I saved my microsoft word file and when i opened it again it became an acl file which could not be opened on windows. Help ls.
    Problem Solver:
  • 16 Answers
I am not sure what has happened here. An .ACL file is a list of corrections used by the AutoCorrect feature in Microsoft Office; used for automatically correcting grammar and spelling mistakes. These AutoCorrect lists can be customised within Microsoft Office programs and are not meant to be edited manually.
I can only suggest you search again for the file to see if another copy has the correct .doc or .docx extension.
Posted on Mar 17, 2011
We have a document produced on a pc with Vista works which has flow charts in amongst the text. We saved the document onto a memory stick and tried opening it in order to print through my laptop which is...
Hello Penny,
After creating document in MS office 2007 or 2010 you can save the document for MS office 2003. In file menu choose the option Save As and choose option Save as type. The click for the option Word 97-2003 Document. Then you are able to print the document in MS Word 2003.
Jun 28, 2011 | Microsoft Windows? Vista Home Premium...
When I am trying to open any saved files in MSWord, I get an error message saying "Windows cannot find example/file.docx. Make sure you have typed the name correctly, and try again." Even when I...
-Run regedit (Start menu, run, etc.) and go to this key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Word\Addins
-Export all the addins to a reg file (for backup)
-Then delete all of them in the registry (or one at a time if you want to
know which addin is causing the problem,
-Now try opening a .docx or .doc file in windows explorer and find that
document loads properly with out any error messages!
-now exit MS Word and open the reg file(s) you exported and import them back
-try opening a .docx file again and the problem is fixed. hope this works for you
May 05, 2011 | Computers & Internet
It says that "Your Auto
You can check out this link:
http://social.technet.microsoft.com/Forums/en-US/office2007deployment/thread/c1b0a32f-fbdf-42af-af7c-f0cccd798d5a/
or
-open RUN or search
-type "REGEDIT" on the run or search box
-navigate to
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
-Check if the Appdata value has a value, if not right click on the blank side choose New >> Expandable String Value then type "AppData" - without quotes
-right click on the value that was just created and choose Modify and type
"%USERPROFILE%\AppData\Roaming" - without quotes
Then restart..
AppData
REG_EXPAND_SZ
AppData
REG_EXPAND_SZ
AppData
REG_EXPAND_SZ
Mar 24, 2011 | Computers & Internet
Dear Expert I am using Windows Vista TM Home Premium at my Notebook Pc( HP Pavilion dv-5) with Microsoft office 2007 since last 01 year. My excel files are not opening and I am receiving following message...
maybe you relocated the file itself, check first if the file you are opening is still in its original location on your hard drive, if not, manually open it by double clicking, do not open it inside microsoft excel.
Jun 02, 2010 | Microsoft Excel 2003 (06503995)
My ZTE cdma1X modem is not working on windows 7.
Apparently, one of the Windows updates is causing corruption of the Access Control List (ACL's) in the registry. I had entire sections of my registry nodes that lost the ACL'S.
While I was researching the problem, I came across a website where someone had a similar problem with getting windows OS programs/services to run and they discovered that there was some registry corruption and missing ACL's.
There are two different options that I ended up doing to get the system back in operation.
It seems that running one or the other alone will not fix the problem, but doing both should get you back in service.
  1. Make a backup of your registry (and a complete backup of the system wouldn't hurt either!)
  2. Go to Microsoft's website and download a program called subinacl.exe from this site; http://www.microsoft.com/downloads/details.aspx?FamilyID=e8ba3e56-d8fe-4a91-93cf-ed6985e3927b&displaylang=en
  3. Install the subinacl.exe (it downloads as an MSI file).
  4. Copy the code below into a text file and then name the text file reset.cmd.
  5. I copied the command file to my temp folder to run, but as you can see from the cmd file, it contains the path to the executable subinacl.exe.
