Question about Pro Boat Toys
Hello i recently bought a proboat miss geico. does it have a reverse? if not, can it be modified to have reverse? secondly, it is programmed to run on nimh. but i installed 2 lipo 2s5300mah batteries instead. it will be 2 weeks before i get the lipo programmable kit , but i am going to play with it tomorow. is this ok? my friend tells me it is ok as long as i make sure i do not allow the battery to drain too low.
    Top Expert:
  • Pro Boat Master
  • 77,932 Answers
No and no.
Posted on Jul 12, 2017
We had the same problem and it was so very frustrating. We sent the Camera back for assesment and repair only to be told there was nothing wrong with it. The solution was so simple we felt like real dummies.
All you have to do is use Energizer Lithium Batteries, since we started using them we have not had a problem with Batteries going flat or that annoying Battery indicator flashing.
Posted on Oct 15, 2008
  • 10594 Answers
SOURCE: Camera keeps shutting off.
Please use Sony Cyber-shot batteries for DSC-H2 model camera.
Posted on Nov 18, 2008
  • 10 Answers
SOURCE: Battery Issues - LG KC910 Renoir
Try putting the battery in a zip lock back and putting it in the freezer overnight
Posted on May 24, 2009
  • 1619 Answers
SOURCE: battery on mercedes A140 drains. I drove the car
aftermarket stereo? dome lights? car alarm? Use a multimeter and see what fuse has power draw when car is off.
Posted on Jun 15, 2009
  • 37 Answers
SOURCE: natural gas generator will not start. 4 years after installation.
very likely a fuel problem. First pull the air cleaner cover off and try choking the engine by putting your hand over the intake partially choking it. If this don't work then go Down on the bottom right hand side behind the battery you will see a fuel regulator on top of it is a fuel solenoid with 2 wires coming off it. Below the fuel solenoid you will see 2 -1/4" pipe plugs one on top of the other. If you pull the top one out and gas comes out then you have fuel up to the solenoid. If you pull the bottom one out and crank the engine then you should get gas out of the bottom one. If you don't then make sure you are getting 12 vdc to those 2 wires during cranking. If you do then You are going to have to pull the 4 screws out of the solenoid and pull the solenoid off and make sure you the seat on your solenoid valve is not sticking. If all this checks out and you are getting fuel out both 1/4" pipe plug holes, then you will need to see if you have a spark at the spark plugs, if you don't then something is shorting out your ignition coils. Disconnect wire 18 from its terminal located above the oil cooler. If the engine starts and runs with this wire disconnected then you need to trace this wire back to the control panel and see whats causing it to ground out.
Let me know if this helps.
Posted on Dec 03, 2009
How do I review the recently established program?
Usually you push the program button repeatedly to cycle through programs... depending on timer.
Oct 05, 2014 | Hardware & Accessories
2004 dodge stratus over 110,000 bought used. When putting car in reverse occasionally it hesitates to go. Also the car shuts off once in awhile if put in reverse. Is the tranny going?
I does sound like a transmission issue, how old is the fluid?
Also, even if changed recently, was it given the specified fluid or the the shop fill it with universal fluid and just add a modifier? These transmissions are very picky, you should always use the actual ATF +4 and NEVER use the universal + an additive no matter what the oil change place says (bring your own).
If you do not know how old the fluid is or if it has the correct type, charge the fluid and filter, you might get lucky.
Hope this helps.
Feb 13, 2011 | 2004 Dodge Stratus
I recently bought a Sony PSP 3006 Version 5.50. My friends told me it cant be modified and I can't put games into it. Then how do I put games into it?? Somebody please help me... D:
Simple! Download Hen program and install it in ur memory card. U should have at 2gb of mem card! Download the system and follow the instruction! Download also the 5.05 gen D!
If ur PSP can't start, tell me more and pay me $5! Just kidding!
Nov 17, 2010 | Sony PSP (Piano Black)
I have an LG wall unit in my sun room. Geicos are coming into the room through the unit. Do you have a screen I can use to keep the Geicos out??
At a hardware store ask for 1/4"bird screen to fashon a cover.It wont block air flow that the unit needs & keep the pests out.
Mar 18, 2010 | Heating & Cooling
Cannot Patch Tiberium Wars.
Right click the game shortcut (or program) before you run it, then click run program as Administrator, or go to properties and check a box to run this program as Administrator.
Hope that Helps.
Jan 26, 2010 | Electronic Arts Command & Conquer 3:...
I just recently bought a used stanton str8 80 but it came without a tone arm weight?! where can i find a replacement?
There is nothing more annoying than buying something second-hand to find parts are missing. I've had a look on the net for you and you could try these sites - they might be able to help. and
I wish you luck finding a weight and hope this has gone some way to helping!
Aug 05, 2009 | Stanton STR8-80 Turntable
Silvercross something missing
Did you get an apron for the pram, it does sound like it is missing. If so, contact who may still have one that they can sell you.
I hope this helps.
Jul 27, 2009 | Baby Gear
Region code
hello charzy
have a look here video help
type model in the search see if any region codes
Jun 18, 2008 | Panasonic DVD-S52 DVD Player
Make Softwere
am programer in vfp9.0 you need to download manuals and examples
y have many
Apr 24, 2008 | Microsoft Visual FoxPro 9.0 Professional...
I have a CLT2054 but i missed the power cable
I bought one on Ebay and it didn't work because the one they sale on Ebay has a reverse polarity, try fixing this, cut the output wire, the one leading to your TV, then reverse the connection, white to un-shielded wire and do the same on the remaining wire.
Aug 22, 2007 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Toys Logo
115 people viewed this question
Top Pro Boat Toys Experts
john h
Andrew Taylor
Andrew Taylor
Are you a Pro Boat Toy Expert? Answer questions, earn points and help others
