Question about Cameras
In my casio calculator while solving any calculations it not showing the digits after the points. The digits which are coming after the points .my calculator is not showing that digits, it only shows the whole digits. Can u solve it ?
  • Cameras Master
  • 4,924 Answers
Take a look cause it has to be a button that selects how many digits to show after the the point ..it is probably a button that slides from side to side with more than one position ...2 digits...4 digits..and at the max to show all ..it is usually just like the power on and off one . not a digital button but more like a switch ...If the issue is not from there ..it may be damaged..
Also try to see if removing the batteries fix the issue ..cause if it is set to approximate ..it does the same ..so ..if it has an approximating button ..switch it off ..
Posted on Mar 17, 2011
My calculator Casio FX-300MS suddenly shows one decimal place only and i need it for exams. please help
Press the MODE key repeatedly until you get to the "Fix Sci Norm" screen. Press 1 to select Fix, then press a digit specifying the number of digits after the decimal point, or else press 3 and select one of the Norm modes.
See the second column of the manual: http://www.fixya.com/support/p186611-casio_fx_300ms_calculator/manual-710
Nov 30, 2013 | Casio FX-300MS Calculator
How do I round 991.5656641 three decimal places? I am using a casio fx-115es
Press SHIFT MODE 6 3 to set the display mode to Fix3. This will show all results with three digits to the right of the decimal point.
Aug 05, 2011 | Casio FX-115ES Scientific Calculator
My answers keep showing up in long decimal forms, how do i restart my calculator
No reset needed. To specify the number of digits after the decimal point, press SHIFT MODE 6 and then the desired number. Alternatively, press SHIFT MODE 8 and then 1 or 2 to select "Normal" mode.
Feb 08, 2011 | Casio FX-115ES Scientific Calculator
I have Casio fx-350 MS. On the screen in the top right, it say "fix." And whenever the answer comes out to be a decimal, the calculator automatically rounds it up to 10th place. I need it to...
Cheer up, the calculator can display UP to 10 digits, no more. Internal memory keeps 12 digits. So clearly, this calculator is not fit to handle the precision you apparently are seeking. It may be time to look for a more capable calculator.
Jan 28, 2011 | Casio FX350MS Scientific Calculator
How do i get my calculator to stop displyaing 15!/5! as 1.08972864*10*10?
You don't. The calculator can display only ten digits in a number. This number has eleven digits to the left of the decimal point, so the only way the calculator can display the most significant digits is to switch to scientific notation.
Oct 06, 2010 | Casio FX-300MS Calculator
Can i solve an equation of second degree(like X^2+2X+1) with Casio FX-7400G Plus ? If so how?
Sorry but the calculator does not have a solving routine. You can however use the graphing capabilities of the Casio FX-7400GPLUS to solve an equation f(X)=0.
  1. Graph the function Y=f(X)
  2. Use the trace function to locate the point(s) where the function vanishes (has value Zero)
See the screen capture for an example.
If you were hoping that this calculator would be able to factorize polynomials for your, sorry my friend it cannot.
May 15, 2010 | Casio FX-7400G Plus Calculator
Can i solve an equation of second degree(like X^2+2X+1) with Casio FX-7400G Plus ? If so, how?
Mar 27, 2010 | Casio FX-7400G Plus Calculator
How do I get my Casio calculator to show only 2 numbers after the decimal point?
Use the FIX format with two decimal digits
[MODE][1:Fix] 2 displays only two decimal digits.
Hope it helps.
Sep 03, 2009 | Casio FX-300MS Calculator
There is a button in a vintage textbook showing a calculator with a "FIX" button. What was that button for?
Followed by a digit key, it probably set the display to fixed decimal notation with the specified number of digits following the decimal point.
No, it didn't magically fix a broken calculator :-)
Mar 26, 2009 | Casio HR-100TMPlus Calculator
Rounding off in Casio FC 200V
Press [SETUP] select FIX then press [EXE]. Enter the number of decimal digits you want (3 or 4). Press [ESC] then press [EXE]
Hope it helps.
Dec 14, 2008 | Casio FC-200V Scientific Calculator
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
