Question about Samsung SW62ASP Top Load Washer
I set my machine to wash,when water get inside,the water can't retain in the machine and the water get out. the water come out from drain hose. I assume my machine can't read the level of water and just get in without control. Is it related to pressure sensor or what?
    Problem Solver:
  • 14 Answers
The drain hose must be fixed at 80-100 cm high,and must not have that efect of absorbtion.good luck.
Posted on Mar 17, 2011
Kenmore Elite HE 4t front load washing machine leaking water bottom right bottom at the end of wash
Unplug the power cord from the electrical outlet. Pull the machine far enough from the wall to get behind it to work
Use a putty knife to pry up and remove the end caps from the control panel. Remove the retaining screws from the control panel with a Phillips screwdriver.
Lift the control panel, and push it toward the back of the appliance. Unplug the wiring harness from the control panel. Remove the retaining clips using a flat-tip screwdriver to release them from the cabinet. Tilt the cabinet of the washer away from the frame, and set it aside.
Remove the pump retaining clips using a flat-tip screwdriver. Pull the pump from the motor shaft. Release the hose clamps using a pair of pliers, and pull the hoses from the drain pump.
Connect the hoses to the new drain pump using a pair of pliers. Place the pump on the motor shaft, and secure it with the retaining clips.
Set the cabinet in place on the washing machine frame, and install the retaining clips with the flat-tip screwdriver. Plug the wiring harness into the control panel. Close the control panel by pulling it forward, and install the retaining screws using a Phillips screwdriver. Install the end caps on the control panel, and push firmly to lock them into place.
Plug the power cord into the electrical outlet. Push the washing machine into place against the wall.
Custom Car Parts
Jun 06, 2012 | Kenmore Washing Machines
WASHING MACHINE NOT RETAINING WATER
Make sure that
A. the drain hose is above the hight of the water level.
B. there is an "air gap" between the drain hose and the stand pipe as the water can "syphon"out.
May 04, 2012 | Samsung Washing Machines
While moving my samsung top washing machine, I think my drain hose pipe has moved down the water level. Now machine is not able to retain the water while washing/soaking. I need to pull the drain hose pipe...
Although a few modern washing machines can operate with the drain pipe at any height, most machines will drain the water as soon as the drain pipe is placed below the machine water level.
The simplest solution for your problem would be to ask somebody with some handy man skills or hire a plumber to add a 2 inch PVC pipe to your drainage pipe which extends to a point behind your washing machine & then points upwards, making sure it is long enough to be at a higher point than your machines fullest water level.
This should be a relatively inexpensive alteration & will ensure that water does not drain unless the machine is on its drain cycle.
Please let me know if you need any further assistance.
Best wishes,
Graeme
Mar 10, 2011 | Samsung SW62ASP Top Load Washer
Where to locate drain plug so that I can put the washer in storage
Just lay the drain hose on the floor into a shallow pan. Gravity will drain it. Remove the water inlet hoses and then set the machine to warm wash--it should open the inlet solenoids which will allow the inlet water inside the machine to drain back out of the hose connectors. Once drained, turn the machine off. Hope this helps!
Jan 07, 2011 | Washing Machines
Washing machine model 110:23032102 is retaining
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23032102&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
I'd check the hoses for blockage, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
Apr 28, 2010 | Kenmore Washing Machines
Machine does not retain the water to enable washing to take place
The drain hose needs to come up higher than the water level in the machine, unless it is one that does not have a pump.
Apr 17, 2010 | Samsung SW62ASP Top Load Washer
Have water leaking out when washer is filling up. What could be the problem?
It sounds like you have a leaking pump. The pump is easy to replace:
1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
4 Remove the 2 clamps off of the hoses.
5 Install the new pump into the hoses, and reinstall the clamps.
6 With the retaining clips installed into the motor housing, install the pump.
7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
God Bless
Jul 08, 2009 | Whirlpool Washing Machines
Maytag MAV2755AWW Washing Machine is leaking water
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
Please rate this solution
Jan 11, 2008 | Maytag MAV2755A Top Load Washer
Water leaking from under the front of the washing machine
Dec 17, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Samsung SW62ASP Top Load Washer Logo
117 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
