Question about Kitchen Ranges
The cleaner works fine at the begining for a few minutes, then the motor changes into a faster speed mode and the cleaner then doesn't **** up the shampoo off the floor anymore, it seems like a switch has tripped and stopped the machines suction
  • 2,510 Answers
If a motor speeds up it shows that the load has been removed from it - no resistance. Check that something is not being sucked up and clogging the pipes or the air outlet. If there is a cut-off float in the container, check that it has not lifted and closed the motor off from the water container.
Posted on Mar 17, 2011
Testimonial: "Many thanks, cut off switch sticking"
Blower Motor Not Working properly
check "amp" at the blower motor! if the "amp" its to high , you better replace the blower motor! It will damge your blower control module soon also!!
Mar 15, 2016 | Cars & Trucks
SLP 222A CD Player - about 25 years old. CDs click/stall/skip on the first minute or so of every cd but play fine throughout the rest. This happens to the initial track/start of every CD even if this part...
As the disk rotates faster in the centre, (track 1) than the later tracks, the spindle motor may need replacing as it can't achieve the correct speed or there is something stopping the laser from focusing correctly at the beginning of the disk. Fluff or a fine hair maybe.
Lens cleaners do not work.
Jan 06, 2018 | Technics Audio Players & Recorders
Bronco stalls in reverse
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control. If the above cleaning doesn't cure your issues you need to have the computer controlled automatic idle speed control system diagnosed and repaired by a dealer or electronic engine control repair shop.
Nov 07, 2012 | Cars & Trucks
I have a 96 f150 5.8 4x4. Starts fine and runs fine, but when I start it after a 5-10 minute stop (when its warm), it will start fine but then die after a minute or so. It starts right back up and I hold...
Common issue on this year and engine, Do the cleaning outlined below.
Throttle Body Cleaning
You can in most cases repair this slow speed stall or unstable idle by cleaning the engine throttle valve and the idle speed control valve using a product called CRC Spray Throttle valve cleaner. Spray the cleaner into the air intake of the engine with the hose removed from the throttle body, the engine will try to stall so hold up the idle speed manually. Once you have used up about 1/2 can of the cleaner stall the engine out while spraying and turn the key off, disconnect the negative battery cable for 5 minutes and then reconnect and drive the car for a about 25 miles of varied driving modes. If this doesn't cure the problem you may need the fuel injectors professionally cleaned by the dealer service dept.
Jun 08, 2017 | Ford F-150 Cars & Trucks
Blower does not activate when a/c mode but works fine without a/c
on your fan motor. red is low speed ,blue is med speed, black is high, red for heating . blue works good for cooling. black is high speed. re look where the forth speed was hooked up. put blue there.
Apr 16, 2010 | Honeywell L4064B2236 Fan/Limit Control...
Johnson 1998 175 hp motor seems to be in safe mode
U CAN DISCONNECT THE OIL RESOVIOR SWITCH THAT TAKE IT OUT OF SAFE MODE BUT IM LEANING TOWARD THE POWER PACK
Jul 12, 2009 | Light Outboard Motor Boat Bass Fishing...
Air wont blow
The high speed setting on any blower bypasses the dropping resistor completely so I suspect you have a failing switch contact. If you can access it, some 'contact cleaner' from an electronic supply outlet may help to restore its operation but generally, once a switch develops problems, it will fail again.
Sep 18, 2008 | 2000 Jeep Grand Cherokee
2003 honda civic HX sputtering while driving
sounds like either a faulty igniter or air/fuel sensor
Sep 03, 2008 | 2002 Honda Civic
Fan works for about ten minutes then begins to slow down
Try spraying some WD-40 or similar on the motor shaft. There is probably some buildup of contaminents gumming up the bearings.
If I knew what country you lived in, I might be able to tell you where you can buy the motor if you need it.
May 29, 2008 | Fedders X Chassis A3X05F2B Air Conditioner
Kitchen Ranges Logo
115 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
