Question about HP Office Equipment & Supplies
I just bought an HP Deskjet 1000 and the power light is just flashing green. No matter what I do, it will not power up.
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Jun 17, 2011 | HP Office Equipment & Supplies
Hp deskjet d1560 printer light flashing
After your printer has completed its initial startup you should have a solid green light. If the light indicator is blinking or orange often this is an indication of a printer error. For example, this could indicate a paper jam, issue with the ink or toner cartridge, or other serious error.
Because there is no standard to what a blinking light or orange light means if you're getting either of these we suggest referring to the printer documentation for troubleshooting steps or methods of determining what the status indicator is reporting.
http://h10025.www1.hp.com/ewfrf/wc/searchResults?tmp_product=HP+Deskjet+D1560+Printer&product=3374275&tmp_qt=power+light+flashing&lc=en&dlc=en&cc=us
Aug 06, 2010 | HP D1560 Deskjet Printer InkJet
Hp deskjet 3325 light flashing have turned device
no problems
:just go ahead and take out the power cable when the printer is still on
:nw press and hold the power button fr 30 seconds
;while holding the power button,plug back the power cable
:nw u will be able to work well
Jun 28, 2009 | HP DeskJet 3325 InkJet Printer
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Jun 09, 2009 | HP DeskJet 5550 InkJet Printer
Hp Deskjet 5550 making grinding noise then stops.
Here is a page explaining how to resolve this issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=71895&prodTypeId=18972&prodSeriesId=71895&objectID=c00681585
Apr 21, 2009 | HP DeskJet 5550 InkJet Printer
Both my printer lights are flashing and I have tried all the
Open the back panel...check to see if you have a paper jam....
if not open the link below and follow instructions
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00681585&lc=en&dlc=en&cc=us&product=71896&rule=23659&lang=en
keep me posted
Please do not forget to vote!
Cheers!
Nov 13, 2008 | HP DeskJet 5550 InkJet Printer
D1360 black ink didn't print and green light keep flashing
just unplug the power cable and usb cable from the back side of the printer and let it be for an hour it will help
Apr 15, 2008 | HP Deskjet D2360 InkJet Printer
845 people viewed this question
Ben Johnson
