When i press print in Microsoft word, the printer will display this error. The printer is an office printer therefore, i had tried 3-4 of the office computers and yet the problem happens. I had tried to reboot numerous but nothing works.
  • 111 Answers
Have you check if your default printer is the one that is being use in your office?
Please go through this steps.
1. Open the Document you want to print then Press CTRL+P.
2. See the attached pict.
3. On General Setting Choose the printer.When i press print in - geneadrian_3.jpg
Posted on Mar 17, 2011
Clearing a Print System Failure on the HP Photosmart C6150 All in One Printer
Try the below steps to bypass the error.
1) Press * and # at the same time
2) Press 1, 2, 3 and "support R0632M" should display
3) Press > and "information menu" should display
4) Press > and "configuration menu" should display
5) Press OK and "hardware failure status" should display
6) Press OK "failure status: clear". Press OK to clear
7) Press CANCEL
8) Press CANCEL
9) Press CANCEL
10) Turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
You may need to repeat the above a few times as the error can change.
Aug 04, 2013 | HP PhotoSmart Office Equipment & Supplies
Error badint 0085ddc0
The 'badint' error on the T6100 indicates the printers firmware has for some reason 'crashed', this error should not be seen in normal operation of the printer.
One common cause of "BADINT" messages is the use of an external print server or host computer with incompatible parallel-port settings. If you have an external print server connected to the printer's parallel port there is a setting on the print parallel interface that may need changing, to change parallel interface setting. • Set the printer to Offline. • Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access On) • Press the Mode key: display will show Offline Normal. • Press any Arrow key until display shows Offline Config. • Press the Forms/1 key. • Press any Arrow key until display shows Config Paralel. • Press the CPI/2 key. • Press any Arrow key until display shows Paralel Bi-Dir. • Press the LPI/3 key. • Press any Arrow key until display shows Bi-Dir Off. • Press the Enter key and the interface will be set. • Press the Clear key. • Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access Off) On the external Print Server, you need to ensure that the unit is also set for Uni-directional working.
Nov 04, 2011 | Tally Line Matrix T6100 Printer
Displays a Device error Press (OK) message which clears on pressing ok but does not print
-You have to delete the document that is waiting to print in the printer document inside the computer as well.
try it.
Good luck
Mai
Aug 30, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Hello, what is the solution to the following error: pcl xl error subsystem: kernel error: illegal operator sequence operator: EndChar position: 209 The printer is hp 3052, Windows XP Pro operating...
Are you printing from Microsoft Office? If so, there are noted issues with HP printers and Microsoft does have patches available to fix the problem. First step is to make sure that your Office is up to date.
Jul 13, 2011 | HP LaserJet P2015 Printer
Printhead Error is displayed and therefore rendering the machine unuasable. Do you have any suggestions for a fix?
Replace with new printhead if the print head is past it's service life. If not past it's service life when you get that error message press the online button and it should print fine.
Apr 12, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Deskjet 5550; Windows 7; Microsoft Office 2007; not printing
That is strange
Try changing the default to a different printer (Microsoft XPS Document Writer) see if it prints to it...
Then (If that works) try switching the 5550 back to default.
If that don't do it, uninstall thee printer, reboot and reinstall the printer.
Mar 12, 2010 | HP DeskJet 5550 InkJet Printer
Error:oxc18a0206
- Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
1. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit.
Dec 16, 2009 | HP Photosmart C7180 All-In-One InkJet...
When I press "Print" in i.e. Microsoft Office Word, then the print queue screen comes up and there it is under "Status": Error - Printing. And nothing happens.
Hi, are u using quick print or print? try using quick print and be sure to choose the correct printer, ur computer may be trying to print on one that isnt even plugged if there is more than one installed.
Nov 01, 2009 | Office Equipment & Supplies
Phaser 8560 Colors are Off
Here are the directions for Tec Color correction. If this doesnt work then replacing the print head is the most likely solution. The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use. TekColor Description Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display. sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications. Euroscale: Matches Fogra glossy paper specification. Commercial: Approximates U.S. commercial press target. SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray From the workstation, select the color correction in a supported driver. Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS): NOTE: Some of the color corrections are grouped under Office Color or Press Match. 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed. 3. Click on the [TekColor] tab. 4. Select the required color correction. Apple Macintosh OS 9.x: 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on [General], and then select [TekColor] from the pull-down menu. 3. Select the required color correction. Apple Macintosh OS X, (version 10.2 and higher): 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu. 3. Select the required color correction.
Jun 08, 2009 | Xerox Phaser 8560MFP Laser Printer
13 people viewed this question
jasbo
jasbo
