Question about HP Photosmart C5180 InkJet Printer
I cannot connect my printer after installing all applicarions in win 7
Can not (re)install HP Solution Center in windows 7 (photosmart c6280)
check leads and connection points
once connected windows 7 should automatically detect your printer search for and install the drivers
click start control panel devices and printers if you see your printer right click on it
you might have to set it as your default printer
click start right click on computer device manager scrollto ports com & lpt
if you see a yellow question/exclamation mark ? ! or a red X a new driver will need to be installed
hope this helps
Dec 12, 2011 | HP Photosmart C6280 Printer
I have downloaded a printer driver for BJC 1000SP for Canon inkjet printer but it i s not win 7 compatible so need help Venugopal
The only way to work around your problem if canon doesn't produce a new Win 7 driver, is to download & install "XP mode" on the win 7 machine. Google it and you will find numerous articles describing how to do this. Once installed, you can open the XP mode and install the printer there. Once you have it installed using the win xp drivers, make sure you click the tab at the top of the screen and select "attach" for the device you require. You have to repeat this attach process each time you open XP mode.
NOTE! XP mode will only work on WIN 7 Pro and upward.
Jan 29, 2011 | Epson R245 InkJet Photo Printer
I need the panasonic printer KXP7100 driver for windows 7
I searched Panasonic's website for information on drivers. They are not providing a stand alone driver for Win 7, for this printer, but no where on their site did they did say that support was discontinued. It does not look good, however, since they offer no Win Vista drivers either. The latest drivers are for Win XP.
Have you tried connecting the printer and seeing if windows installs it on its own? I have found sometimes this works because Win 7 has a considerable driver database in the installation files.
Jan 10, 2011 | Computers & Internet
I want to dowmload the software for the bjc1000sp printer for windows 7 starter.
it doesnt have a win 7 driver
http://www.canon.ca/inetCA/serviceDetail?m=load&id=3&sid=19&mid=0002027&type=S
but it does have a windows vista driver,,
keep the printer connected and restart your pc,, then go to windows update and install the optional updates (chances are win 7 will pull and use the vista driver)
Oct 23, 2010 | Canon BJC 1000N InkJet Printer
Where can i find the driver for PIXMA IP90 win 7 x64?
The printer driver for Win 7 x64 should be automatically installed if your printer is connected and your have an internet connection.
See
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip90#ServiceAndSupport
Let me know if you have any other questions. Thanks.
Sep 12, 2010 | Office Equipment & Supplies
I wish to install a Canon LBP2900B printer under windows 7. I have downloaded the drivers from Canon but the windows system adds the printer as 'unspecified' not as a printer. It is connected by a usb...
somehow this is because Win 7 actually does not support all devices. try installing the device using win xp or vista, if it does work then it really has no support for win 7
May 21, 2010 | Canon LASER SHOT LBP-2900 Printer
The network printer will print a test page but nothing else
whenever a printer is connected to a network it loads a driver for all the lower versions of operating systems so that if any computer from the network having a lower version gives a print command it can be spooled using that driver. On the other hand you have connected the printer to an OS of low version and printing through a higher version. Its just like connecting a printer to DOS comp and trying to print through Win 98. So now you know what you have to do. Just find your driver compatible for Win7 and connect it to win7 and you can give print through xp.
Apr 14, 2010 | HP Photosmart C5180 All-In-One InkJet...
I am trying to install my printer the software is
HI there
you will need the new software for win 7 , and it not easy to find the new drivers for the printers to mach
Mar 02, 2010 | Office Equipment & Supplies
Driver for printer not compatible with win 7
The driver is classed as inbox. An inbox driver is already installed and should install automatically when the printer is connected and powered on. This if the printer driver. You will also need the scanner driver which epson say the Vista version is compatible and can be downloaded from their website.
Feb 08, 2010 | Epson Stylus RX425 Multifunction...
HP Photosmart C5180 InkJet Printer Logo
Seeker5211
Seeker5211
