Step
Action
Value(s)
Yes
No
DEFINITION: This diagnostic procedure should only be used if the high beam headlamps are operating properly and the low beams are inoperative.
Did you perform the Headlights System Check?
Go to Step 2
Go to Headlight System Check
Does the test lamp light?
Go to Step 3
Go to Step 5
Go to Step 4
Go to Step 6
Go to Step 7
Go to Step 8
5
Replace the headlamp dimmer switch.
Is the repair complete?
6
Repair the open in CKT 359 (PPL) between the headlamp dimmer switch and the daytime running lamp relay.
7
Replace the high/low beam headlamps.
8
Main headlights don't come on. Fogs and hi beams work fine. all fuses checked and aok. headlamp bulbs checked and aok. Could it be the headlight relay?
thanks
steve
yep both are out. I did change one bulb..a while back, maybe that would have something to do with it? The fuses and relays are fine. Strange.
Same issue. High beams work, and the fog lights as well as running lights, but the regular lights do not come on.
Low beam lights will not come on at all.
I have the same problem... anybody find the answer?
i have the same problem, front and rear lights do not turn on, daytime or night time and the dashboard light wont turn on either, however the P, R, N D, 1, 2, lights work and the radio and clock light do too and the high beams do when i manually hold them on...and checked all the fuses....
HEADLIGHTS DONT WORK BUT EVERYTHING WORKS FINE
