Question about West Bend 41053 Bread & Dough Maker
Bread machine hums and sounds like it's stuck when starting
My husband has taken the bottom off this bread machine and he says it has no fuses. The belt is runs on gears.
    Brigadier General:
  • 3,614 Answers
It was located near the powersupply area, & also check for the continuity on the resistor & capacitor on that area also..
let me know here again
Posted on Aug 02, 2008
How do I get the kneeding blade out of the bread machine?
soak the paddle in soapy water overnight with enough water to keep the paddle submerged. The next day wiggle it back and forth while holding the litte ears underneathe the pan. Move it up and down too. If it still doesn't break free go to you tube and type "how to remove a stuck bread machine paddle" have your husband do that move, but don' use more than one jug of water because the TBR15 pan is thin and can bend. Be sure your husband uses hot pads to hold the pan edges so he doesn't hurt his fingers. If that method doesn't work you will have to live with a stuck paddle or order a new pan assembly and paddle and then always remember to remove to soak your paddle after baking and remove it from
the stem, clean, and store. Daryl,,, from
Feb 26, 2013 | Toastmaster TBR15 Bread Maker
The pan on by breadman gets stuck everytime I make a loaf of bread and my husband has to get it out for me. How do I easily remove the pan?
Keep your husband nearby, lol.
No, but really, the two guides located at each end of your removable bread pan insert need to be raised up a bit. Place both thumbs directly under each guide and push up a bit.
The two baking chamber clips may also need a bit of re-positioning. Reach under each clip, grab the opening at bottom, then genty tug in the direction of the opposing clip.
Did this answer help? Please rate this answer as soon as you can. Thank you.
Jun 08, 2011 | Breadman TR875 Bread Maker
I have loved this machine- had no problems until today. I put in liquid ingredients for banana bread (had not even added flour yet) and started it mixing. It was doing fine, then suddenly stopped mixing....
It sounds like your drive belt has come off or snapped. If you can take off the bottom panel and look in there you'll see which it is. A snapped drive belt is not uncommon on bread machines.
Mar 24, 2011 | Sunbeam 5891 Bread Maker
I was given a B&D 2250 machine (used) and the kneading blade seems to be fused to the bottom of the machine. I have soaked it in hot water and scrapped out dough from beneath the blade but it is still...
I buy and sell bread machines and have run in to your problem many times. Just log on to you tube and type in,,,,,,,,,,,How to Remove a Stuck Bread Machine Paddle or Kneading Blade"
You will need ...2 hotpads, an old shoelace or string about 3 feet long and 2 old milk jugs, detergent botlles etc......something that will provide weight than you can tie the string to. Tie the string tightly around the post and knot it tight.....the string goes in the little gap between the bottom side of the paddle and the pan. The other end is tied to the milk the video and it will make sense....
Nov 27, 2010 | Black & Decker B2250 Bread Machine
The apparatus/prongs that operate the paddle don't move properly
Take off the bottom and spray the bearing under the oven with automotive brake cleaner. This will free them up.
Sep 30, 2009 | Sunbeam 5891 Bread Maker
Bread machine automatically turn on and starts when plugged in
My b2300 bread machine will not mix on one paddle it seems the belt is of the pully. I have taken all the screws out in the bottom but the bottom will not come off is there any more screws to come out from the inside
Sep 23, 2009 | Kitchen Appliances - Others
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Bread maker motor still hands
it has something to do in the motor.. i don't know which is the specific location but always check on the right side.
Aug 02, 2008 | West Bend 41053 Bread & Dough Maker
Kitchen Appliances - Others Logo
49 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Oloyede Monsuru
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
