Question about Pioneer DEH-1100 CD Player
I have a pioneer DEH-P6200BT > I need help with the wiring it is going into a 2000 dodge Durange
  • 15 Answers
SOURCE: pioneer deh-p6800mp wiring
You can find the wiring diagram online in a PDF of the installation manual, which is at this location
Hope that helps!
Posted on Jan 14, 2008
SOURCE: wiring diagram pioneer deh-3400
ce3d034.jpgh
ihave this for you
Posted on Feb 06, 2009
lostinfamily
  • 149 Answers
SOURCE: need wiring diagram for pioneer deh-p4000ub
http://akamaipix.crutchfield.com/Manuals/130/130DEHP4UB.PDF
Here is the PDF file for your radio. On page 63 is the start of the wiring diagram. I hope this helps. Please Rate this solution
Posted on May 20, 2009
  • 85 Answers
SOURCE: Wiring diagram for Pioneer DEH-P6550
black is negative blue is remote red is accesory key switch yellow is constant power memory,gray with black is RF negative and gray is positive white is LF positive and white black is LF negative.violet is RR positive and violet black is negative and green is LR positive and green black is negative
Posted on Sep 14, 2009
  • 68 Answers
SOURCE: wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
Posted on Nov 17, 2009
Wiring diagram for pioneer deh-p6200bt
do you need the wiring for the deck or for the car(or both)
Oct 09, 2014 | Cars & Trucks
NO SOUND OUT OF NEWLY INSTALLED PIONEER DEH-X6600BT
Did the Durango have the Infinity sound system? If so, there is a separate amplifier that is probably not being activated. Look for a blue or blue/white wire on the harness adapter and connect it to the Pioneer's blue/white wire. If it does not have blue/white, use the solid blue one.
Dec 29, 2013 | Pioneer Deh-X6600bt Car Cd Receiver...
Wiring colors ford ranger 1992 &pioneer deh 3900 mp need to know which wires are which thanks
I suggest check this diagram
DEH-3900 Installation Manual -->> DEH_3900MP_CRD4131_installation_manual
1992 Ford Ranger Pickup Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Hope helps.
Oct 03, 2011 | Pioneer DEH-3900MP CD Player
How to integrate the pioneer deh-1300mp into a 96 Dodge 2500 Centurion diesel truck to replace a radio/cassette player.
The simplest way to swap the stock radio out for the cassette player would be to go to a radioshack or bestbuy, normally they will carry a double-din to single-din adapter so that the smaller after market radio fits into the existing location snugly. They usually also carry a wiring harness adapter that will plug right into your dodges existing harness and you can just wire nut or solder & shrink wrap the adapter to the pioneers harness, saves a lot of time and insures everything is where it needs to be.
Normally you can get both adapters for under $15, hope this is helps.
Mar 08, 2011 | Pioneer DEH-1300 CD Player
How do i set the clock on the pioneer deh-p6200bt unit
Clock set (setting the clock)
1 PressM.C.todisplaythesettingmode. 2 PressM.C.toselectthesegmentoftheclockdis
play you wish to set. Hour Minute As you select segments of the clock display, the selected segment flashes.
3 TurnM.C.toadjusttheclock.
Jun 03, 2010 | Pioneer Car Audio & Video
I just hooked up a pioneer deh-5100ub stereo in my 2004 dodge ram 1500 pick-up using a store bought wiring harness but I cannot get any sound from my speakers now.
Does you truck say Infinity anywhere on a door panel or such? If so you need to make sure that the blue wire from the store bought wiring harness is connected to the amp turn on from the pioneer.
Mar 02, 2010 | Pioneer DEH-P5100UB Car CD/ MP3 Player
Can not find a wireing diagram for a pioneer DEh-p2600
Pioneer follows the universal after-market color code, so if your CD player was made in the last ten years or so, the wires should go like this:
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
May 30, 2009 | Pioneer DEH-P2000 CD Player
Pioneer DEH-1100 CD Player Logo
165 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
