Question about Canon ZR100 Mini DV Digital Camcorder
Wont except tape or occasionally when it does after awhile of use it pops up "remove tape" or "remove cassette".
    Genius:
  • 1,812 Answers
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Posted on Mar 18, 2011
I want to begin converting music from my computer onto cassette tapes using a device i've just bought. Can i use this device to firstly, override tapes? And Secondly does my record button even work?
check the top of the tape cassette if plastic removable tabs missing it will behave like a read only cassette if missing sticky tape can be used to cover the holes to make cassette recordable.
Jul 11, 2015 | Audio Players & Recorders
Fisher dual cassette player recorder doors wont open
The eject mechanisms may have simply aged to a point where they no longer work. There could be dried out lubricant or a failed mechanical part.
Mar 23, 2014 | Sony Audio Players & Recorders
"A" side/deck wont play----"B" deck works just fine
Loose belts and lack of lubrication. Dual cassette decks are built to minimum standards so that it does not take much to push them over the edge to be non-functional. It is almost like they should provide a tape deck repair course with these types of units as it is most certain that you are going to need it. They want you to throw it away and buy another one. This is where the throw away economy started.
Jan 27, 2013 | Sony TC-WE635 Single Cassette Deck
I have a Cannon Elra 100 Camcorder. It is fully charged, when I put a tape into it, the cassette spins and then pops out with the mesage "remove the cassette " the error occurs when I insert the...
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, a dislodged pinch roller, a faulty rotary mode switch or a defective clutch in the take-up spool and will require disassembling the camera to repair. This can usually be done fairly inexpensively. However, it's not a really user serviceable problem and will need to be repaired by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 13, 2011 | Canon Elura 100 Mini DV Digital Camcorder
Cassette gets entangled, and does not play well
Cassette tape machines will occasional require maintenance after a certain period of usage. First open the cassette door and remove the tape and any broken tape remaining inside. Some models allow you to remove the cassette door allowing you to have better access to clean the unit. Next you will need to clean the capstan with alcohol and a Q-tip. The capstan is the metal post which the rubber wheel (pinch roller) pushes against to drive the tape across the tape head. Basically clean all the shiny metal parts including the tape head. Some of the tape residue may be difficult to clean, I use Tricloroetilene which has been regulated by the government, but you may try a product called Goof Off to clean the difficult parts, but it could eat the plastic and rubber parts so be careful. Next use a rubber cleaner on the pinch roller so you do not dry the rubber out, or it will become useless. The other problem is the cassette may be driven by a motor and belts. The belts may need to be replaced and the pulleys cleaned. For this you will need to disassemble the unit to access the belts but the cleaning of the pinch roller and capstan may fix your problem, if not you need to open it up to replace the main belt.
Jun 23, 2010 | Philips 3-Disc Changer FW320C Cassette/CD...
Tape Wont Play
My advice is that you should by a cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
May 10, 2009 | Sony Handycam CCD-TRV58 Camcorder
Pioneer multi cassette changer CT M6R
I have had this same problem too. I fixed it by taking the tape transport out of it and removing both capstans with their flywheels and oiling the capstans. However this only fixed the problem for a few months. Maybe you need to more a most soild oil since i used just regular motor oil.
Oct 17, 2008 | Pioneer DEH-1600 CD Player
DVX100A panasonic camera tape mechanism not working
You can open the cassette cover and spray inside the upper left side of mechanism(closer to the back) with contact cleaner spray,because there is a rec inhibit switch.If it's not damaged and just dirty you solve your problem ,but if is damaged it needs replacement.
Jul 26, 2008 | Panasonic AG-DVX100A Mini DV Digital...
I cant put a tape in!
when mechanism pops out to eject, wait until it completly comes out, deattache battery immediately, and Pull lever as per below mentioned picture. Cassette door will be open and place cassette. Close it and attache the battery. Camera is ready to Record or Playback.
Feb 25, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
Cassette jam
I had this problem, and here is how it was resolved.
My cassette would not pop out when I opened the door with the camera turned on. When I turned off the camera and opened the door, it slid out much further, but still failed to pop open so that I could remove the tape. Then it slid back in.
Remove the battery, and have the camera off, but make sure the power cord is connected. Open the door until the tape slides out further than at other times. (Note: It intermittently slides out further when the camera is off. Sometimes it will not slide out any further than when it is on.) When the tape is slid out as far as it will go, quickly remove the power cord. The tape will stay in the slid-out position. Now, at the bottom side of the tape door there is a curved channel for a small pin to slide in. This channel has a 90% curve at the bottom of the channel to catch the pin, which holds the door closed. Push that pin back a little (toward the lense) to get it to go around that 90% curve, and the door will pop open so you can remove your tape. The ribbon of your tape will be jammed in the camera a little, so you will have to be careful and move the ribbon around a little until you can get it out freely.
This worked for me twice. I did not try putting a tape in again.
I hope this helps.
Apr 10, 2006 | Canon ZR10 Mini DV Digital Camcorder
Canon ZR100 Mini DV Digital Camcorder Logo
54 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
