Question about RCA ViSYS 2-Line Speakerphone
Where can I get a replacement piece to make the phone stand upright?
  • 54 Answers
Hello. This is the only accessory that is available for your phone model specifically: http://www.touchfreesolutions.net/visys-two-line-accessory-handset_8_46633_85916.html
It charges your phone and makes it stand upright as well :)
  • Lines: 2
  • Telephone Type: Cordless
  • Caller ID/Type: Handset
Please rate this solution 4 thumbs up if I helped you, so I can get paid :)
Posted on Mar 17, 2011
I opened the bottom to replace the brush (which was easy ) and the mechanism that holds the vacuum upright and or to snap the handle back to for use (that is a white plastic piece and a v shaped metal...
Hi sdibowitz,
I do not know if this will help, but here is a exploded view of your vacuum cleaner.
LINK
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 09, 2011 | Eureka Whirlwind 410 Bagless Upright...
It no longer stands upright as a 1 inch piece of arched plastic broke off. Is there a replacement part? what does it entail to fix it? Is it worth fixing?
Mine did the same thing.To date I have yet to find a replacement part.I do not think it is all that important either.And most likely not worth your time.
May 20, 2011 | Vacuums
I have a Dyson DC14 upright vacuum cleaner that after cleaning out I am unable to stand the vacuum upright so that I can use the tools any idea of the problem?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi its Darran at Dyson.
This procedure should solve the problem. Before you start it, please make sure the machine is unplugged.
First, remove the airway inspection. It’s located at the side of your cleaner.
Next, hold the main body of the cleaner halfway between the floor and upright position. Then, place two fingers in the square hole left by the airway inspection (you should be able to see a round hole at the base) then pull that plastic piece sharply upwards. You should hear a click as you do so.
Your machine should now stand upright and you may also notice an improvement in the suction, too.
If this procedure hasn’t worked, please call our experts on 0800 298 0298 (UK) or 1866MYDYSON (US).
Many thanks
Darran
Dyson customer service
May 08, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a Dyson DC14..I was vacuming and when I stopped the vacum would not stand up..it wouldn't click in the stationary poistion. When I turned it on all the suction is coming from the hose even though it...
Yes! Stand behind the machine. Hold the handle at about 45 degree angle. Remove the airway inspection valve (press the yellow release button that's between the right wheel and the clear bin and then just pull away that curved piece of plastic pipe). Inside, where that pipe plugs in, you will see a square plastic molding that should slide up and down. Push that square piece upwards until it snaps in to place. The machine will then stand upright.
I value your feedback so please remember to rate this response.  Good luck!
Sep 05, 2009 | Dyson DC14 All floors Bagless Upright...
My Dyson will not lock into the stand position
- Stand behind the vacuum cleaner
- Remove the AI PIPE (it has two purple buttons that you push together to lift it up and out - it looks like a Tuba)
- Lay the handle down
- Stick your index finger and middle finger into the vacant AI Pipe Hole (the square hole)
- Reach over with your thumb and press the black button in front of the square hole
- WHilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square holse basically)
- Remove your fingers from the square hole
- Lift the handle and stand your machine back upright again
- Place the AI Pipe back into the square hole
Jul 16, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson dc07 will not lock into upright position
- Stand behind the vacuum cleaner and look at the right-hand side wheel
- Lay the handle down and look for a black button that will be exposed in front of the square hole
- Whilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square hole basically)
Jul 12, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Dyson DC07 will not stand upright. It just lays in the recline position.
Jul 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Dyson upright suddenly won't stay in the upright position. It appears that a little rubber piece has fallen out of position.
hole basically)
Apr 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bissell proheat 12 amp
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
gsshg
Oct 28, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Dirt Devil upright vac
It could be a broken handle release, but it also could be the the clamps where the handle asm, and the base hold together came use, this will cause this problem on some Dirt Devils. The top has to come off to check this out.
Jul 13, 2008 | Kenmore Progressive Bagless Upright with...
RCA ViSYS 2-Line Speakerphone Logo
76 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