@echo off
title Resetting ACLs...
cd /d "%ProgramFiles%\Windows Resource Kits\Tools"
echo.
echo Resetting ACLs...
echo (this may take several minutes to complete)
echo.
echo ==========================================================================
echo.
echo.
subinacl /subkeyreg HKEY_LOCAL_MACHINE /grant=administrators=f /grant=system=f
echo.
echo.
subinacl /subkeyreg HKEY_CURRENT_USER /grant=administrators=f /grant=system=f
echo.
echo.
subinacl /subkeyreg HKEY_CLASSES_ROOT /grant=administrators=f /grant=system=f
echo.
echo.
echo System Drive...
subinacl /subdirectories %SystemDrive% /grant=administrators=f /grant=system=f
echo.
echo.
echo Windows Directory...
subinacl /subdirectories %windir%\*.* /grant=administrators=f /grant=system=f
echo.
echo.
echo.
echo FINISHED.
echo.
echo Press any key to exit . . .
pause >NUL
3. As this command file runs it will show you the status of the reset and create a log that you can go back into and inspect for problems.
4. When this command file completes, you then need to open a command window (using Run As Administrator) and run the following command;
secedit /configure /cfg %windir%\inf\defltbase.inf /db defltbase.sdb /verbose >c:\temp\secedit_output.txt (the redirect of output echos the programs output to a text file, but secedit also creates a log file. The program will show you the location of the log file when it is done).
These two actions combined will reset the permissions on the registry nodes back to their default settings.
Reboot and check your Event Log service... at this point it should be running.
After effects of this process which happened to me, were that the Network List Service would not run... I still had network and internet access, however the Network icon in the task notification area had a Red X, and mouse over displayed a tooltip that said "Server Execution Failed". This was a result of resetting the ACL's.
The Network List Service (netprofm) would not run because it did not have permission to run.
In order to correct this issue, you must open the Component Services snap-in and drill down under Computers/My Computer/DCOM Config/netprofm (this is for Vista!) and right click the node, and select Properties.
Click on the Security tab and make certain the correct user names are listed and that they have the appropriate permissions. I have 4 users listed with the same permissions; (your mileage may vary )
  1. Administrators - Perms; Local Launch, Local activation
  2. Interactive
  3. Local Service
  4. System
Next, go to the Identity tab and ensure that The System account (services only) is the item that is checked. Make sure the changes you make get applied.
Restart your computer so the ACL's are refreshed.
Once you come back up from the reboot, things should be pretty much back to normal.
You may find a stray program here and there that may need to have it's permissions reset, but you should be operational.
Mar 19, 2010 | Microsoft Windows Vista Ultimate Edition
In which we can open .docx files
You can open docx extension files only with MS Office 2007. If you wish to open it in earlier versions you have to save it again in compatible mode. Click on File (top left most corner with the logo), Save As, Word 97-2003 Document. Just using Save option will save your document as "docx" and not "doc" document.
Aug 30, 2009 | Microsoft Windows XP Home Edition
Lost word modified doc opened from outlook attachment
If you still have this problem and are using Microsoft Office 2007, run registry editor (regedit.exe) and scroll to the following location:
HKEY_CURRENT_USER\Software\Microsoft\Office\12.0\Outlook\Security
Copy the contents of the "OutlookSecureTempFolder" key and paste it in the Windows Explorer to open the OutlookSecureTempFolder. Your file will most probably be here. This location can not be browsed to and can only be found from the registry as it is different for all users. e.g. for myself it is as follows:
D:\Users\keekus\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.Outlook\R34DKK8O\
Mar 25, 2009 | Microsoft Office Outlook 2007: Windows
Sir,  I have been worked in an Excel Worksheet and Saved the file periodically (File Name - Known and the Saved Location is Unknown).  Immediately the System became Hang and I wait for a long time and then...
normally all the MS office files saved in my documents folder, check at this location, otherwise the file will appears in file menu of excel at the top of recent used file. you can also find the file in most recent save document in start menu.
Feb 02, 2009 | Microsoft Windows Vista Ultimate Edition
Excel Recovery
You have to search the file name in all drives.
Jan 31, 2009 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
