to the board of the flash drive. if it your using it several times, well try to check at your PC, then do the following specs:
my computer (right click and select manage)
and under manage window ( select disk management )
try to see if your flash drive registered (you can see the drives of your PC) and see if theres a volume (either raw/ or theres a partition on it).
if not, well the board of your flash drive might be damaged, mostly these were caused by the power of the system, fluctuation is one of them, then improper plugging of the flashdrive.
Mar 12, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Western Digital External USB 2.0 80 GB Hard Drive Logo
73 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
