All color of the canon ip 1980 printer are okay to print... there's no problem to it, but blue is not working... even i have to head clean 10x and deep clean 10x... there is nothing change... the blue ink is not running to the tube ink of blue... what can i do if the blue is not **** and not going to the ink cartridge...
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Posted on Mar 17, 2011
Canon pixma ip 1500. Will not print black ink. Have cleaned, and deep cleaned nozzles. Color prints good, black does not print at all.
Jul 01, 2011 | Canon Office Equipment & Supplies
Canon iP 90 printer problem The blue ink is not printing out - have changed the ink tank but make no difference and the blue colour is printing out a pinkish colour. Genuine Canon ink tanks are being...
It looks like the blue print head is blocked, have a look on ebay, you can get head cleaning kits for just a few £/$.
Here's one :- Item number: 380304689134
Replacement print heads usually work out more expensive than a replacement printer.
Apr 16, 2011 | Office Equipment & Supplies
My printer is canon pixma ip 1980, its orange light is blinking 7 times, it says the cartridge is not installed properly (but i did not even touch the cartridge), how can fix the problem? pls help, i need...
Remove the cartridges, clean the contact points and heads using a soft brush (you can clean them using the brush dipped in alcohol or acetone or spirit). Reinstall them and switch on the printer. If the problem persists, try with another cartridge/s, it's also possible that one of the cartridge/s is/are bad and no longer usable. In that case, you'll need to replace it/them.
Good luck.
Thanks for using FixYa.
Aug 15, 2010 | Canon PIXMA iP1800 InkJet Printer
MP530 all in one printer - bought Staples magenta & blue inks but printer won't print those colors but did print older Canon inks not needing replacing; bought new Canon magenta & blue inks but...
What you can do is take the ink cartridges out of the print head and remove the printhead. Hold the print head over a trash can and take some 409 cleaner and spray the little pads inside the print head til you start noticing the colors dripping into the trash can. You will them want to dry off the print head as much as possible and litely wipe off the outside and the bottom of the print head with a paper towel. Then reseat the printhead back into the printer and the inks. You will then want to run a nozzle check from your printer software or from the printer properties. If the inks still are not showing up run one or two cleanings. If the issue still persists then you might have to replace the printhead. If this is the case you can look up part number: QY6-0059-000 online to replace the print head.
Jun 30, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon ip 1980 offline problem
Saya Punya Printer Canon IP 1980, printer sudah terkonek ke PC driver sudah ok tapi ketika saya print tidak ada respon sama sekali saya cek kabelnya bagus tidak ada masalah . kepada para sahabat saya minta bantuannya dan solusinya ? ...
May 31, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip 1200 colored print problem but b & w is o.k.
You should run the cleaning program for the color cartridge 4 or 5 times, or until the printing looks okay. If things do not improve after the fifth cleaning, you may have to take the printer to a repair depot.
Jul 10, 2009 | Office Equipment & Supplies
Will not print blue
clean head cardrige and calibrate color cardriges.
Jun 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Mar 18, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Jan 13, 2009 | Canon I960 InkJet Photo Printer
115 people viewed this question
jasbo
jasbo
