Question about Kensington Portable Ethernet Cord (33052)
Ethernet cord My ethernet cord running from the outside of my house up to my room stopped working all of the sudden and the rest of the ethernet cords in the house work, the port that my room is conected to is working as well. it has been raining for a few days, I dont know if this could affect it.
  • 3 Answers
Hi Dear Friend,
There can be number of reasons for this problem. To solve the problem, you can try these:
1. Check that RJ 45 connector, connected to switch/hub/pc is showing LED indication or not at the both the ends i.e pc end and at the switch/hub end.
2. Make sure switch and pc configuration should be correct and is not changed by mistake.
3. If LED indicators are not glowing any of the ends i.e PC or Switch end there might be a problem of ethernet cable, possible broken/cracked cable at some place or also possible that RJ 45 connector problem.
4. Also try the same cable to connect to different pc. Check, if it work then or not.
Hope this will solve the problem.
In case any other info is required pls. feel free to contact.
Thanks
Posted on Jan 05, 2009
My 2002 trane XE 1200 gas &electric unit stopped blowing air
it may be the blower motor not working inside the house check the cap for the motor & the power to the motor
Apr 28, 2014 | Heating & Cooling
I've had a saniplus toilet system (with toilet and sink) for about 10 years. Suddenly stopped working as well. The macerator pump runs in shorter bursts and the water level in the toilet goes down
You should check the 1 1/2" vent pipe if there is one attached to the top of the pump casing. The vent pipe must be vented to the open air, outside of the house so the unit can breath air in and out at all times. A lack of airflow usually creates this type of problems. Leave the vent connection open to the room and flush the toilet, you will see the difference when pumping.
Mar 11, 2013 | Home
Ethernetport red port
If your router works wirelessly but the ethernet ports do not work try using a new ethernet cord. If it still does not work try using another device with the old and new cord. If that still does not work try doing a hard rest on your router and setting it back up. if that doesnt work you may have taken a power surge and they are dead.
Jan 26, 2013 | Computers & Internet
3g network stopped working
Too much RFI interference can often cause Apple devices to start overheating and loose cell network connectivity. Try letting it cool down a bit and then try again in a different room, or outside of the house to see if that may be the problem. Unfortunately, I am not aware if there is any fix or solution to the problem unless you can find sources of interference and correct that.
In my case, I cannot use my iPhone in my "home office" area because of too much computer hardware and electronics running, too close to my phone. I have to step out of the room to maintain 3G connectivity.
Dec 02, 2012 | Apple iPad 16 GB 3G Tablet PC
Is it possible to Wirelessly connect Router to a Router? We have a Router (outside the house) by which we connect to the internet inside the house. The problem is is that the internet connection is not...
1.Yes you can connect router to router.
2.Buy ruckus 802.11n.It got MIMO antenna.I hope it will work for u.You can use single router to access internet from all room
Feb 04, 2011 | Computers & Internet
I am having connection problems with this product, the NetGear Router WGR614. My computer that the router is connected to is in my family room and it works great in here, but when i am sitting in a chair...
HI, This is one of the problems associated with wireless connections in the home.
I have many clients in a similar sitauationa and where possible, I run an ethernet cable from the router to whereever the computer is to be used. Alternatively I use what's known as 'Powerline networking'. This is a system whereby the mains wireing in your house is used instead of ethernet.
There are several brands available and you can buy units that have a wireless transamitter on one mains plug so that you can be flexible with your wireless layout.
I have found this to be much more reliable than trying to use 'range-boosters'.
Aug 09, 2010 | NetGear Computers & Internet
Blackout in my house, Xbox 360 ethernet port broken!
All the message means is it can't find the internet, so your internet must have went down.. your systems should still be working fine. I don't know much about using usb for ethernet, but that sounds like it would work no problem.
Apr 04, 2009 | Microsoft Xbox 360 Console
Tv wont come on at all
Run an extension cord from another room to see if the tv still works. It sounds like faulty wiring in the living room that needs to be checked. Also, check for a tripped circuit breaker for that area of the house. Can't tell you about the repair but, you will save yourself some time by checking these things out first.
Jan 14, 2009 | RCA P52926 52" Rear Projection Television
The ethernet light won't turn on my modem anymore
hi...
try to check the ethernet adapter on your computer...if the ethernet cable works fine with the other computer and the other one does not, then probably, the NIC CARD or ethernet adapter is defective...i advise, if you have someone or a technician or a friend who knows how to check...then you can do such,..or if it's a laptop..then youn can bring that to any computer stores and they have technicians there to check freely your case,k...
hope i give you something that may help a little with your concern....
happy new year!!!!!
Dec 31, 2008 | Computers & Internet
Electric outlet does not work
LETS START HERE , MOST OF THE GFCI BREAKERS WILL SOMETIMES RUN THROUGH THE BATH ROOM OUTLETS AND THEN OUTSIDE IF YOU HAVE A GFCI IN THE BATH OR LAUNDRY OR BASEMENT OR GARAGE MAKE SURE NONE OF THE RESET BUTTONS ARE IN THE TRIP POSITION THE NEC CODE CALLS FOR ALL OF THE LISTED PLACES AS WELL AS CRAWL SPACES AND NEXT TO AC/HEATPUMP TO BE ALL GFCI AND TO SAVE MONEY AND WIRE MOST OF THESE ARE DAISEY CHAINED TOGETHER TO SAVE MONEY SO THEY PUT ONE CLOSE TO THE BREAKER PANEL AND FEED THE REST OFF IT IT WILL BE A GOOD CK I HAVE HAD MANY CALLS FOR THIS THROUGH THE YEARS
Dec 09, 2008 | Rival S12T Electric Skillet
Computers & Internet Logo
70 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Alun Cox
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
