Question about Chariot Carriers Inc. CTS CX 1 Jogger
Hey the back wheel is jammed on our chariot cx1 might be a lubrication problem? any advice on how to get it off?
I cant put the axle back in my car
Lubricate the splines and snap ring with trans fluid. Then insert the axle with a quick jamming motion. That'll compress the snap ring and it'll click into place in the differential gears.
Jul 01, 2017 | Cars & Trucks
Want to know the correct automatic transmission fluid for mitsubishi chariot 2000
erperts do not know everything as thee are countless variations of vehicles,transmissions and owners like to mix and matcg units outside of manufacturers specifications. What makes us experts is that we know where to go for information that is specific and our advice to you to get the right oil for your transmission -talk to a dealer service centre.
Oct 27, 2014 | 1996 Mitsubishi SpaceWagon
Brake jam in two wheels and car dose not move
is it jammed on the rear brakes ? if so then try shaking the rear handbrake cables underneath and hitting the back plate when its off , choc the wheels so it wont move then if possible drive backwards as it sounds if the cables or linkage needs lubricating ! if its not the handbrake then you need to back off the pads or shoes then remove all and clean and grease and check for wear etc !
Jun 02, 2014 | 2004 Ford Freestar
My sewing machine gears jammed.
One or more of the bushings is seized, the machine needs to disassembled, the bushings removed, cleaned, re-lubricated. Not something you can do yourself.
Apr 07, 2010 | Baby Lock Espire
Plantronics bluetooth model# HFBLU-CX1
I just glued them back together and wrapped black electrical tape around the glued  together section,no more breaking for me.
Jul 28, 2008 | Cellular Innovations HFBLU-CX1 Wireless...
My Wheel Rolls EXTRA Slow!
Hey Kayla,
I had the same problem. What happened is i left mine in my car while i was working. This was not the first time either and when i got out of work in the late afternoon i noticed my sansa's wheel was incredibly hard to turn. I went home and searched for solutions and found your very same problem. I went downstairs and found that my dad had a pressurized can of Super Lubricant. 1 small, quick shot directly onto the wheel top and button got the spray lubricant on there good and i just wiped the excess lubricant into the wheel seams. Immediately start turning the wheel in either direction (try to switch back and forth) and it'll start to spin freely. The Heat of an enclosure like your purse or my car in the sun dries out lubricants just like the lube sansa applies in their factories to these products so just try this and tell me how it worked for ya if you still have it.
Sincerely,
Ben (belmont1@gmail.com) ( :
P.S. stop applying alcohol. That's more of a cleaner and all it will do is temporarily fix the glide sticking problem while simutaneously drying it out. Bad method...go with your every-day spray-lube.
May 04, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Chariot Carriers Inc. CTS CX 1 Jogger Logo
111 people viewed this question
Top Chariot Carriers Inc. Baby Gear Experts
Dorel UK
Dorel UK
Are you a Chariot Carriers Inc. Baby Gear Expert? Answer questions, earn points and help others
