Question about Olympus FE-280 Digital Camera
Just plain out not working
When ever i turn my camera on it has the red light on. And when i try to zoom, it will, but it won't stay there. And then wehn i try to veiw my pictures it wont let me and it wont let me take a picture. In fact it wont let me do anything but turn it on and off!
I've got the same problem. Did you find a solution ???
John
Posted on Aug 05, 2008
Zoom lens stuck closed
Here are some troubleshooting steps that you can try that may (or may not) correct your problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
And here's a video summary of the steps:
Dec 24, 2011 | Fuji FinePix A340 Digital Camera
Dropped camera leads to zoom error and blurry pictures. HELP!
Your lens was damaged and probably needs service. This could be expensive so get an estimate first to help you decide what to do.
Nov 10, 2011 | Fuji FinePix S1000FD Digital Camera
My Minolta Freedom Zoom will turn on and zoom but won't take pictures. The numbers dissapear when you try.
Hi. It could be that the camera needs more memory. Also replace your batteries. if the batteries are low the camera won't run properly.
Jun 26, 2011 | Cameras
My casio exilim ex-z60 wont switch on, I put battery in charger for hours and light flashed red constantly (overnight) so I plugged it into the computer with USB but nothing????
Thank you every one who posted solutions.
I was all set to try the 9 volt trick until i realised i didnt have one so i tried someone else's suggestion of constantly re-inserting the battery until the red light stays constant. Touch wood, but it seems to have worked.
Dec 30, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Zoom Lens stuck out, won,t close. Says camera problem #E45
that error code indicates the the Lens of teh camera is already defective., In most cases if the lens is stuckout or stuckin camera will not stay On or It will not Turn On at all. For this case you need to call Tech support to send you camera for repair toll free 1 800 235 6325 extension 12
Nov 12, 2009 | Kodak EasyShare V530 Digital Camera
Camera on for 5 seconds red flashing light then turns off
that definitely sounds like a battery problem.
when you charged the battery, did the light stay red, and then turn green when it was finished?
if it flashed red, try this:
MATERIALS: 9 volt battery, 2 pieces of wire the same length, casio battery
DIRECTIONS: connect the + sides of each battery with a wire, and the - sides of each battery with another wire. [I just held them there, but maybe you can tape them if you're having trouble.] Hold it for 30 seconds. Then try charging it. If it doesn't work keep trying it until it does. TRUST ME! It took me 5 times to do it effectively.
If your battery has gone too long without charging, sometimes it won't charge correctly any more. So do this.. IDK why it works, but it did for me!
Nov 19, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Built-In Speedlight (Flash) will not retract
I haven't heard of this problem but compliments of velocityreviews I came up with this. Follow the instructions below to attach an external Speedlight. Refer to your Speedlight manual for detailed instructions regarding Speedlight operation. 1 Make sure that both the camera and the external Speedlight are turned off. 2 Attach the Speedlight to the camera accessory shoe. 3 Turn both the camera and the Speedlight on. 4 Set the external Speedlight zoom head to an angle wider than 28 mm. If you are using a Speedlight with Auto Power Zoom, set the zoom head angle manually. The COOLPIX5700 does not support power zoom. 5 Set the external Speedlight flash mode to TTL. At this setting, the amount of light produced by the external Speedlight is measured by the camera?s photocell, and the flash shooting range adjusted automatically to ensure optimal exposure. D-TTL flash control (available with the SB-80DX, SB-50DX and SB-28DX) is not supported. 6 Take the picture If the Speedlight Options: Speedlight Control option in the SET-UP menu is set to Auto, only the external Speedlight will fire. If this option is set to Int & Ext Active then the external Speedlight and the builtin Speedlight will fire at the same time. The COOLPIX5700 does not support AF-assist illumination, or red-eye reduction using the red-eye reduction lamp on the external Speedlight. At a setting of STBY (standby), the Speedlight will turn on automatically whenever the camera turns on but will not turn off automatically when the camera turns off. Exact functionality varies with the Speedlight in use. Refer to your Speedlight manual for details. I hope it's of some help BMW
Jul 07, 2006 | Nikon Coolpix 5700 Digital Camera
Olympus FE-280 Digital Camera Logo
64 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
